[Nek5000-users] srun error
Tue Nov 29 09:50:31 CST 2016
Hi SP,
This is a script modified from nekbmpi that I used to run with srun awhile ago
echo $1        >  SESSION.NAME
echo `pwd`'/' >>  SESSION.NAME
touch $1.rea
rm ioinfo
mv $1.log.$2 $1.log1.$2
mv $1.his $1.his1
mv $1.sch $1.sch1
rm -f logfile
 nohup srun -p scx-comp -n $2 -N  $3  nek5000 > $1.log.$2 &
sleep 2
ln $1.log.$2 logfile
where $2 & $3 command line arguments are the numbers of MPI ranks and compute node, respectively.
Also make sure that you could run any MPI job first using, e.g., "Hello world" printout from ranks or something similar.
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, November 29, 2016 6:19 AM
To: Nek5000 Users
Subject: [Nek5000-users] srun error
 Hi Neks,
 I am trying to run a job using SLURM Job script. The batch script job
 suggested for MPI uses the srun command.
 My job submission failed and I got the following error:
 srun: error: Application launch failed: Job credential revoked
 Has anybody faced similar difficulties?
 SP
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
