[Nek5000-users] Laminar Flow Poiseuille
Tue Nov 22 22:59:57 CST 2016
Ok, if you are looking for plane-poiseuille flow you can look into the
turbChannel example. It is designed for turbulent channel flow, but you can
reduce the Reynolds number to generate a desired 3D Laminar flow. Also it
is periodic boundary conditions, you can modify BC's like inflow/outflow
according to your wish.
Best Regards,
Tanmoy
On Tue, Nov 22, 2016 at 12:34 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Helix example is a 3D Poiseiulle flow with flow in the z direction.
> I want to simulate a plane Poiseuille flow, in which a fluid
> is moving laterally between two plates whose length and width is much
> greater than the distance separating them.
> I don't know how to modify helix for my case. Can you help me?
> 2016-11-20 15:23 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>> You can start with the nek example : helix. Make necessary modifications
>> to helix.usr and helix.rea as needed.
>> On Sun, Nov 20, 2016 at 10:12 AM, <nek5000-users at lists.mcs.anl.gov>
>> wrote:
>>> Hi neks!
>>> I just want to simulate a laminar flow case like a Poiseuille flow. What
>>> case example I can use?
>>> Sorry for the question, I'm very new at nek.
>>> Thanks.
>>> Mateus.
>>> Mateus Peixoto Avanci
>>> Engenheiro Mecânico
>>> Aluno do Programa de Pós-Graduação em Engenharia Mecânica
>>> Universidade Federal Fluminense
>>> *http://lattes.cnpq.br/1773896725783894
>>> <http://lattes.cnpq.br/1773896725783894>*
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Engenheiro Mecânico
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161122/ed47b612/attachment.html>
