[Nek5000-users] Error Compiling
Fri Nov 18 06:56:27 CST 2016
Thanks Tanmoy!
I installed tcsh shell and everything is fine. Thanks a lot!
I'm very new at nek and I have a lot to learn about ^^
Thanks again!
Mateus.
2016-11-16 22:05 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
> Also visnek requires tcsh shell. Try installing that as well.
> Best Regards,
> Tanmoy
> On Wed, Nov 16, 2016 at 10:16 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Try ‘visnek eddy_uv’ without the ‘./'
>> On Nov 16, 2016, at 11:41 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Thanks for the answer.
>> I tried to use visnek. After type ./visnek eddy_uv I got these error:
>> bash: ./visnek: /bin/tcsh: bad interpreter: No such file or directory
>> Any ideia?
>> Mateus.
>> 2016-11-16 14:34 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>>> I think you can ignore the error message you are getting.
>>> As for visualization of the solution, you can also use visit or
>>> paraview. You have to use visnek.
>>> Marco
>>> On Nov 16, 2016, at 11:12 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> I realize my mistake. My PATH was wrong, now I can compile without
>>> problems.
>>> But now I have other problem. After compile with makenek and after run
>>> with nekb I can't vizualize the results with postx.
>>> My path is /bin, I type ./postx and I got a black window without a
>>> sidebar.
>>> Whats wrong?
>>> Thanks.
>>> 2016-11-16 1:11 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>>>> What does echo $PATH return for you?
>>>> On Nov 15, 2016, at 4:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi all,
>>>> I'm ver new at nek5000. I'm trying to compiling a first example case
>>>> (eddy) and I get a error.
>>>> After ./makenek eddy_uv
>>>> I get:
>>>> ./makenek: line 92: /home/mateus/nek5000/core/makenek.inc: No such
>>>> file or directory
>>>> make: makefile: No such file or directory
>>>> make: *** No rule to make target 'makefile'.  Stop.
>>>> Can someone help me?
>>>> Mateus Peixoto Avanci
>>>> Engenheiro Mecânico
>>>> Aluno do Programa de Pós-Graduação em Engenharia Mecânica
>>>> Universidade Federal Fluminense
>>>> *http://lattes.cnpq.br/1773896725783894
>>>> <http://lattes.cnpq.br/1773896725783894>*
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> Engenheiro Mecânico
>> Engenheiro Mecânico
Engenheiro Mecânico
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161118/bdfa3ba8/attachment.html>
