[Nek5000-users] Error Compiling
Thu Nov 17 02:22:42 CST 2016
Sorry this mailing list is not about learning Linux. Don¹t get me wrong but
I would suggest you learn Linux and the command line first.
Von:  <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of
<nek5000-users at lists.mcs.anl.gov>
Antworten an:  <nek5000-users at lists.mcs.anl.gov>
Datum:  Thursday, November 17, 2016 at 1:48 AM
An:  <nek5000-users at lists.mcs.anl.gov>
Betreff:  Re: [Nek5000-users] Error Compiling
I tried and I got "command not found".
I copied visnek from /bin and paste at the eddy folder, is that right?
2016-11-16 15:16 GMT-02:00  <nek5000-users at lists.mcs.anl.gov>:
> Try Œvisnek eddy_uv¹ without the Œ./'
>> On Nov 16, 2016, at 11:41 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Thanks for the answer.
>> I tried to use visnek. After type ./visnek eddy_uv I got these error:
>> bash: ./visnek: /bin/tcsh: bad interpreter: No such file or directory
>> Any ideia?
>> Mateus.
>> 2016-11-16 14:34 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>>> I think you can ignore the error message you are getting.
>>> As for visualization of the solution, you can also use visit or paraview.
>>> You have to use visnek.
>>> Marco
>>>> On Nov 16, 2016, at 11:12 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> I realize my mistake. My PATH was wrong, now I can compile without
>>>> problems.
>>>> But now I have other problem. After compile with makenek and after run with
>>>> nekb I can't vizualize the results with postx.
>>>> My path is /bin, I type ./postx and I got a black window without a sidebar.
>>>> Whats wrong?
>>>> Thanks.
>>>> 2016-11-16 1:11 GMT-02:00 <nek5000-users at lists.mcs.anl.gov>:
>>>>> What does echo $PATH return for you?
>>>>>> On Nov 15, 2016, at 4:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hi all,
>>>>>> I'm ver new at nek5000. I'm trying to compiling a first example case
>>>>>> (eddy) and I get a error.
>>>>>> After ./makenek eddy_uv
>>>>>> I get:
>>>>>> ./makenek: line 92: /home/mateus/nek5000/core/makenek.inc: No such file
>>>>>> or directory
>>>>>> make: makefile: No such file or directory
>>>>>> make: *** No rule to make target 'makefile'.  Stop.
>>>>>> Can someone help me?
>>>>>> Mateus Peixoto Avanci
>>>>>> Engenheiro Mecânico
>>>>>> Aluno do Programa de Pós-Graduação em Engenharia Mecânica
>>>>>> Universidade Federal Fluminense
>>>>>> http://lattes.cnpq.br/1773896725783894
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Engenheiro Mecânico
>> Engenheiro Mecânico
Engenheiro Mecânico
_______________________________________________ Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161117/6f8f52a5/attachment.html>
