[Nek5000-users] Problem when running with variable fluid properties
Tue Mar 15 14:14:43 CDT 2016
After successfully running some DNS cases of a turbulent pipe with heat
transfer in NEK (
http://www.sciencedirect.com/science/article/pii/S0142727X15000533), I am
now struggling to run a similar case but with variable fluid properties (Re
and Pe being functions of temperature).
I am currently using Pn-Pn2 (lx2=lx1-2 in SIZE) method and stress
formulation (IFSTRS=true), together with IFUSERVP=true (p030=1.0 in REA
file) to be able to define the viscosity and conductivity functions.
Initial flow conditions are taken from a previous constant fluid properties
turbulent pipe case.
My problem is that, when setting IFUSERVP=true, the flow velocities go to
zero in very few time steps, even though I was setting constant fluid
properties in USERVP subroutine for trial purposes.
I have checked that the forcing in the momentum equation (subroutine USERF)
is correctly set.
Could you please give me some indications as to what I can be doing wrong?
Thanks in advance.
Regards
Antonio
ANTONIO ANTORANZ PERALES
Universidad Carlos III de Madrid
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160315/e7fb6b06/attachment.html>
