[Nek5000-users] Nek5000-users Digest, Vol 88, Issue 8
Sun Jun 12 14:20:45 CDT 2016
Hi Jing,
Following your instructions, I re-generate a new 2D cylinder mesh (see
attachment, plz), set the upper (4) and bottom (3) as the periodics, the
distance in y is 30,
the setting as followed:
convert('cyl.msh', curves={7:{'type':'C', 'radius':-0.5, 'depth': 3,
'circle_center': (0, 0)}}, periodic_dx={(3,4) : [0, 30.0, 0]}, bcs={ 5:
'O', 6: 'v', 7: 'W'})
as fas as fine, while it failed to convert , error informations are
*Traceback (most recent call last):  File "mshconvert_new.py", line 15, in
<module>    convert('cyl.msh', curves={7:{'type':'C', 'radius':-0.5,
'depth': 3, 'circle_center': (0, 0)}}, periodic_dx={(3,4) : [0, -30.0, 0]},
bcs={ 5: 'O', 6: 'v', 7: 'W'})  File
"/home/wei/Workstation/CFD/mshconvert/mshconvert.py", line 1458, in
convert    create_periodic_face_map(periodic_dx)  File
"/home/wei/Workstation/CFD/mshconvert/mshconvert.py", line 304, in
create_periodic_face_map    - abs(dx)) < 1.e-7*norm(dx)):ValueError:
operands could not be broadcast together with shapes (2,) (3,) *
would you like to help me? thanks!
regards
Wei
2016-06-09 16:15 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
> Hi Wei,
> >1. to impose the periodic boundary conditons: in the script, it strongly
> >recommend to impose "P" through the script, then how to setup it in
> >mshconvert.py? the way
> >convert('mesh.msh', bcs={1:'W',2:'v',3:'O',4:'P', 5:'P'})
> > can generate the rea field but failed in the step of genmap. so how to
> > treat boundary 4 and 5 as periodic BCs?
> Probably you should have to do likes
> convert('mesh.msh', periodic_dx={(4,5) : [0, 0, 2]},
> bcs={1:'W',2:'v',3:'O'})
> Where the "periodic_dx" is to specify which pair-zone is periodic and what
> is the orientation of zones. in the example, zones 4,5 are the periodic
> boundaries and on the z-direction with distance of 2.
> >2. about the curved wall. there is no problem to  define a circle by
> >"Circle" command, but if I want to using "m" to define a spline curve, how
> t>o seed middle points? I know in Gambit I can mesh the line using 3 node,
> I
> >defined 3 node mode to mesh a circle, and using "m" instead of "circle",
> >however,  it failed to generate the rea file. the circle merged into a
> >point, then what should I do to active the spline curve?
> Yes, it seems to be bugs in the python script  with "m" method. In the
> python script, the midpoints is (somehow) defined by
>  x_m = (x_1+x_2)/2;
>  y_m = (y_1+y_2)/2;
> However, in the nek5000 (tools/prenek/zipper2.f) it read the values of
> (x_q, y_q) instead of (x_m,y_m) !?
> !   subroutine xyzquad(xl,yl,zl,nxl,nyl,nzl,e)
>      do k=1,nedge
>          if (ccurve(k,e).eq.'m') then
>             j = eindx(k)
>             xq(j) = curve(1,k,e)
>             yq(j) = curve(2,k,e)
>             zq(j) = curve(3,k,e)
>          endif
>       enddo
> This should be confirmed by nek5000 developers.
> Thanks.
> /Jing
> From: nek5000-users-bounces at lists.mcs.anl.gov <
> nek5000-users-bounces at lists.mcs.anl.gov> on behalf of
> nek5000-users-request at lists.mcs.anl.gov <
> nek5000-users-request at lists.mcs.anl.gov>
> Sent: Wednesday, June 8, 2016 18:18
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Nek5000-users Digest, Vol 88, Issue 8
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Re: Nek5000-users Digest, Vol 88, Issue 5
>       (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Wed, 8 Jun 2016 18:15:42 +0200
> From: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 88, Issue 5
> Message-ID:
>         <mailman.23474.1465402725.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
> Hello Jing,
> Recently I am also working on converting fluent mesh to nek5000. I have
> generated the *msh from gambit, then using the mshconvert.py tool to
> convert a simple mesh with a circular cylinder inside a square.
> simply, I can get the *rea file with circle of the "W", "v" and "O". but I
> have met two problems;
> to seed middle points? I know in Gambit I can mesh the line using 3 node, I
> Thanks!
> Wei
> 2016-06-08 15:46 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
> > Hi Mansi,
> > You can find the updated "mshconvert.py" in the attachment.  You can run
> > the script for your case likes
> > $ ipython
> > In [1]: from mshconvert import *
> > Converting from ANSYS Fluent format (.msh) to Nek5000, semtex or FEniCS
> > format
> > In [2]: convert('mesh_hexa_final.msh', bcs={10:'W',11:'v',12:'v',13:'O'})
> > Here I assume that BC "W" is on zone 10, "v" is on zones 11 and 12, and
> > 'O' on zone 13.
> > The snapshot for the Nek5000 mesh using visit is also attached in the
> > email.
> > /Jing
Wei HE 何偉
School of Aeronautics
Universidad Politécnica de Madrid
http://www.cfm.upm.es/
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160612/84a38f20/attachment-0001.html>
Type: model/mesh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160612/84a38f20/attachment-0001.msh>
