[Nek5000-users] avg_all and visnek
Mon Jul 25 00:38:18 CDT 2016
Hi Marco,
It seems like ifxyo overwrites itself to .false. after istep .eq. 0
conditional statement. If you have the flexibility of running the code
again (if it runs quickly), you can set ifxyo = .true. just before the
avg_all() call. Otherwise, you can run, nek5000 is post-processing mode as
follows.
subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      include 'ZPER' ! Needed to communicate nelx,nely,nelz to my_stats
      include 'RESTART'
      character*80 filename
       filename = 'avg.....fld..' <original filename of average file>
      call load_fld(filename)
       ifxyo = .true.
       call outpost(vx,vy,vz,pr,t,'avx')
      call exitt
      return
      end
On Fri, Jul 22, 2016 at 12:48 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Here is what I have in my usrchk():
>       subroutine userchk
>       include 'SIZE'
>       include 'TOTAL'
>       common /my_recycle/ nslab,n_in_slab
>       ifxyo = .true.
>       if (istep.eq.0) call outpost(vx,vy,vz,pr,t,'   ')
>       ifxyo = .false.
> c      call set_inflow(nslab,n_in_slab)   ! set up inflow BCs
>       nelx = n_in_slab
>       nely = 1
>       nelz = nelgv/(nelx*nely)
> c     if (istep.gt.0) call my_stats
>       call avg_all()
>       return
>       end
> Marco
> On Jul 22, 2016, at 3:34 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Interesting... Check whether there is a statement
> ifxyo = .false. in usrchk() which overrides .rea specification (typically
> after the first dump to save the disk space)
> Aleks
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Friday, July 22, 2016 1:52 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] avg_all and visnek
> Hi Aleks,
> thanks for your help.
> I did set CORDINATES to T in the block ‘SPECIFICATIONS FOLLOW’. It was
> originally set to F.
> I copied my instantaneous dump file into avg*0.f00000 and then substituted
> firsttimestep:1 to firsttimestep:0. It did work.
> This is the first time I have to do such a thing when using avg_all() even
> though I have used avg_all() in the past. Is there anything that has
> changed in the code?
> Thanks,
> Marco
> On Jul 22, 2016, at 2:17 PM, nek5000-users at lists.mcs.anl.gov wrote:
> firsttimestep
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160724/637d861f/attachment.html>
