[Nek5000-users] (no subject)
Fri Jul 15 08:24:32 CDT 2016
Hi Shivang,
Does the rest of the code  (i.e., nek5000 proper) run ok?
If so, then your problem likely is the xlib interface on your platform.
For post processing you have an alternative in VisIt, which is also freely downloadable.
For preprocessing there is, say, Cubit, for which there are a few converters available but
which at present are really in beta form as far as I know.
Your best bet is to be able to have prenek and postnek working.. and for this you
need X windows to work on your PC.
hth,
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, July 15, 2016 3:29 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] (no subject)
Hello Users,
I have started running the basic example to understand the functioning of the code. I am using a windows 10 system and finding difficulties with the basic compiling of maketools and makenek file. I think this is happening because of system variable and compiler issues. I am using gcc and gfortran compilers. Has anyone gone through such kind of problems? Your suggestions will be of great help !
Shivang Aggarwal
Faculty of Aerospace Engineering
TU Delft
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160715/d9fbba45/attachment.html>
