[Nek5000-users] Turbulence Models not yet implemented
Thu Jul 7 12:35:51 CDT 2016
I apologize, I wasn't very clear in my previous message, at all.
My question is this: there is a turbulent channel example included with Nek5000. According to the file turbChannel.usr, I have the understanding that this is an LES model of a turbulent channel at Re(tau)=590. How can this be an LES model if there are no turbulence models implemented in Nek5000?
From: nek5000-users-bounces at lists.mcs.anl.gov [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of nek5000-users at lists.mcs.anl.gov
Sent: Thursday, July 07, 2016 11:11 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Turbulence Models not yet implemented
Let me explain slightly better. For Direct Numerical Simulations (DNS), all the scales of turbulence are computed directly and no scales are modeled. Thus, no turbulence model is needed, you will get turbulence naturally as the direct solution of equations. Usually, some initial perturbation of the flow field is recommended to get the statistically-converged turbulence faster. For Large Eddy Simulations (LES), only the largest scales are computed directly, and the smaller scales are modeled (with the so-called sub grid-scale (SGS) models). SGS models for LES are available in Nek5000, including classical Smagorinsky and dynamic Smagorinsky models (they are in a TurbChannel example). For Reynolds Averaged Navier Stokes (RANS) simulations, all scales of motion are modeled. RANS models for Nek5000 are still in an exploratory stage and I believe are not yet part of the repo suite.
Please, let me know if you have any further questions.
Best regards,
Yulia
On Jul 6, 2016, at 4:42 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
I am trying to generate a set of DNS data for a turbulent channel flow, and I am currently trying to build my case in prex. When I try to select "Turbulence Model", it says "Turbulence Models not yet implemented". How can this be the case if there is already an example turbulent channel flow included with Nek5000?
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160707/06993210/attachment.html>
