[Nek5000-users] WARNING: DIV(V)-QTL too large
Sat Jan 23 18:43:58 CST 2016
dear neks,
nobody is replying me???
Thanks
> On 12 Jan 2016, at 13:43, Desanga Fernando <desanga at gmail.com> wrote:
> dear developers ,
> I'm doing a rotator-stator type of simulation using Pn-Pn method (lx1=8 lxd=12 ).  Annular mesh has been created using genbox (box file is attached). Inner radius is considered as the hub and outer radius is the case (or the sidewalls of the disk ). I use following settings  in rea file
> 3                     p27  TORDER
> 20.00000         p93 Number of prev pressure solns saved
> 5.000000         p94 start projecting vel. after p94 step
> 5.000000         p95 start projecting pr after p95 step
> 4.000000         p99    dealiasing:if <0 disable
> 1.000000         p101   No. of additional filter modes
>  5.000000E-02     p103   weight of stabilizing filter (.01)
> Hub and rotor (z=0) rotating in a constant angular velocity. Stator (z=0.2) and side walls are stationary. singularities among rotor and stationary components are resolved using a method which is very similar to vortex example (using an exponential ramp instead of a polynomial ramp) .  After 3000-4000 iterations , CFL number reached around 0.48 and I got following warning
>                L1/L2 DIV(V)    :  -1.6903E-16   1.0198E-01
>                L1/L2 QTL       :   0.0000E+00   0.0000E+00
>                L1/L2 DIV(V)-QTL:  -1.6903E-16   1.0198E-01
>                WARNING: DIV(V)-QTL too large!
> I'm not using any inlets or outlets in my simulation. I'm not sure the reason for this warning.  can anybody give me a little advice regarding this situation.  I can provide more details on request.
> Desanga
> <3da.box>
