[Nek5000-users] error in generalev
Fri Jan 22 06:55:09 CST 2016
Hi Xu,
 Did you use genbox to build this case?
You need BCs on all 4 sides ...
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, January 22, 2016 12:56 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] error in generalev
Hello Nek,
I just met a trouble in running the case ‘high_ray’ In ‘benard’. I changed the original 2X1 calculation field into a 1x1 cavity, and when I ran the case, the error message ‘error in generalev’ appeared on the screen. All elements of the matrix ‘Aeig’ were ‘NaN’. I guess that I made some mistakes in the .usr file, maybe wrong B.C., but I’m not sure. I hope I can get some help from you. Thank you!
Kind regards
Xu Bolun
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160122/3b8f6490/attachment.html>
