[Nek5000-users] User defined boundary conditions from internal plane
Mon Feb 22 09:30:48 CST 2016
Dear All,
I would like to impose boundary conditions (in userbc) with velocity
values coming from a 2D plane in the same 3D domain being simulated (a
channel). For example, having two channels on top of each other, how can
I extract planar/cross-section values from the top channel (set with
periodic boundary conditions in the streamwise direction) and impose
them as "v" bc conditions in the bottom channel (set with v as inlet and O
(outflow))?
What I cannot understand is how to extract the values from a certain
y-z plane to impose them as bc in userbc (assuming the element distribution
is
the same in both cases).
jp
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160222/5489549a/attachment.html>
