[Nek5000-users] Mass flow rate and averages
Wed Feb 17 08:21:48 CST 2016
Hi neks,
maybe mine, will be noob questions, but i am a nek noob.
I am running a DNS of channel with riblets, now i  need to know the
averages fields and the mass flow rate.
For the averages fields i have seen in turbChannel example folder, and i
have seen in turbchannel.usr that there is a subroutine that do it.
But i didn't understand, if i set fintime(P10) and iotime(P14) and P68
in rea file, have i always the output?Because in turbchannel example, if
i set how i already told, i have errors in compilation.
And the second question is related to the mass flow rate.
If i set forcing, can i know the relative mass flow rate? Or viceversa,
if i set the mass flow rate in .rea file, can i know the forcing? Where
can i read or compute it?
