[Nek5000-users] ERROR of compilating
Wed Feb 17 08:17:13 CST 2016
Hi all,
I have a compilation issue with my example.
I created a mesh 3D using n2to3 from the  file w2dcyl020a.rea. I don't have
any issue with compilation. Then I refined the mesh 2D using pretex and
rebuilt the mesh 3D with n2to3 like before this and this time  an error
message occured:
"obj/stenosis.o: In function `uservp_':
stenosis.f:(.text+0xd): relocation truncated to fit: R_X86_64_PC32 against
symbol `nekuse_' defined in COMMON section in obj/stenosis.o
stenosis.f:(.text+0x1b): relocation truncated to fit: R_X86_64_PC32 against
stenosis.f:(.text+0x29): relocation truncated to fit: R_X86_64_PC32 against
obj/stenosis.o: In function `userf_':
stenosis.f:(.text+0x35): relocation truncated to fit: R_X86_64_PC32 against
stenosis.f:(.text+0x3c): relocation truncated to fit: R_X86_64_PC32 against
stenosis.f:(.text+0x43): relocation truncated to fit: R_X86_64_PC32 against
obj/stenosis.o: In function `userq_':
stenosis.f:(.text+0x53): relocation truncated to fit: R_X86_64_PC32 against
obj/stenosis.o: In function `userchk_':
stenosis.f:(.text+0x73): relocation truncated to fit: R_X86_64_PC32 against
symbol `dimn_' defined in COMMON section in obj/stenosis.o
stenosis.f:(.text+0x189): relocation truncated to fit: R_X86_64_PC32
against symbol `dimn_' defined in COMMON section in obj/stenosis.o
stenosis.f:(.text+0x1e7): relocation truncated to fit: R_X86_64_PC32
obj/stenosis.o: In function `userbc_':
stenosis.f:(.text+0x2b4): additional relocation overflows omitted from the
output
collect2: ld a retourné 1 code d'état d'exécution
make: *** [nek5000] Erreur 1"
The same issue occures if I change the parameters lx1 and lxd in SIZE-file.
Does anybody have an idea on how to fix this?
Thank you for any help or suggestion.
*Andrew*
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160217/1191fcf7/attachment.html>
