[Nek5000-users] Nek5000-users Digest, Vol 84, Issue 13
Fri Feb 12 14:10:51 CST 2016
Hello Murph,
I tried doing the which gfortran and gfortran -v.I also tried the yum update and yum upgrade. All I got is nothing. I am so badly stuck nothing is working.[mansi at maea203-01 eddy]$ which gfortran
/usr/bin/gfortran
[mansi at maea203-01 eddy]$ gfortran v-
gfortran: v-: No such file or directory
[mansi at maea203-01 eddy]$ gfortran -v
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --enable-plugin --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=x86_64-redhat-linux
Thread model: posix
gcc version 4.1.2 20071124 (Red Hat 4.1.2-42)
