[Nek5000-users] Link Fortran90 code via Fortran Interface
Thu Feb 11 16:06:56 CST 2016
I guess you could just use common blocks also in the Fortran90 code.
Philipp
On 2016-02-11 18:00, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Philipp,
> You should be able to define subprograms in a separate F90 file and call
> them from the usr file.  Then, just compile your new file and add it to
> the link line using the "USR_LFLAGS" option in makenek. However, it
> could be a bit tricky to access global data stored Nek5000's common
> blocks, so I'd strongly suggest making those routines self-contained
> with all data passing via arguments.  This approach can be used to link
> in C or C++ code as well, as they are all object compatible.
> The usr file itself needs to be F77, if for no other reason than the
> include files ('SIZE', for example) are in F77 format.
> Depending on your problem, you may be able to use NekBox, which is
> written in F90 and uses F90 for the usr file.  NekBox is more of a
> prototyping code than a production code, so its functionality is
> limited.  See:
> https://github.com/Nek5000/NekBox
> Max
> On Thu, Feb 11, 2016 at 8:35 AM <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi Neks,
>     Is it possible to link Fortran90 code via the Fortran Interface
>     (b3d.usr).
>     Best regards, Philipp Weiss
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
