[Nek5000-users] SYM boundary conditions
Wed Feb 10 05:17:28 CST 2016
one initial suggestion would be to use ON at the outflow. Is the flow
turbulent at the outflow boundary?
Philipp
On 2016-02-10 11:45, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> Thank you. I am trying to simulate a flow whose inlet boundary condition
> is time periodic ux=sin(omega*time). Since there is an injection and a
> suction, and the mean flow is zero, I think that the boundary conditions
> should let the transpiration/penetration of the flow... (I have tried to
> run the simulation using outflow BC but it crashes). Is there any BC
> condition in Nek5000 that suits to this problem?
> Thank you for your help in advance.
> Best regards,
> SL
> El 10-02-2016 10:20, nek5000-users at lists.mcs.anl.gov escribió:
>> Hi,
>> SYM is essentially means that the velocity through the interface is
>> zero and for the inplane velocities that the normal gradients vanish.
>> So it does not allow transpiration/penetration through the boundary.
>> So I suspect that this condition is not what you are looking for.
>> However, I am not exactly sure what you really mean. Perhaps you can
>> say a bit more about your case?
>> Best regards,
>> Philipp
>> On 2016-02-10 08:02, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Neks,
>>> I am looking for a boundary condition that leads the flow to go out or
>>> to go into the domain.
>>> Is 'SYM' valid for this purpose?
>>> I think that what I am looking for is, in the outlet surface:
>>>    - If the velocity vector at the outlet points out of the domain, then
>>> the boundary condition for the velocity will be of the Neumann type
>>>    - However, if the velocity at the outlet points into the domain, then
>>> we can imagine that the outflow is no longer an outflow, but an inflow,
>>> and that we therefore would like to specify a Dirichlet boundary
>>> condition for velocity
>>> Thanks in advance
>>> SL
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
