[Nek5000-users] SYM boundary conditions
Wed Feb 10 03:20:52 CST 2016
SYM is essentially means that the velocity through the interface is zero
and for the inplane velocities that the normal gradients vanish. So it
does not allow transpiration/penetration through the boundary. So I
suspect that this condition is not what you are looking for.
However, I am not exactly sure what you really mean. Perhaps you can say
a bit more about your case?
Best regards,
Philipp
On 2016-02-10 08:02, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I am looking for a boundary condition that leads the flow to go out or
> to go into the domain.
> Is 'SYM' valid for this purpose?
> I think that what I am looking for is, in the outlet surface:
>    - If the velocity vector at the outlet points out of the domain, then
> the boundary condition for the velocity will be of the Neumann type
>    - However, if the velocity at the outlet points into the domain, then
> we can imagine that the outflow is no longer an outflow, but an inflow,
> and that we therefore would like to specify a Dirichlet boundary
> condition for velocity
> Thanks in advance
> SL
> Nek5000-users mailing list
