[Nek5000-users] Clarification on Adjoint solver
Tue Feb 2 02:09:35 CST 2016
Hi
The adjoint implementation in nek assumes change of the direction of
time evolution. The goal is to use the standard nek solver with minimal
modifications (only advection terms have to be changed). You get these
equations from you standard one by changing the time and pressure sign
(t -> -t; p-> -p). This of course changes your time integration limits,
but it shouldn't be a problem. So when you  have your linear direct
simulation, to turn it into dual one it is enough to include  in your
userchk include files ADJOINT and TSTEP, and for ISTEP.eq.0 set
IFADJOINT to true. Something like:
       subroutine userchk
       include 'SIZE'
       include 'TSTEP'           ! ISTEP
       include 'ADJOINT'            ! IFADJ
       if(ISTEP.eq.0) ADJOINT=.TRUE.
There is no need to modify ###.rea or ###.map files. The only problem
are boundary conditions for open flows, as they would require
non-homogeneous bc. In this case to avoid problems we usually use
sufficiently large domain together with zero Dirichlet bc. The last
issue is sufficient resolution for both direct and adjoin runs. I hope
this gives you some idea about nek implementation.
Regards
Adam
On 2016-02-01 22:17, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> To my knowledge, Nek5000 is able to solve adjoint equations of the form:
> $\partial u_a/\partial t + V.\nabla u_a - u_a.(\nabla V)^T + \nabla
> \p_a + 1/Re \nabla^2 u_a=0$ and $\nabla.u_a=0$
> where u_a and p_a are adjoint velocity and pressure. (Slightly
> different formulation may be seen in literature).
> Let's assume the forward problem is already solved so that $V$, i.e.
> velocity, (and possibly $p$ as the pressure) is (are) already know.
> Thus, the initial and boundary conditions for adjoint NS are also
> known. How can we now solve the dual/adjoint NS problem with Nek5000?
> Is there any example on how to modify .rea files? Specailly, the
> "convection term of $V.\nabla u_a - u_a.(\nabla V)^T$ needs to be
> modified compared to forward NS but am not sure how.
> My search of mailing list entails some modifications in "perturb.f"
> subroutine, but a little bit more clarification on that would be
> really appreciated.
> Yours,
> Saleh
> Nek5000-users mailing list
