[Nek5000-users] maketools all fails at postnek on RHEL6.4
Wed Dec 14 09:25:03 CST 2016
Good morning,
I just tested using the master version of the v16.0.0 release using both BIGMEM = “true” and BIGMEM = “false” on the ALCF systems. Output below (same for both):
[lfick at cetuslac1 tools]$ ./maketools all
Make genmap...
make[1]: Entering directory `/gpfs/mira-home/lfick/Nek5000/tools/genmap'
gfortran -fdefault-real-8 -o /home/lfick/bin/genmap genmap.o byte.o
make[1]: Leaving directory `/gpfs/mira-home/lfick/Nek5000/tools/genmap'
Make n2to3...
make[1]: Entering directory `/gpfs/mira-home/lfick/Nek5000/tools/n2to3'
gfortran   -o /home/lfick/bin/n2to3 n2to3.o byte.o
make[1]: Leaving directory `/gpfs/mira-home/lfick/Nek5000/tools/n2to3'
Make postnek...
make[1]: Entering directory `/gpfs/mira-home/lfick/Nek5000/tools/postnek'
gfortran -c    ../../nek/3rd_party/blas.f
gfortran: ../../nek/3rd_party/blas.f: No such file or directory
gfortran: no input files
make[1]: *** [blas.o] Error 1
make[1]: Leaving directory `/gpfs/mira-home/lfick/Nek5000/tools/postnek'
make: *** [all] Error 1
I’ve noticed this before, but when compiling specific tools (reatore2 in my case) it works fine.
Lambert Fick
Graduate Research Assistant | Department of Nuclear Engineering
Texas A&M University
+1 (979) 422-8317 | Lambert.Fick at tamu.edu <mailto:Lambert.Fick at tamu.edu>
> On Dec 14, 2016, at 11:10 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Can you try again with release/v16.0.0 (https://github.com/Nek5000/Nek5000/archive/release/v16.0.0.zip)
> Cheers,
> Stefan
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Wednesday 14th December 2016 18:06
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] maketools all fails at postnek on RHEL6.4
>> Using the tarball at https://github.com/Nek5000/nek5000/archive/master.tar.gz to compile locally on my RHEL6.4 server.  During maketools event, only the genmap and n2to3 tools are compiled and the make event fails out as shown below.  Is
>> this attributed to BIGMEM=true in maketools, or something else?  Can anyone help?  Error and gcc/gfortran information below
>> Thanks
>> Richard P
>> [user at rhel64 tools]$ gedit maketools
>> [user at rhel64 tools]$ ./maketools all /nfs/home/user/Nek5000
>> Make genmap...
>> make[1]: Entering directory `/home/user/Nek5000-master/tools/genmap'
>> gfortran -mcmodel=medium -fdefault-real-8 -o /nfs/home/user/Nek5000/genmap genmap.o byte.o
>> make[1]: Leaving directory `/home/user/Nek5000-master/tools/genmap'
>> Make n2to3...
>> make[1]: Entering directory `/home/user/Nek5000-master/tools/n2to3'
>> gfortran -mcmodel=medium   -o /nfs/home/user/Nek5000/n2to3 n2to3.o byte.o
>> make[1]: Leaving directory `/home/user/Nek5000-master/tools/n2to3'
>> Make postnek...
>> make[1]: Entering directory `/home/user/Nek5000-master/tools/postnek'
>> gfortran -mcmodel=medium -c    postnek.f
>> postnek.f:1977.19:
>>          ifbswap = if_byte_swap_test(test)
>>                    1
>> Warning: Extension: Conversion from INTEGER(4) to LOGICAL(4) at (1)
>> gfortran -mcmodel=medium -c    postnek2.f
>> gfortran -mcmodel=medium -c    postnek3.f
>> postnek3.f:1552.20:
>>       COMMON /CTMP4/ wk(LXYZ,3,3)
>>                     1
>> Warning: Named COMMON block 'ctmp4' at (1) shall be of the same size
>> gfortran -mcmodel=medium -c    postnek5.f
>> postnek5.f:711.21:
>>       COMMON /ccdiag/ iee,iii
>>                      1
>> Warning: Named COMMON block 'ccdiag' at (1) shall be of the same size
>> gfortran -mcmodel=medium -c    postnek6.f
>> gfortran -mcmodel=medium -c    tsort.f
>> gfortran -mcmodel=medium -c    postnek8.f
>> devices.inc:22.19:
>>     Included at basics.inc:168:
>>     Included at postnek8.f:96:
>>       COMMON/SCALE/XFAC ,YFAC ,XZERO ,YZERO
>>                    1
>> Warning: Named COMMON block 'scale' at (1) shall be of the same size
>> gfortran -mcmodel=medium -c    postnek9.f
>> gfortran -mcmodel=medium -c    plot.f
>> gfortran -mcmodel=medium -c    getfld.f
>> gfortran -mcmodel=medium -c    legend.f
>> gfortran -mcmodel=medium -c    userf.f
>> userf.f:1282.21:
>>       common /rlobjs/    x_l_objs(mopts),y_l_objs(mopts),z_l_objs(mopts)
>>                      1
>> Warning: Named COMMON block 'rlobjs' at (1) shall be of the same size
>> userf.f:1816.21:
>>       common /rlobjs/ avg(6,0:mopts-1,3)
>>                      1
>> userf.f:5261.20:
>>       common /ctmp1/ uavg(nxm*nelm),vavg(nxm*nelm),wavg(nxm*nelm)
>>                     1
>> Warning: Named COMMON block 'ctmp1' at (1) shall be of the same size
>> gfortran -mcmodel=medium -c    trap.f
>> gfortran -mcmodel=medium -c    animate.f
>> gfortran -mcmodel=medium -c    genxyz.f
>> gfortran -mcmodel=medium -c    screen.f
>> gfortran -mcmodel=medium -c    g3d.f
>> gfortran -mcmodel=medium -c    subs.f
>> gfortran -mcmodel=medium -c    xinterface.f
>> gfortran -mcmodel=medium -c    locglob.f
>> gfortran -mcmodel=medium -c    postnek5a.f
>> gfortran -mcmodel=medium -c    ../../nek/3rd_party/blas.f
>> make[1]: Leaving directory `/home/user/Nek5000-master/tools/postnek'
>> ###########gcc and gfortran details for server##########
>> [user at rhel64 tools]$ rpm -qa | grep gcc
>> gcc-4.4.7-3.el6.x86_64
>> compat-gcc-34-3.4.6-19.el6.x86_64
>> gcc-gfortran-4.4.7-3.el6.x86_64
>> libgcc-4.4.7-3.el6.i686
>> gcc-c-4.4.7-3.el6.x86_64
>> libgcc-4.4.7-3.el6.x86_64
>> [user at rhel64 tools]$ rpm -qa | grep gfortran
>> libgfortran-4.4.7-3.el6.x86_64
>> compat-libgfortran-41-4.1.2-39.el6.x86_64
>> Richard B Powell
>> Technical Architect II
>> Operations/Server Engineering
>> AREVA, Inc.
>> 3315 Old Forest Road OF-60
>> Lynchburg, VA  24501
>> Phone: 1 434-832-3894
>> Fax: 1 434-382-3894
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161214/d55c1a91/attachment-0001.html>
