[Nek5000-users] maketools all fails at postnek on RHEL6.4
Wed Dec 14 09:09:30 CST 2016
Hi Richard,
I find on my mac that I have to set BIGMEM="false" to get make tools to complete.
That being said, it's been awhile since I've built maketools, so I'm not certain if there
is another open issue at present.
We're getting close to a new release where everything should soon be sorted out.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Wednesday, December 14, 2016 8:44 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] maketools all fails at postnek on RHEL6.4
Using the tarball at https://github.com/Nek5000/nek5000/archive/master.tar.gz to compile locally on my RHEL6.4 server.  During maketools event, only the genmap and n2to3 tools are compiled and the make event fails out as shown below.  Is this attributed to BIGMEM=”true” in maketools, or something else?  Can anyone help?  Error and gcc/gfortran information below…
Thanks
Richard P
[user at rhel64 tools]$ gedit maketools
[user at rhel64 tools]$ ./maketools all /nfs/home/user/Nek5000
Make genmap...
make[1]: Entering directory `/home/user/Nek5000-master/tools/genmap'
gfortran -mcmodel=medium -fdefault-real-8 -o /nfs/home/user/Nek5000/genmap genmap.o byte.o
make[1]: Leaving directory `/home/user/Nek5000-master/tools/genmap'
Make n2to3...
make[1]: Entering directory `/home/user/Nek5000-master/tools/n2to3'
gfortran -mcmodel=medium   -o /nfs/home/user/Nek5000/n2to3 n2to3.o byte.o
make[1]: Leaving directory `/home/user/Nek5000-master/tools/n2to3'
Make postnek...
make[1]: Entering directory `/home/user/Nek5000-master/tools/postnek'
gfortran -mcmodel=medium -c    postnek.f
postnek.f:1977.19:
         ifbswap = if_byte_swap_test(test)
                   1
Warning: Extension: Conversion from INTEGER(4) to LOGICAL(4) at (1)
gfortran -mcmodel=medium -c    postnek2.f
gfortran -mcmodel=medium -c    postnek3.f
postnek3.f:1552.20:
      COMMON /CTMP4/ wk(LXYZ,3,3)
                    1
Warning: Named COMMON block 'ctmp4' at (1) shall be of the same size
gfortran -mcmodel=medium -c    postnek5.f
postnek5.f:711.21:
      COMMON /ccdiag/ iee,iii
                     1
Warning: Named COMMON block 'ccdiag' at (1) shall be of the same size
gfortran -mcmodel=medium -c    postnek6.f
gfortran -mcmodel=medium -c    tsort.f
gfortran -mcmodel=medium -c    postnek8.f
devices.inc:22.19:
    Included at basics.inc:168:
    Included at postnek8.f:96:
      COMMON/SCALE/XFAC ,YFAC ,XZERO ,YZERO
                   1
Warning: Named COMMON block 'scale' at (1) shall be of the same size
gfortran -mcmodel=medium -c    postnek9.f
gfortran -mcmodel=medium -c    plot.f
gfortran -mcmodel=medium -c    getfld.f
gfortran -mcmodel=medium -c    legend.f
gfortran -mcmodel=medium -c    userf.f
userf.f:1282.21:
      common /rlobjs/    x_l_objs(mopts),y_l_objs(mopts),z_l_objs(mopts)
                     1
Warning: Named COMMON block 'rlobjs' at (1) shall be of the same size
userf.f:1816.21:
      common /rlobjs/ avg(6,0:mopts-1,3)
                     1
userf.f:5261.20:
      common /ctmp1/ uavg(nxm*nelm),vavg(nxm*nelm),wavg(nxm*nelm)
                    1
Warning: Named COMMON block 'ctmp1' at (1) shall be of the same size
gfortran -mcmodel=medium -c    trap.f
gfortran -mcmodel=medium -c    animate.f
gfortran -mcmodel=medium -c    genxyz.f
gfortran -mcmodel=medium -c    screen.f
gfortran -mcmodel=medium -c    g3d.f
gfortran -mcmodel=medium -c    subs.f
gfortran -mcmodel=medium -c    xinterface.f
gfortran -mcmodel=medium -c    locglob.f
gfortran -mcmodel=medium -c    postnek5a.f
gfortran -mcmodel=medium -c    ../../nek/3rd_party/blas.f
gfortran: ../../nek/3rd_party/blas.f: No such file or directory
gfortran: no input files
make[1]: *** [blas.o] Error 1
make[1]: Leaving directory `/home/user/Nek5000-master/tools/postnek'
make: *** [all] Error 1
###########gcc and gfortran details for server##########
[user at rhel64 tools]$ rpm -qa | grep gcc
gcc-4.4.7-3.el6.x86_64
compat-gcc-34-3.4.6-19.el6.x86_64
gcc-gfortran-4.4.7-3.el6.x86_64
libgcc-4.4.7-3.el6.i686
gcc-c++-4.4.7-3.el6.x86_64
libgcc-4.4.7-3.el6.x86_64
[user at rhel64 tools]$ rpm -qa | grep gfortran
libgfortran-4.4.7-3.el6.x86_64
compat-libgfortran-41-4.1.2-39.el6.x86_64
Richard B Powell
Technical Architect II
Operations/Server Engineering
AREVA, Inc.
3315 Old Forest Road OF-60
Lynchburg, VA  24501
Phone: +1 434-832-3894
Fax: +1 434-382-3894
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161214/0c48b958/attachment.html>
