[Nek5000-users] Questions on turbChannel
Fri Dec 2 08:32:09 CST 2016
Hi Tanmoy,
thank you for taking the time to answer my questions and sharing your piece of code. It is very helpful.
Marco
On Dec 1, 2016, at 10:21 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Marco,
From my experience, I got benefitted by remodifying the eddy_visc code, by having the element loop inside the subroutine as well. i.e. in the eddy_visc() structure all the calculations of the stresses, etc. done as follows. The benefit is that with the previous snippet, my code froze, whenever the number of processors did not divide nelv, i.e. whenever nelv/np had a non-zero remainder.
The following code gets rid of this short-coming.
 subroutine eddy_visc(ediff,cs)
      include 'SIZE'
      include 'TOTAL'
      integer e
      real zn0,zn01,zn02
      integer ntot
      real cs,kappa,z0
      real ediff(lx1,ly1,lz1,lelv)
      common /dynsmg/ sij (lx1,ly1,lz1,ldim,ldim)
     $              , dg2 (lx1,ly1,lz1,lelv)
     $              , snrm(lx1,ly1,lz1,lelv)
          cstat = 0.16
t
          ntot = nx1*ny1*nz1
          call set_grid_spacing(dg2)
          if(nid.eq.0) write(6,*) 'Calculating eddy visosity',session
          do e=1,nelv
          call comp_gije(sij,vx(1,1,1,e),vy(1,1,1,e),vz(1,1,1,e),e)
          call comp_sije(sij)
          call mag_tensor_e(snrm(1,1,1,e),sij)
          call cmult(snrm(1,1,1,e),2.0,ntot)
           do k = 1,nz1
             do j = 1,ny1
              do i = 1,nx1
              ediff(i,j,k,e) = param(2) +
     &                        (cstat**2)*snrm(i,j,k,e)
              enddo
             enddo
           enddo
          enddo
      return
      end
2. ifsplit flag is the for the formulation, ifsplit = true, --> Pn Pn, and ifsplit = false, --> PnPn-2, and ifstrs formulation works only for PnPn-2 formulation (atleast in the older versions). if you use PnPn-2 formulation, ifexplvis = .true. has no effect.
3. set_ds_filt() is the routine required for the second level of filtering in dynamic Smagorinsky, .i.e. required for calculation of L_ij, M_ij. The first level of filtering is assumed to be coming from the coarse grid. I would recommend reading the mathematics of dynamic Smagorinsky model to better understand the procedure. (See http://www.scholarpedia.org/article/Turbulence:_Subgrid-Scale_Modeling)
Best Regards,
Tanmoy
On Wed, Nov 30, 2016 at 7:56 AM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Hello,
I have a few questions on the turbChannel example.
1) the ‘eddy viscosity ‘ is computed in the function eddy_visc and called in a loop over the elements of mesh 1. Inside the function eddy_visc there is the following piece of code:
     if (e.eq.nelv) then  ! planar avg and define nu_tau
         ntot = nx1*ny1*nz1*nelv
         do i=1,ntot
            cdyn = 0
            if (den(i,1).gt.0) cdyn = 0.5*num(i,1)/den(i,1)
            cdyn = 0.16*0.16 ! max(cdyn,0.)   ! AS ALTERNATIVE, could clip ediff
            ediff(i,1) = param(2)+cdyn*dg2(i,1)*snrm(i,1)
         enddo
      endif
eddy that stores the eddy viscosity is updated when the last element of mesh 1 is called. Is there any reason why it should be done in this manner?
2) I am still confused over the differences between ‘ifsplit’, ‘ifexplvis’ and ‘ifstrs’. From the archive and the documentation I understand the following (please correct me if I am wrong):
  *   ‘ifexplvis’ is set to true when the user specified the viscosity coefficient in uservp. It does not required, however, the stress formation meaning the the diffusive term in the NS equations looks like \mu(x,t) \nabla^2 \vec{u}.
  *   when ‘ifsplit’ is set to true, the viscosity is split in a explicit part and an implicit part. If this correct, how and where are defined the explicit and implicit parts?
  *   ‘ifstrs’: when set to true, ‘ifexplvis’ and ‘if split’ do not have any effect.
3) could someone shed some light on the subroutine ‘set_ds_filt’ in turbChannel.usr, please? It seems to compute some sort of filter that is then used to compute M_{i,j} and L_{i,j}
Marco
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161202/086f7ca1/attachment.html>
