[Nek5000-users] uservp MHD error
Thu Dec 1 15:28:21 CST 2016
Hi Sandeep,
The MHD implementation in Nek5000 works only for constant properties so far but it is possible to generalize it to a case with ifuservp=.true.  Let me know if you want to discuss this offline: obabko at mcs.anl.gov
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Thursday, December 01, 2016 11:31 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] uservp MHD error
Hello All,
I want to run MHD case with different magnetic diffusivities in different region of the domain.
Can we run MHD run with different magnetic diffusivities?
Assuming that udiff=magnetic diffusivity (eta), in the uservp file I added the following
      1.0000000E+00     p30 > 0 ==> properties set in uservp()
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      if (ifield.eq.1) then ! velocity
utrans = param(1)
udiff  = param(2)
      elseif (ifield.eq.ifldmhd) then ! B-field
utrans = 1.0
        R1 = sqrt(x*x+y*y);
if(R1 .le. 2.0) then
udiff= param(29)
else
udiff= 1000.0D0*param(29)
endif
 endif
      return
      end
I get an error
 done :: set initial conditions
  ERROR:  Non-positive diffusivity (    0.00    ) specified for field 2, group 0 element
Attached are the .usr, .rea and the logfile
When I set the p30=0.000 and just utrans=0.0 udiff=0.0 in the uservp, the simulation is running fine.
Thank you in advance.
Cheers,
Sandeep
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161201/34636a48/attachment.html>
