[Nek5000-users] n2to3 to create a tube
Mon Apr 11 08:57:40 CDT 2016
Hi Neks,
I am trying to use n2to3 to create an axisymmetric mesh. I have created
a 2D mesh using gmsh and it works. Now, the idea is to extrude the 2D
mesh to create a tube (circular sweep). However, n2to3 doesn't seem to
work.
In the 2d file the geometry is rectangular with SYM boundary conditions
in the x axis. Is it possible to use n2to3 to create the tube, or half
of the tube? If it is possible what are the files that I need? I suppose
that with the gemoetry_2d.rea file should be enough, shouldn't it?
I realized that:
If I set the number of planes to, let's say -10, and
  input z min:
0
  input z max:
90
I have problems with genmap
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.2
  reading .rea file data ...
  start locglob_lexico:           8       47680      381440
0.20000000000000001
  locglob:           1           1      381440
  locglob:           2         666      381440
  locglob:           3        2536      381440
  locglob:           1       51469      381440
  locglob:           2       51644      381440
  locglob:           3       51644      381440
  locglob:           1       51644      381440
      1     2     4  Matrix:  SELF!!
        1 SELF!!    11362    11361    11362    11361
        2 SELF!!     9722     9721     9729     9728
  cont: SELF!!           1   ??
  ABORT: SELF-CHK            1           5           1           0
  Try to tighten the mesh tolerance!
            0  quit
However, if I increase the number of planes, let's say -80, it seems
that genmap also works. But, when I run the numerical simulations and I
try to plot some snapshots, I cannot see anything. It seems that there
is a problem with the connectivity. What I am missing?
Thanks in advance.
Cheers
SL
