[Nek5000-users] Nek5000-users Digest, Vol 78, Issue 9
Tue Sep 1 16:36:00 CDT 2015
Hi Allen,
It looks like you have an extra line after the file name in the restart section
of your .rea file ?
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Saturday, August 29, 2015 2:51 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 78, Issue 9
Hi, Phillip
Thanks for your reply, but the dos2unix actually does not help. And I
tried a lot to fix it up, including copy existing command from other
examples .rea files to eliminate the error that might have something to
do with the "CR and LF" stuff (I know little about these line breaks).
I am in Ubuntu, should this this be due to the  failue of reading
restart parameters?he
I have attached the .rea file. It would  be greatly that you can have a
look and give some advice.
Thanks in advance.
and have a nice weekend!
from Allen
On 08/29/2015 01:00 AM, nek5000-users-request at lists.mcs.anl.gov wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>       https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>       nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>     1. restart a case got an error: Error reading initial
>        condition/drive force data (nek5000-users at lists.mcs.anl.gov)
>     2. Re: restart a case got an error: Error reading initial
> Message: 1
> Date: Fri, 28 Aug 2015 11:22:34 +0800
> From: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] restart a case got an error: Error reading
>       initial condition/drive force data
> Message-ID:
>       <mailman.6382.1440732161.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Hi, Nekers:
> I recently want to do some simulation with Nek, so I followed the
> tutorial for the eddy_uv case
> I have run the case without problem, but when I want to try the restart
> utility with the following modification instructed by the manual
>               1 PRESOLVE/RESTART OPTIONS  *****
> eddy_uv0.f00010
> affter changing for a new case name and recompile, I started the restart
> run, but the logfile gives the following error :
>    mapping elements to processors
>              2          86          86         256         256  NELV
>              0          85          85         256         256  NELV
>              1          85          85         256         256  NELV
>    RANK     0 IEG     133     134     135     136     149     150 151     152
>                       161     162     165     166     167     168 177     178
>                       179     181     182     183     184     193 194     195
>                       196     197     198     199     200     201 202     203
>                       204     205     206     207     208     209 210     211
>                       212     213     214     215     216     217 218     219
>                       220     221     222     223     224     225 226     227
>                       228     229     230     231     232     233 234     235
>                       236     237     238     239     240     241 242     243
>                       244     245     246     247     248     249 250     251
>                       252     253     254     255     256
>    element load imbalance:            1          85          86
>    done :: mapping elements to processors
>     Error reading initial condition/drive force data
>     aborting in routine rdicdf.
> EXIT: rdicdf error          1
> call exitt: dying ...
> backtrace(): obtained 9 stack frames.
> ./nek5000(print_stack_+0x18) [0x500ff8]
> ./nek5000(exitt_+0x1cc) [0x5be5ec]
> ./nek5000(exitti_+0x117) [0x5c1537]
> ./nek5000(rdicdf_+0x1e7) [0x442387]
> ./nek5000(readat_+0x35f) [0x44951f]
> ./nek5000(nek_init_+0x75) [0x41ae25]
> ./nek5000(main+0x24) [0x419d84]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f26a5be276d]
> ./nek5000() [0x419dc9]
> I have searched the post list, but I only found very vague statement of
> this
> problem:_http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-October/001560.html_
> Hope some one can give me some hint, I actually do exactly what the
> manual does, which makes me confused.
> Thanks, hope it is a minor mistake.
> from Allen
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150828/06850988/attachment-0001.html>
> Message: 2
> Date: Fri, 28 Aug 2015 10:43:10 +0200
> Subject: Re: [Nek5000-users] restart a case got an error: Error
> Message-ID:
>       <mailman.6397.1440751408.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> not sure it helps, but we had a similar problem recently when a rea file
> went trough Windows and Linux, adding CR and LF as line breaks. As far
> as I remember, using dos2unix of the file helped. Also, a tab character
> (ASCII 9) somewhere on that line gave some problems.
> Good luck,  Philipp
> On 2015-08-28 05:22, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi, Nekers:
>> eddy_uv0.f00010
>>                       252     253     254     255     256
>> this
>> from Allen
>> Nek5000-users at lists.mcs.anl.gov
> End of Nek5000-users Digest, Vol 78, Issue 9
