[Nek5000-users] low order interpolation
Sun Nov 22 12:44:10 CST 2015
Hi Tanmoy
I really don't understand why the interpolation fails.. I hope that someone
can help me because a sample low order interpolation could solve my problem.
Thanks anyway
Alessandro
2015-11-21 23:53 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
> Hi Alessandro,
> Ok. But, I was not talking about your matlab routines, but rather I was
> talking about your nek5000 postprocessing mode. I guess they are correct,
> since you got good results with Tecplot.
> But anyway, the bottom line is, nek5000 uses spectral interpolation
> routine, so even the higher order polynomials are orthogonal, so it is
> unlikely that you will have Runge's phenomenon.
> Also, I myself use hpts routines for interpolating a turbulent field
> Best Regards,
> Tanmoy
> On Fri, Nov 20, 2015 at 10:41 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Tanmoy
>> thanks for the quick answer, unfortunately I didn't commit this kinds of
>> errors. I have already used my matlab routine for other cases and it worked
>> well, so I'm pretty sure that there isn't errors. The only differences is
>> that I'm using this routine to interpolate the hpts.in points on more
>> complex grid and on a turbulent field. It seams that I have the Runge's
>> phenomenon. Is this possible with the hpts routine?
>> Sincerely
>> Alessandro
>> 2015-11-20 17:29 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
>>> Hi Alessandro,
>>> I use exactly the same procedure for my case. Just wondering, by any
>>> chance, are there any points in hpts.in which are outside bounds of the
>>> original domain, or you may resize the domain in userdat(), while
>>> postprocessing in nek5000.
>>> Best Regards,
>>> Tanmoy
>>> On Fri, Nov 20, 2015 at 6:46 AM, <nek5000-users at lists.mcs.anl.gov>
>>> wrote:
>>>> Dear neks
>>>> I don't know how Nek5000 performs the interpolation with hpts() routine
>>>> but I have some problem when I use this last. Using Matlab I built an
>>>> hpts.in file that contains the points of a structured and not constant
>>>> mesh, then using Nek in postprocessing  mode I evaluate the values of
>>>> velocity an pressure in this points. When I reshape the hpts.out in order
>>>> to visualize my domain, there are many zones that have no-sense values!. I
>>>> performed the same interpolation in tecplot and it works fine.
>>>> my question is: there's any way to perform a first order interpolation
>>>> in Nek5000?
>>>> Sincerely
>>>> Alessandro
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151122/ffe78724/attachment.html>
