[Nek5000-users] dissipation
Mon Nov 9 08:02:13 CST 2015
Thank you, Paul,
Only I think to account for all nondiagonal components I have to add
conditions to the inner loop like:
      do e=1,nelv
      do j=1,nij
      do i=1,nxyz
         sij2(i,e)=sij2(i,e)+sij(i,j,e)**2
                 if (if3d .and. j.ge.4)  sij2(i,e)=sij2(i,e)+sij(i,j,e)**2
                 if ( .not. if3d .and. j.eq.3 )
      enddo
      enddo
      enddo
Best regards, Ilias
On Mon, Nov 9, 2015 at 5:03 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Ilias,
> How about:
>       subroutine dissipation(sij2)
>       include 'SIZE'
>       include 'TOTAL'
>       real sij2(lx1*ly1*lz1,lelt)
>       common /scrns/         sij (lx1*ly1*lz1,6,lelv)
>       parameter (lr=lx1*ly1*lz1)
>       common /scruz/         ur(lr),us(lr),ut(lr)
>      $                     , vr(lr),vs(lr),vt(lr)
>      $                     , wr(lr),ws(lr),wt(lr)
>       integer e
>       nij = 3+3*(ndim-2)
>       call comp_sij(sij,nij,vx,vy,vz,ur,us,ut,vr,vs,vt,wr,ws,wt)
>       nxyz = nx1*ny1*nz1
>       n    = nx1*ny1*nz1*nelv
>       call rzero(sij2,n)
>       do e=1,nelv
>       do j=1,nij
>       do i=1,nxyz
>       enddo
>       enddo
>       enddo
>       return
>       end
> This should function correctly.
> Best, Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Sunday, November 08, 2015 4:37 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] dissipation
> Dear neks,
> I am trying to user comp_sij to compute dissipation in every point of the
> domain.
> The data storage is organised according to
>       real sij(lx1*ly1*lz1,nij,lelv)
> so the index of a component of tensor
> precedes number of element, and
> the is no continuous block of lx1*ly1*lz1,lelv points for an element of
> tensor.
> And so, the global functions like col3 of glsc can not be applied.
> At least I don't understand how.
> To bypass this, I copied comp_sij to my usr file and changed the order of
> last indices in sij
>       real sij(lx1*ly1*lz1,lelv,nij)
> After that I use the followng code to compute viscous dissipation
>        nij = 3
>        if (if3d) nij=6
>       call il_comp_sij(sij,nij,vx,vy,vz,ur,us,ut,vr,vs,vt,wr,ws,wt)
>       call rzero(il_dissip,lv)
>       do j=1,nij
>       call col3(sij2,sij(1,1,1,1,j),sij(1,1,1,1,j),nxyz)
>       il_dissip=il_dissip+sij2
>        if (if3d .and. j.ge.4) then
>        end if
>       if ( .not. if3d .and. j.eq.3 ) then
>       end if
>       il_dissip=2*param(2)*il_dissip
>       enddo
> Is is a fair way to compute dissipation?
> Thanks, Ilias
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151109/e2c6cbaf/attachment.html>
