[Nek5000-users] Newest version of svn repo (1088) does not compile
Sun Nov 8 12:06:07 CST 2015
Hi Nek,
i hope someone can help me to understand. I simulate a ribbed surface
(triangulare riblets).
When i use genmap command i have the following error:
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.0001
  reading .rea file data ...
  start locglob_lexico:           8     1428840    11430720
1.00000000000000005E-004
  locglob:           1           1    11430720
  locglob:           2          64    11430720
  locglob:           3       14720    11430720
  locglob:           1      942080    11430720
  locglob:           2      942080    11430720
  locglob:           3      942080    11430720
717319     2     4  Matrix:  SELF!!
        1 SELF!!    14465    14465    14466    14466
        2 SELF!!    29185    29185    29186    29186
  cont: SELF!!      717319   ??
  ABORT: SELF-CHK            1           3      717319           0
  Try to tighten the mesh tolerance!
            0  quit
STOP
Obviously i tried more different values for mesh tolerance.
So my question is: there is or there are particular conditions to choose
this value? Or depending in which criterion i could choose this value?
On 06/11/2015 21:28, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Janet,
> My fault... we're working on it on this end.
> Did you update your "makenek" from the repo?
> Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov
> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Friday, November 06, 2015 1:45 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] Newest version of svn repo (1088) does not
> compile
> Just an FYI for those of you who tend to do svn updates fairly often
> for nek5000:
> The svn version 1088 does not compile correctly. I found if I reverted
> to version 1078 it did compile correctly.
> Janet
> Janet Scheel
> Associate Professor of Physics
> Occidental College
> 1600 Campus Road, M21
> Los Angeles, CA 90041
> (323) 259-2777
> jscheel at oxy.edu <mailto:jscheel at oxy.edu>
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151108/14da0320/attachment.html>
