[Nek5000-users] read temperature
Fri May 22 10:11:10 CDT 2015
Hi Mirko,
Did you check whether you temperature filed is dumped into the field file by checking whether there is a letter 'T' in the header of
head BF_Channel0.f00001|strings|head -1
If not than you could either turn in the temperature dump by modifying turbChannel.rea's line
  F      TEMPERATURE
to
  T      TEMPERATURE
or inserting the line in userchk() before your call to outpost()
      ifto = .true.
(which is the output specification)
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, May 22, 2015 8:21 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] read temperature
Hi Neks
I'm trying to save some variables  in this way:
call outpost(u_bf,v_bf,w_bf,du_bfdy,vis_t,'BF_')
after a simulation.
then i would to read the aforementioned variables:
 ifto = .true.
 b_flow = 'BF_Channel0.f00001'
 call load_fld(b_flow)
but it seems to read in the correct way just the first 4 variables:
xyz min     0.0000      -1.0000       0.0000
uvwpt min   0.0000      0.96051E-20  0.96051E-20  -9.6269      0.96051E-20
PS min      0.0000      0.99000E+22
xyz max     12.560       1.0000       6.2800
uvwpt max  0.97894      0.80000E-19  0.80000E-19   9.6744      0.80000E-19
PS max      0.0000     -0.99000E+22
because the tmin e tmax are not zero in BF_Channel0.00001!
Could someone help me?
Thanks
Mr. Mirko Farano
Ph.D. student at Politecnico di Bari
Tel.: +39-0883529289 / +39-0805963462
Mob.: +39-3202342719
Department of Mechanics Mathematics and Management -
Fluid Machinery and Energy Systems
Via Re David, 200 - 70125 BARI (Italy)
mirko.farano at poliba.it<mailto:mirko.farano at poliba.it>
In joint supervision with the
Ecole Nationale Supérieure d'Arts et Métiers de Paris - Paristech
Tel.: +33-144246436
Mob.: +33-789822134
Dynfluid Laboratory
151 Boulevard de l'Hôpital - 75013 Paris (France)
mirko.farano at ensam.eu<mailto:mirko.farano at ensam.eu>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150522/56582341/attachment.html>
