[Nek5000-users] userf Questions
Sun Jul 26 23:08:48 CDT 2015
Hi All,
Hate to be so long winded, but I'm seeing problems with my code and was
wondering if anyone could help...
I'm modeling a wind turbine using a modified actuator line method, where
I describe the blades (3) as a set of rotating rectangular outlines,
advanced in space at each time step.  I'm selecting GLL points which
fall within my outlines, reading in the velocities, calculating the body
forces, then assigning them back to ffx,ffy,ffz.  This generates a
downstream flowfield and wake in NEK...  Looking at rough results, they
compare (velocity and vorticity plots and isosurfaces) favorably with
other work. However, during some recent debugging to add some features
to my code, I noticed that when I repeatedly ran short runs and printed
results at the same time step, my point selections for the 3 blades
varied with each run, even though I made no other changes to the code or
any runtime parameters.  A chunk of my point selection for a given area
of blade passage looks like:
---------------------F77 Code In
userf-----------------------------------------------------------------------------------
C     Test for location in Quadrant...
C
       if (thetacalc .GE. (pi/2.0 - epsim2)) then
C
C     Close to Vertical Axis...
C
C     Sin+ ...
C
       xlo = centerx + (rhubm*SIN(thetacalc))
       xhi = centerx + (bladeradius*SIN(thetacalc))
       ymax=centery+(1./SIN(thetacalc))*(chordbig/2.0)
       ymin=centery-(1./SIN(thetacalc))*(chordbig/2.0)
       if (((x.GE.xlo).AND.(x.LE.xhi)).AND.
      &     ((y.GE.ymin).AND.(y.LE.ymax))) then
C
C     Calculate forces...
C
       radm = SQRT((x-centerx)**2.0 + (y-centery)**2.0)
       vthetam = SQRT(ux**2.0 + uy**2.0)
       psim = ATAN(uz/(avelm*radm + vthetam))   ....
-----------------------F77 Code
Continues------------------------------------------------------
The xlo,xhi,ymax,ymin values are calculated based on the rotational
location of the blade, which changes at each time step, and defines an
outline of the blade.  Then the IF statements test the x,y point (z-axis
location has already been tested) to be within this blade outline, and
when a point "HITS" any one of these outlines for the 3 blades, it
calculates the forces, prints a diagnostic line, etc... A typical print
clip, which only runs at one time step I define and prints for the "Hit"
point, is:
C     Print output
C
       if(istep.eq.pstepm)then
       WRITE(4,1000)'Q1V',x,y,z,ux,uy,uz,psim,ffx,ffy,ffz
       endif
This tells me the quadrant and general area of the point; because of
geometric issues, I have separate selection (and associated print)
routines for each Cartesian quadrant which are all tested in turn...
So...  My problem is if I run this code over and over, and print at say
istep=10, the code shows a different number of points selected for each
of the 3 blades, on each run!  Oddly, there are repeated patterns, and
the total is always the same; for this particular setup at this istep,
it was 204 points for all 3 blades.  An example of the differences is:
                     Blade 1                    Blade
2                    Blade 3
Run 1          76 125                           3
Run 2         32 110                           62
Run 3          78 79                            47
I've tried a bunch of things to fix it, including going back to a
previous version which had no SAVE statements in it (had more manual
parameter input); compiling between each run, etc...
All my code is within userf.  I'm running this in MPI mode on a large
SMP server/workstation; compiled with gfortran.  I've run this out to
10000 cycles with repeated runs and have always gotten qualitatively
identical results.  I ran into this problem when I was debugging a new
version which added a bunch of automated features I've been working on.
But, when going back to previous versions and performing repeated short
runs, I discovered that it did it there too...
Am I missing something here with MPI and my selection code not working
correctly because of the way userf is called?  My understanding of the
code is that at each time step, all the GLL points and elements are
cycled through with a call to userf for each point; the forces are
brought back in as ffx,ffy,ffz.  If I look qualitatively at a typical
run through time, you can see each blade rotating step-by-step, and see
the physical outline and edges of the blades.  It makes me think that my
selection code (which I've debugged and checked out a lot in the past)
is basically correct; just don't know why it would select different
points with those IF statements on repeated runs.  Now, I can see some
roundoff-resolution issues where it might vary one or two points between
runs, but here the differences are huge.
Thanks for listening ;-)
Murph
Murphy Leo O'Dea
PhD Student
Mechanical Engineering
Oakland University
mlodea at oakland.edu
