[Nek5000-users] Error in Hmholtz solving
Thu Jan 29 13:44:28 CST 2015
Hi Paul,
Many thanks for your help. Yes, my simulation is scaled in convective time units. As you pointed out, the solutions are well converged.
I just have a question about the projection and dealiasing. I'm still not sure when I need to use them in my simulations. Say I'm doing simulations without any models, do I need to turn on projection and dealiasing? I actually don't know how they will affect the solutions, would projection or dealiasing (off, old or new?) change the solutions? It would be great if you could briefly explain this bit to me.
Thank you very much.
Best regards,
Tony
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users-request at lists.mcs.anl.gov <nek5000-users-request at lists.mcs.anl.gov>
Sent: 29 January 2015 18:00
To: nek5000-users at lists.mcs.anl.gov
Subject: Nek5000-users Digest, Vol 71, Issue 16
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. Error in Hmholtz solving (nek5000-users at lists.mcs.anl.gov)
   2. Re: Error in Hmholtz solving (nek5000-users at lists.mcs.anl.gov)
Message: 1
Date: Thu, 29 Jan 2015 15:50:43 +0000
To: "nek5000-users at lists.mcs.anl.gov"
        <nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] Error in Hmholtz solving
Message-ID:
        <mailman.14256.1422546648.3424.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="iso-8859-1"
Dear Neks,
I'm getting the error message of '**ERROR**: Failed in HMHOLTZ: ' when running my simulation. I've checked the subroutine 'cggo' in hmholtz.f where the error message is printed. I understand that when the tolerance is not satisfied, the code would output this error message. But what I'm wondering is why the maximum iteration number is only 100. In the subroutine 'cggo', niter is equal to min(maxit,maxcg) where maxit=200 and maxcg=900. I can't see other places where maxit is restricted to only 100. So why the maximum iteration number is 100 when solving the Hmholtz equation?
Also, is it right that if I increase the maximum number of iterations to certain point where the tolerance is satisfied, I won't get the error message?
Hope anyone can help me on this. Thank you very much in advance.
Best regards,
Tony
Example of the error message:
Step     52, t= 2.5600000E+01, DT= 5.0000000E-02, C=  2.689 5.6747E+02 1.0237E+01
 Solving for fluid T T T
       52 PRES gmres:   29  9.7057E-07  1.0000E-06  1.5219E-03  1.0926E+00  2.1480E+00    F
         52    Hmholtz VELX:     99   8.5954E-10   6.0898E-03   1.0000E-09
    52   100 **ERROR**: Failed in HMHOLTZ: VELY   1.7088E-09   2.5049E-02   1.0000E-09
    52   100 **ERROR**: Failed in HMHOLTZ: VELZ   1.4665E-09   2.5165E-02   1.0000E-09
               L1/L2 DIV(V)    :   2.7573E-18   9.1661E-04
               L1/L2 QTL       :   0.0000E+00   0.0000E+00
               L1/L2 DIV(V)-QTL:   2.7573E-18   9.1661E-04
         52   2.5600E+01  1.0094E+01 Fluid done
Step     53, t= 2.5650000E+01, DT= 5.0000000E-02, C=  2.697 5.7766E+02 1.0186E+01
       53 PRES gmres:   28  9.6076E-07  1.0000E-06  1.1322E-03  1.0558E+00  2.0542E+00    F
         53    Hmholtz VELX:     98   9.4891E-10   5.8783E-03   1.0000E-09
    53   100 **ERROR**: Failed in HMHOLTZ: VELY   1.6450E-09   2.4941E-02   1.0000E-09
    53   100 **ERROR**: Failed in HMHOLTZ: VELZ   1.4160E-09   2.5049E-02   1.0000E-09
               L1/L2 DIV(V)    :   2.4695E-18   1.0845E-03
               L1/L2 DIV(V)-QTL:   2.4695E-18   1.0845E-03
         53   2.5650E+01  9.9794E+00 Fluid done
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150129/e21e4255/attachment-0001.html>
Message: 2
Date: Thu, 29 Jan 2015 16:00:45 +0000
Subject: Re: [Nek5000-users] Error in Hmholtz solving
Message-ID:
        <mailman.14259.1422547425.3424.nek5000-users at lists.mcs.anl.gov>
Tony,
It looks like your Helmholtz tolerance is too tight.
If your problem is scaled in convective time units with characteristic length scale 1, timescale 1, and visc ~ 1/Re,
then typical Helmholtz tolerances are around 1.e-7.
You might also try turning on projection ---
set p93=20 (and lmxprev=20 in SIZE), p94=5 and p95=5 in the rea file.
No guarantees at this point because there seems to be something flaky in the projection routines
these days under certain runtime combinations (e.g., I think splitting + heat transfer +
velocity projection does not work)...  It's on my todo list to clean these up.
Note that your helmholtz solves are pretty well converged... residual is 1.7e-9, etc.
Projection should easily put you over the top
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Thursday, January 29, 2015 9:50 AM
Dear Neks,
Best regards,
Tony
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150129/b14c95c6/attachment-0001.html>
Nek5000-users at lists.mcs.anl.gov
End of Nek5000-users Digest, Vol 71, Issue 16
