[Nek5000-users] Compilation of nek5000 in ubuntu
Thu Jan 15 06:15:51 CST 2015
Hi Qiong,
Thanks for your help. By checking mpif77, the location of mpif77 is:
/home/szhang009/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/bin/mpif77
which is in the OpenFOAM file. So I copy and paste it to makenek but it does not work where it still says mpif77 compiler is non-functional. I also checked the dir /usr/bin and there also exists mpif77. So I change makenek to this address but it still returns the same error.
Thanks & Regards,
Simon
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, 15 January, 2015 6:33 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Compilation of nek5000 in ubuntu
Hi, Simon
     I met the similar problem as you before. What I did is :
    1) check which and where mpif77 have been installed
         sth at sth:~$ which mpif77
         /usr/.../mpif77
     2) change this path to the makenek
         F77="/usr/.../mpif77"
     also you can include this path to you profile then you don't need to change makenek every time.
     hope it helps
Qiong
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150115/4cc7b883/attachment.html>
