[Nek5000-users] question about efficient running nek5000
Wed Feb 4 13:09:37 CST 2015
I ran nek5000 on 1024 CPUs which is divided to 128 nodes and 8 cores per
node, and the same problem on 1200 CPUs with 100 nodes and 12 cores per
node, however in second case I got lower efficiency, simulation goes slower
about 5~8 percent!! I ran both cases on the same cluster!! Does anyone have
any idea why I do not get higher efficiency with the higher number of CPUs
but less nodes involved!? Could memory be a limitation here or since
numbers in first case are power of 2, it is more efficient!?
Ami
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150204/3761a796/attachment.html>
