[Nek5000-users] MOAB Cubit problem
Wed Apr 29 13:23:23 CDT 2015
Hamid,
It is possible that the file formats are quite different between Cubit
and Trelis. We have not tested with the Trelis versions so far and do
plan to acquire a license to make these conversions possible.
Meanwhile, if you want to use Exodus or any other format that MOAB can
understand directly, that would simplify your workflow. We will keep
you updated about the progress, if you're interested.
Vijay
On Wed, Apr 29, 2015 at 11:47 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I use Trelis (V 15) to generate mesh. However, when I try to use mbconvert
> to generate h5m file, it says
> [0]MOAB ERROR: --------------------- Error Message
> [0]MOAB ERROR: This doesn't appear to be a .cub file!
> [0]MOAB ERROR: load_file() line 310 in src/io/Tqdcfr.cpp
> [0]MOAB ERROR: Failed to load file after trying all possible readers!
> [0]MOAB ERROR: serial_load_file() line 634 in src/Core.cpp
> [0]MOAB ERROR: load_file() line 523 in src/Core.cpp
> Failed to load "/home/hamid/nek5_svn/moab_conjht/cubit01.cub".
> Error code: MB_FAILURE (16)
> Error message: Failed to load file after trying all possible readers
> I have downloaded other cub files from repository and mbconvert works fine
> on them.
> However opening and saving these files with Trelis causes same problem.
> I think the file format in Trelis is different than Cubit. Is it true? if
> yes what is the solution?
> Hamid
> Nek5000-users mailing list
