[Nek5000-users] Submitting Job Nek Enabled Moab
Wed Oct 29 10:37:41 CDT 2014
Hi Again,
I just wanted to update that although I have added the szip library to the LD_LIBRARY_PATH I still receive the same error:
mv: cannot stat `pipe.log.12': No such file or directory
mv: cannot stat `pipe.sch': No such file or directory
./nek5000: error while loading shared libraries: libintlc.so.5: failed to map segment from shared object: Cannot allocate memory
Should I consider loading zlib etc in the same way or is this something else?
Regards, Friedrich.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20141029/4f19e74b/attachment.html>
