[Nek5000-users] Recycling BC
Thu Nov 13 08:52:23 CST 2014
Dear Neks,
I am using the turbJet example to set up my own recycling boundary case.
As far as I understand the velocity that is passing through stack 8 (element 8) in the turbJet example should then be recycled back to the inlet.
However when I plot the instantaneous velocity profiles for these two points they are non-identical. Is this deliberately so, I presume it should behave like a periodic boundary condition, or have I missed the point?
Thank you for your time, Friedrich.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20141113/be60dcd8/attachment.html>
