[Nek5000-users] About the iobj in the drag calculation
Thu May 29 05:54:10 CDT 2014
Hi Xianbei,
You can define more objects by picking your
own surface discriminators (which will
be dependent on your particular application).
If you need more than 4 objects, you can increase maxobj
in SIZE.
Typically, dragx(0) would be the sum of the drag on all
the objects --- this is sometimes useful.
If you have (say) a 4-sided channel, you can just define
one object instead of 4, and set it to be the collection
of all faces for which cbc(f,e,1)='W  '.
Paul
On Thu, 29 May 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,all:
     I read Paul's reply in this mail https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2014-May/002756.html
     And got to know something about objects. As you say, the object is a collection of faces, here , I have a question about the iboj, how could I know which face it represent with iboj? As in turbChannel.usr,
      dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2))
      I think it means to do the time-average of the average dragx on planey1 and planey2, as
  indicates, while how to calculate the dragx on the planex1, planex2, planez1 and planez2? for the maxobj in this example is only 4 and dragx is defined as
      dragx(0:maxobj)
Thank you
Xianbei
