[Nek5000-users] Questions in AXHELM and WLAPLACIAN
Thu May 29 05:33:24 CDT 2014
Dear nek5000 team,
Could you help me with the 2 questions below? Thank you very much !
1)
Concerning the routine “axhelm” in hmholtz.f. If I am right, one possibility of this routine can be the discretisation of the diffusion operator. However it is not clear to me if axhelm performs:
a) vdiff  x   Laplacian(phi)
or
b) grad ( vdiff x grad (phi) )
phi being the variable solved for (T or PS for example).
So, is it actually a) or b) ?
2)
In the routine wlaplacian in navier1.f, I am not sure to understand the consequence of the line:
call sub2 (out,wrk,ntot)
after the lines:
call bcneusc(out,1)
call axhelm(wrk,a,diff,h2,imesh,1)
If I am right, this will change the sign in front of the diffusion operator, right?
Because in makeq.f, I am not sure that the line
call add2(bq(1,1,1,1,ifield-1),w1,ntot)
will actually assemble the RHS of the transport equation :  - (vtrans) x  U grad (phi)  +  grad ( vdiff x grad (phi) )
Thank you for your help !
Best regards,
Emmanuel
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140529/a90e812c/attachment.html>
