[Nek5000-users] Problem w/ outflow and DIV(V)
Wed May 28 19:39:00 CDT 2014
Hi Mosen,
I'm assuming that gravity points in the -z direction for you?
If so, what is the value of the unit normal vector on your outflow plane?
Is it (0,0,-1), i.e., in the negative z direction?  Or something else?
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Wednesday, May 28, 2014 6:48 PM
To: Nek 5000
Subject: [Nek5000-users] Problem w/ outflow and DIV(V)
Hello all,
I am working on a problem consisting of an axially-horizontal
cylindrical tank with an inlet (an opening) at its top and a
connected pipe to its bottom as an outlet. The boundary conditions
are set accordingly, i.e., inflow and outflow, respectively. Gravity
is in vertical direction. I need to use Pn-Pn formulation as I use
Moab for this problem.
Assuming a steady-state condition with a full tank, this problem can
be solved using single-phase NS solver. However, I noticed that there
is large mass conservation error, as indicated by warning of "DIV(V)-
QTL too large", when I run the case with a zero initial velocity
field. I expected that this error decreased as the time evolved, but,
it increased. Also a back-flow gradually starts to grow at the
outflow boundary as well.
I thought that this problem may be solved if I start from a realistic
initial condition, however, it is not trivial for this problem. I am
also skeptical about the zero pressure BC which is imposed at the
outflow in Pn-Pn formulation.  The other solution might be having an
inlet (but outward) velocity at the outlet.
So I wondered if anyone can give me a hint on this problem or the
solutions proposed.
Mohsen
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
