[Nek5000-users] Implementing magnetic boundary conditions
Fri May 9 13:24:56 CDT 2014
Hi Jan,
Excellent questions and we have thought of implementing MHD in a two-domain manner similar to conjugate heat transfer approach but we are currently tied up with other projects.
Let us discuss your questions offline -- my email is obabko at mcs.anl.gov
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, May 09, 2014 8:25 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users]   Implementing magnetic boundary conditions
Hi everyone,
I am currently trying to implement the quasi vacuum boundary conditions (n x B=0) for an ellipsoidal shell. My understanding from earlier threads is that I can only set Bx=By=dBz/dz=0 via the string ‚ddn‘ , restricting me to boundaries orthogonal to the cartesian axis. Has anyone tried some workarounds to this problem? And are the same restrictions applying to the flux boundary conditions of the add. scalars? If not, it might be possible to use 3 additional passive scalars to model the magnetic field (instead of the standard implementation).  Or, as another idea, is it possible to use something like the conjugate heat transfer implementation for the magnetic field: Having some larger Elements on the outside with u=0, where only laplace B=0 is solved.
My current approach, which is not working yet, is to transfer the boundary conditions to Dirichlet conditions via an interpolation algorithm, but this seems a bit dubious to me, both from a numerical and a physical perspective.
Any suggestions would be appreciated.
Best regards,
Jan
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
