[Nek5000-users] Emergency Exit error
Fri Mar 28 05:13:14 CDT 2014
Hello Neks,
I launched a simulation on cluster, but it crashes with the error
            1  Emergency exit:           9    time =
8.00000000000000017E-003
   Latest solution and data are dumped for post-processing.
   *** STOP ***
            2  Emergency exit:           9    time =
   *** STOP ***
could some please help me out with fixing this. I have attached the
logfile.
Thank you,
Kamal
|      _   __ ______ __ __  ______  ____    ____    ____   |
|     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
|    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
| Version:  1.0rc1 / SVN  r1016                            |
| Web:      http://nek5000.mcs.anl.gov                     |
 Number of processors:         135
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
  Beginning session:
  /home/2014012/jpeixi01/neksamples/expansion/expansion.rea
 timer accuracy:   9.5367432E-08 sec
 read .rea file
 nelgt/nelgv/lelt:       25760       25760         200
 lx1  /lx2  /lx3 :           5           5           5
 mapping elements to processors
 RANK     0 IEG   11201   11203   11217   11254   11292   11300   11337   11338
                  11340   11369   11373   11401   11409   11410   11411   11412
                  11413   11414   11415   11416   11417   11418   11419   11420
                  11421   11422   11423   11424   11425   11426   11427   11428
                  11462   11500   11508   11509   11541   11545   11546   11548
                  11565   11573   11577   11581   11609   11613   11617   11618
                  11619   11620   11621   11623   11624   11625   11626   11629
                  11630   11631   11632   11633   11634   11635   11636   11669
                  11670   11707   11708   11717   11749   11753   11755   11756
                  11773   11781   11785   11789   11813   11817   11821   11825
                  11826   11827   11828   11829   11832   11833   11834   11837
                  11838   11839   11840   11841   11842   11844   11877   11878
                  11915   11916   11925   11957   11961   11962   11964   11981
                  11989   11993   12021   12025   12029   12033   12034   12035
                  12036   12045   12046   12047   12048   12049   12052   12085
                  12086   12133   12165   12169   12170   12172   12181   12189
                  12197   12201   12205   12229   12233   12237   12241   12242
                  12243   12244   12253   12254   12255   12257   12293   12294
                  12341   12373   12377   12378   12380   12389   12397   12405
                  12409   12413   12437   12441   12449   12450   12451   12452
                  12463   12501   12502   12529   12581   12585   12586   12587
                  12588   12597   12605   12613   12617   12621   12657   12659
                  12660   12671   12709   12710   12737   12793   12794   12795
                  12796   12805   12813   12821   12825   12829
 element load imbalance:            1         190         191
 done :: mapping elements to processors
           0  objects found
 done :: read .rea file    2.9936     sec
 Reset the target Courant number to .5
 setup mesh topology
   Right-handed check complete for   25760 elements. OK.
   setvert3d:   5      973641     1669161      973641      973641
 call usrsetvert
 done :: usrsetvert
gs_setup: 289964 unique labels shared
   pairwise times (avg, min, max): 8.12765e-05 6.88791e-05 9.08136e-05
   crystal router                : 0.000431342 0.000419593 0.000444794
   used all_to_all method: pairwise
   handle bytes (avg, min, max): 287033 249460 309884
   buffer bytes (avg, min, max): 82103.5 47360 106528
   setupds time 5.7415E-02 seconds   0  5      973641       25760
           8  max multiplicity
 done :: setup mesh topology
 call usrdat
 done :: usrdat
 generate geometry data
 vol_t,vol_v:   1916.3691909032111        1916.3691909032111
 done :: generate geometry data
 call usrdat2
 done :: usrdat2
 regenerate geometry data           1
 vol_t,vol_v:   479.09229772580278        479.09229772580278
 done :: regenerate geometry data           1
 verify mesh topology
  -1.0000000000000000        1.0000000000000000       Xrange
  -1.0000000000000000        1.0000000000000000       Yrange
  -10.000000000000000        150.00000000000000       Zrange
 done :: verify mesh topology
 118   Parameters from file:/home/2014012/jpeixi01/neksamples/expansion/expansion.rea
   1      1.00000     p001 DENSITY
   2    -2000.000     p002 VISCOS
   8      1.00000     p008 CONDUCT
  11     1000.000     p011 NSTEPS
  12    -0.100000E-02 p012 DT
  15      100.0000    p015 IOSTEP
  21     0.100000E-05 p021 DIVERGENCE
  22     0.100000E-06 p022 HELMHOLTZ
  24     0.100000E-01 p024 TOLREL
  25     0.100000E-01 p025 TOLABS
  26      1.00000     p026 COURANT/NTAU
  27      2.00000     p027 TORDER
  28      0.00000     p028 TORDER: mesh velocity (0: p28=p27)
  65      1.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
  66      6.00000     p066 output : <0=ascii, else binary
  67      6.00000     p067 restart: <0=ascii, else binary
  93      20.0000     p093 Number of previous pressure solns saved
  94      3.00000     p094 start projecting velocity after p94 step
  95      5.00000     p095 start projecting pressure after p95 step
  99      0.00000     p099 dealiasing: <0--> off/3--> old/4--> new
 103     0.100000E-01 p103 weight of stabilizing filter (.01)
 IFTRAN   = T
 IFFLOW   = T
 IFHEAT   = F
 IFSPLIT  = T
 IFLOMACH = F
 IFUSERVP = F
 IFUSERMV = F
 IFSTRS   = F
 IFCHAR   = F
 IFCYCLIC = F
 IFAXIS   = F
 IFMVBD   = F
 IFMELT   = F
 IFMODEL  = F
 IFKEPS   = F
 IFMOAB   = F
 IFNEKNEK = F
 IFSYNC   = T
 IFVCOR   = F
 IFINTQ   = F
 IFCWUZ   = F
 IFSWALL  = F
 IFGEOM   = F
 IFSURT   = F
 IFWCNO   = F
 IFTMSH for field           1    =  F
 IFADVC for field           1    =  T
 IFNONL for field           1    =  F
 Dealiasing enabled, lxd=           8
 Estimated eigenvalues
 EIGAA =    1.6450625773221985
 EIGGA =    6170411880.1129513
 EIGAE =   3.85531421917553079E-004
 EIGAS =   1.95297242402937292E-005
 EIGGE =    6170411880.1129513
 EIGGS =    2.0000000000000000
  E-solver strategy:  0 itr
 mg_nx:           1           2           4
 mg_ny:           1           2           4
 mg_nz:           1           2           4
 call usrsetvert
 done :: usrsetvert
gs_setup: 16049 unique labels shared
   pairwise times (avg, min, max): 2.49049e-05 2.21014e-05 2.77042e-05
   crystal router                : 5.43299e-05 5.24998e-05 5.58138e-05
   all reduce                    : 0.000609596 0.000607705 0.000614309
   handle bytes (avg, min, max): 23388.4 19756 25868
   buffer bytes (avg, min, max): 7389.16 3680 10112
   setupds time 1.2838E-02 seconds   1  2       27147       25760
   setvert3d:   4      501087      707167      501087      501087
 call usrsetvert
 done :: usrsetvert
gs_setup: 160989 unique labels shared
   pairwise times (avg, min, max): 5.01423e-05 4.22955e-05 5.88179e-05
   crystal router                : 0.000263465 0.000255799 0.000272799
   handle bytes (avg, min, max): 165421 143180 179100
   buffer bytes (avg, min, max): 48269.5 27328 62976
   setupds time 2.9434E-02 seconds   2  4      501087       25760
   setvert3d:   3      185589      211349      185589      185589
 call usrsetvert
 done :: usrsetvert
gs_setup: 69684 unique labels shared
   pairwise times (avg, min, max): 3.20203e-05 2.79903e-05 3.60012e-05
   crystal router                : 0.000139336 0.000135708 0.00014441
   all reduce                    : 0.00236143 0.00234699 0.0023746
   handle bytes (avg, min, max): 77539.4 66612 84508
   buffer bytes (avg, min, max): 23364.7 12768 30912
   setupds time 4.6377E-02 seconds   3  3      185589       25760
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 7.52006e-05 6.23941e-05 8.84056e-05
   crystal router                : 0.000432244 0.000421095 0.000446296
   setupds time 4.9351E-02 seconds   4  5      973641       25760
 NOTE: All elements deformed , param(59) ^=0
 h1_mg_nx:           1           2           4
 h1_mg_ny:           1           2           4
 h1_mg_nz:           1           2           4
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 2.42703e-05 2.10047e-05 2.7895e-05
   crystal router                : 4.95451e-05 4.82082e-05 5.20945e-05
   all reduce                    : 0.000627152 0.00062499 0.000628805
   setupds time 1.2090E-02 seconds   5  2       27147       25760
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 4.90579e-05 4.06027e-05 5.79119e-05
   crystal router                : 0.000273124 0.000265503 0.000281787
   setupds time 2.9640E-02 seconds   6  4      501087       25760
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 3.21588e-05 2.67982e-05 3.56913e-05
   crystal router                : 0.000132228 0.000128198 0.000136113
   all reduce                    : 0.00225109 0.0022393 0.0022593
   setupds time 4.4819E-02 seconds   7  3      185589       25760
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 7.4347e-05 6.1202e-05 8.7595e-05
   crystal router                : 0.000428043 0.000416994 0.000440192
   setupds time 4.9358E-02 seconds   8  5      973641       25760
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 7.4325e-05 5.95808e-05 8.74996e-05
   crystal router                : 0.00042732 0.000415993 0.000440502
   setupds time 4.9174E-02 seconds   9  5      973641       25760
   setvert3d:   7     2389917     5609917     2389917     2389917
 call usrsetvert
 done :: usrsetvert
gs_setup: 660924 unique labels shared
   pairwise times (avg, min, max): 0.00013483 0.000116491 0.000150299
   crystal router                : 0.000920938 0.000892711 0.000946999
   handle bytes (avg, min, max): 631448 551156 680380
   buffer bytes (avg, min, max): 176559 103840 229920
   setupds time 1.1020E-01 seconds  10  7     2389917       25760
 setup h1 coarse grid, nx_crs=           2
 call usrsetvert
 done :: usrsetvert
   pairwise times (avg, min, max): 2.6669e-05 2.19107e-05 3.05891e-05
   crystal router                : 5.02219e-05 4.90904e-05 5.14984e-05
   all reduce                    : 0.000600592 0.000597286 0.000603104
 done :: setup h1 coarse grid    1.3920550346374512       sec
 call usrdat3
 done :: usrdat3
 set initial conditions
 nekuic (1) for ifld            1
 call nekuic for vel
 xyz min    -1.0000      -1.0000      -10.000
 uvwpt min -0.11602E-19 -0.11602E-19  -6.0000     -0.11602E-19 -0.11602E-19
 PS min      0.0000       0.0000      0.99000E+22
 xyz max     1.0000       1.0000       150.00
 uvwpt max  0.80000E-19  0.80000E-19   2.0000      0.80000E-19  0.80000E-19
 PS max      0.0000       0.0000     -0.99000E+22
 done :: set initial conditions
 call userchk
        0  0.0000E+00  7.8540E-01  1.0000E+00  2.0000E+00 ubar
       0  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00      1dragx
       0  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00      1dragy
       0  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00      1dragz
       0  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00      1torqx
       0  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00      1torqy
       0  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00  0.00000000000E+00      1torqz
 done :: userchk
gridpoints unique/tot:       1669161      3220000
  dofs:              1631271              1664487
 Initialization successfully completed    5.1737     sec
Starting time loop ...
     DT/DTCFL/DTFS/DTINIT   0.100E-02   0.303-316   0.494-323   0.100E-02
 CFL, Ctarg!   214.75997258291918       0.50000000000000000
Step      1, t= 1.0000000E-03, DT= 1.0000000E-03, C=214.760 0.0000E+00 0.0000E+00
 Solving for fluid T T T
  9.99999999999999955E-008  p22            1           1
 New CG1-tolerance (RINIT*epsm) =   1.08207767419886776E-006  9.99999999999999955E-007
    1 1.00000E-06 3.22803E+02 1.75695E+03 1.83728E-01       1 Divergence
    2 1.00000E-06 1.57519E+02 1.75695E+03 8.96545E-02       1 Divergence
    3 1.00000E-06 6.28753E+01 1.75695E+03 3.57865E-02       1 Divergence
    4 1.00000E-06 3.25760E+01 1.75695E+03 1.85412E-02       1 Divergence
    5 1.00000E-06 1.88748E+01 1.75695E+03 1.07429E-02       1 Divergence
    6 1.00000E-06 1.16254E+01 1.75695E+03 6.61678E-03       1 Divergence
    7 1.00000E-06 5.93552E+00 1.75695E+03 3.37830E-03       1 Divergence
    8 1.00000E-06 3.15576E+00 1.75695E+03 1.79616E-03       1 Divergence
    9 1.00000E-06 1.95012E+00 1.75695E+03 1.10994E-03       1 Divergence
   10 1.00000E-06 1.12041E+00 1.75695E+03 6.37698E-04       1 Divergence
   11 1.00000E-06 8.50816E-01 1.75695E+03 4.84256E-04       1 Divergence
   12 1.00000E-06 7.06272E-01 1.75695E+03 4.01987E-04       1 Divergence
   13 1.00000E-06 6.39486E-01 1.75695E+03 3.63974E-04       1 Divergence
   14 1.00000E-06 5.67954E-01 1.75695E+03 3.23261E-04       1 Divergence
   15 1.00000E-06 5.16824E-01 1.75695E+03 2.94159E-04       1 Divergence
   16 1.00000E-06 4.57075E-01 1.75695E+03 2.60152E-04       1 Divergence
   17 1.00000E-06 4.28050E-01 1.75695E+03 2.43632E-04       1 Divergence
   18 1.00000E-06 4.03813E-01 1.75695E+03 2.29837E-04       1 Divergence
   19 1.00000E-06 3.84796E-01 1.75695E+03 2.19013E-04       1 Divergence
   20 1.00000E-06 3.64836E-01 1.75695E+03 2.07653E-04       1 Divergence
   21 1.00000E-06 3.43890E-01 1.75695E+03 1.95731E-04       1 Divergence
   22 1.00000E-06 3.30000E-01 1.75695E+03 1.87825E-04       1 Divergence
   23 1.00000E-06 3.17040E-01 1.75695E+03 1.80449E-04       1 Divergence
   24 1.00000E-06 3.04429E-01 1.75695E+03 1.73271E-04       1 Divergence
   25 1.00000E-06 2.91701E-01 1.75695E+03 1.66026E-04       1 Divergence
   26 1.00000E-06 2.80348E-01 1.75695E+03 1.59565E-04       1 Divergence
   27 1.00000E-06 2.71172E-01 1.75695E+03 1.54342E-04       1 Divergence
   28 1.00000E-06 2.61264E-01 1.75695E+03 1.48702E-04       1 Divergence
   29 1.00000E-06 2.53621E-01 1.75695E+03 1.44353E-04       1 Divergence
   30 1.00000E-06 2.46152E-01 1.75695E+03 1.40102E-04       1 Divergence
   31 1.00000E-06 2.42107E-01 1.75695E+03 1.37799E-04       1 Divergence
   32 1.00000E-06 2.38468E-01 1.75695E+03 1.35728E-04       1 Divergence
   33 1.00000E-06 2.34723E-01 1.75695E+03 1.33597E-04       1 Divergence
   34 1.00000E-06 2.31380E-01 1.75695E+03 1.31694E-04       1 Divergence
   35 1.00000E-06 2.27228E-01 1.75695E+03 1.29331E-04       1 Divergence
   36 1.00000E-06 2.24432E-01 1.75695E+03 1.27739E-04       1 Divergence
   37 1.00000E-06 2.22329E-01 1.75695E+03 1.26542E-04       1 Divergence
   38 1.00000E-06 2.20257E-01 1.75695E+03 1.25363E-04       1 Divergence
   39 1.00000E-06 2.17840E-01 1.75695E+03 1.23987E-04       1 Divergence
   40 1.00000E-06 2.14726E-01 1.75695E+03 1.22215E-04       1 Divergence
   41 1.00000E-06 2.11561E-01 1.75695E+03 1.20414E-04       1 Divergence
   42 1.00000E-06 2.08644E-01 1.75695E+03 1.18753E-04       1 Divergence
   43 1.00000E-06 2.05786E-01 1.75695E+03 1.17127E-04       1 Divergence
   44 1.00000E-06 2.02654E-01 1.75695E+03 1.15344E-04       1 Divergence
   45 1.00000E-06 1.97932E-01 1.75695E+03 1.12656E-04       1 Divergence
   46 1.00000E-06 1.92774E-01 1.75695E+03 1.09720E-04       1 Divergence
   47 1.00000E-06 1.87224E-01 1.75695E+03 1.06562E-04       1 Divergence
   48 1.00000E-06 1.81402E-01 1.75695E+03 1.03248E-04       1 Divergence
   49 1.00000E-06 1.74384E-01 1.75695E+03 9.92536E-05       1 Divergence
   50 1.00000E-06 1.68176E-01 1.75695E+03 9.57201E-05       1 Divergence
   51 1.00000E-06 1.61313E-01 1.75695E+03 9.18140E-05       1 Divergence
   52 1.00000E-06 1.57329E-01 1.75695E+03 8.95462E-05       1 Divergence
   53 1.00000E-06 1.54409E-01 1.75695E+03 8.78842E-05       1 Divergence
   54 1.00000E-06 1.52259E-01 1.75695E+03 8.66606E-05       1 Divergence
   55 1.00000E-06 1.50049E-01 1.75695E+03 8.54031E-05       1 Divergence
   56 1.00000E-06 1.47270E-01 1.75695E+03 8.38214E-05       1 Divergence
   57 1.00000E-06 1.43941E-01 1.75695E+03 8.19263E-05       1 Divergence
   58 1.00000E-06 1.40918E-01 1.75695E+03 8.02056E-05       1 Divergence
   59 1.00000E-06 1.38270E-01 1.75695E+03 7.86989E-05       1 Divergence
   60 1.00000E-06 1.36257E-01 1.75695E+03 7.75530E-05       1 Divergence
   61 1.00000E-06 1.35121E-01 1.75695E+03 7.69061E-05       1 Divergence
   62 1.00000E-06 1.33722E-01 1.75695E+03 7.61100E-05       1 Divergence
   63 1.00000E-06 1.32399E-01 1.75695E+03 7.53572E-05       1 Divergence
   64 1.00000E-06 1.30981E-01 1.75695E+03 7.45497E-05       1 Divergence
   65 1.00000E-06 1.29756E-01 1.75695E+03 7.38528E-05       1 Divergence
   66 1.00000E-06 1.28722E-01 1.75695E+03 7.32643E-05       1 Divergence
   67 1.00000E-06 1.27514E-01 1.75695E+03 7.25765E-05       1 Divergence
   68 1.00000E-06 1.26196E-01 1.75695E+03 7.18263E-05       1 Divergence
   69 1.00000E-06 1.24699E-01 1.75695E+03 7.09747E-05       1 Divergence
   70 1.00000E-06 1.23081E-01 1.75695E+03 7.00538E-05       1 Divergence
   71 1.00000E-06 1.21761E-01 1.75695E+03 6.93022E-05       1 Divergence
   72 1.00000E-06 1.20440E-01 1.75695E+03 6.85502E-05       1 Divergence
   73 1.00000E-06 1.19462E-01 1.75695E+03 6.79937E-05       1 Divergence
   74 1.00000E-06 1.18755E-01 1.75695E+03 6.75911E-05       1 Divergence
   75 1.00000E-06 1.18181E-01 1.75695E+03 6.72645E-05       1 Divergence
   76 1.00000E-06 1.17775E-01 1.75695E+03 6.70335E-05       1 Divergence
   77 1.00000E-06 1.17406E-01 1.75695E+03 6.68235E-05       1 Divergence
   78 1.00000E-06 1.17017E-01 1.75695E+03 6.66022E-05       1 Divergence
   79 1.00000E-06 1.16638E-01 1.75695E+03 6.63865E-05       1 Divergence
   80 1.00000E-06 1.16307E-01 1.75695E+03 6.61978E-05       1 Divergence
   81 1.00000E-06 1.16055E-01 1.75695E+03 6.60545E-05       1 Divergence
   82 1.00000E-06 1.15873E-01 1.75695E+03 6.59511E-05       1 Divergence
   83 1.00000E-06 1.15646E-01 1.75695E+03 6.58218E-05       1 Divergence
   84 1.00000E-06 1.15369E-01 1.75695E+03 6.56641E-05       1 Divergence
   85 1.00000E-06 1.15022E-01 1.75695E+03 6.54664E-05       1 Divergence
   86 1.00000E-06 1.14685E-01 1.75695E+03 6.52747E-05       1 Divergence
   87 1.00000E-06 1.14367E-01 1.75695E+03 6.50939E-05       1 Divergence
   88 1.00000E-06 1.13986E-01 1.75695E+03 6.48769E-05       1 Divergence
   89 1.00000E-06 1.13554E-01 1.75695E+03 6.46313E-05       1 Divergence
   90 1.00000E-06 1.12810E-01 1.75695E+03 6.42074E-05       1 Divergence
   91 1.00000E-06 1.12276E-01 1.75695E+03 6.39036E-05       1 Divergence
   92 1.00000E-06 1.11878E-01 1.75695E+03 6.36773E-05       1 Divergence
   93 1.00000E-06 1.11541E-01 1.75695E+03 6.34855E-05       1 Divergence
   94 1.00000E-06 1.11214E-01 1.75695E+03 6.32993E-05       1 Divergence
   95 1.00000E-06 1.10811E-01 1.75695E+03 6.30699E-05       1 Divergence
   96 1.00000E-06 1.10345E-01 1.75695E+03 6.28049E-05       1 Divergence
   97 1.00000E-06 1.09846E-01 1.75695E+03 6.25205E-05       1 Divergence
   98 1.00000E-06 1.09432E-01 1.75695E+03 6.22851E-05       1 Divergence
   99 1.00000E-06 1.08940E-01 1.75695E+03 6.20049E-05       1 Divergence
  100 1.00000E-06 1.08255E-01 1.75695E+03 6.16149E-05       1 Divergence
  101 1.00000E-06 1.07131E-01 1.75695E+03 6.09755E-05       1 Divergence
  102 1.00000E-06 1.06032E-01 1.75695E+03 6.03500E-05       1 Divergence
  103 1.00000E-06 1.05002E-01 1.75695E+03 5.97638E-05       1 Divergence
  104 1.00000E-06 1.03914E-01 1.75695E+03 5.91441E-05       1 Divergence
  105 1.00000E-06 1.02512E-01 1.75695E+03 5.83463E-05       1 Divergence
  106 1.00000E-06 1.00626E-01 1.75695E+03 5.72729E-05       1 Divergence
  107 1.00000E-06 9.82260E-02 1.75695E+03 5.59069E-05       1 Divergence
  108 1.00000E-06 9.49935E-02 1.75695E+03 5.40671E-05       1 Divergence
  109 1.00000E-06 9.14758E-02 1.75695E+03 5.20650E-05       1 Divergence
  110 1.00000E-06 8.75772E-02 1.75695E+03 4.98460E-05       1 Divergence
  111 1.00000E-06 8.33393E-02 1.75695E+03 4.74340E-05       1 Divergence
  112 1.00000E-06 7.90651E-02 1.75695E+03 4.50012E-05       1 Divergence
  113 1.00000E-06 7.47196E-02 1.75695E+03 4.25279E-05       1 Divergence
  114 1.00000E-06 7.03656E-02 1.75695E+03 4.00498E-05       1 Divergence
  115 1.00000E-06 6.70951E-02 1.75695E+03 3.81883E-05       1 Divergence
  116 1.00000E-06 6.43758E-02 1.75695E+03 3.66405E-05       1 Divergence
  117 1.00000E-06 6.19525E-02 1.75695E+03 3.52613E-05       1 Divergence
  118 1.00000E-06 6.00907E-02 1.75695E+03 3.42016E-05       1 Divergence
  119 1.00000E-06 5.86494E-02 1.75695E+03 3.33813E-05       1 Divergence
  120 1.00000E-06 5.79274E-02 1.75695E+03 3.29704E-05       1 Divergence
  121 1.00000E-06 5.74350E-02 1.75695E+03 3.26901E-05       1 Divergence
  122 1.00000E-06 5.67243E-02 1.75695E+03 3.22856E-05       1 Divergence
  123 1.00000E-06 5.59673E-02 1.75695E+03 3.18547E-05       1 Divergence
  124 1.00000E-06 5.51477E-02 1.75695E+03 3.13882E-05       1 Divergence
  125 1.00000E-06 5.42863E-02 1.75695E+03 3.08979E-05       1 Divergence
  126 1.00000E-06 5.34865E-02 1.75695E+03 3.04427E-05       1 Divergence
  127 1.00000E-06 5.26256E-02 1.75695E+03 2.99527E-05       1 Divergence
  128 1.00000E-06 5.17645E-02 1.75695E+03 2.94626E-05       1 Divergence
  129 1.00000E-06 5.09915E-02 1.75695E+03 2.90227E-05       1 Divergence
  130 1.00000E-06 5.02108E-02 1.75695E+03 2.85783E-05       1 Divergence
  131 1.00000E-06 4.94175E-02 1.75695E+03 2.81268E-05       1 Divergence
  132 1.00000E-06 4.85935E-02 1.75695E+03 2.76578E-05       1 Divergence
  133 1.00000E-06 4.77428E-02 1.75695E+03 2.71736E-05       1 Divergence
  134 1.00000E-06 4.69242E-02 1.75695E+03 2.67077E-05       1 Divergence
  135 1.00000E-06 4.59654E-02 1.75695E+03 2.61620E-05       1 Divergence
  136 1.00000E-06 4.50510E-02 1.75695E+03 2.56415E-05       1 Divergence
  137 1.00000E-06 4.41995E-02 1.75695E+03 2.51569E-05       1 Divergence
  138 1.00000E-06 4.30613E-02 1.75695E+03 2.45090E-05       1 Divergence
  139 1.00000E-06 4.19256E-02 1.75695E+03 2.38627E-05       1 Divergence
  140 1.00000E-06 4.06598E-02 1.75695E+03 2.31422E-05       1 Divergence
  141 1.00000E-06 3.96012E-02 1.75695E+03 2.25397E-05       1 Divergence
  142 1.00000E-06 3.83529E-02 1.75695E+03 2.18292E-05       1 Divergence
  143 1.00000E-06 3.73504E-02 1.75695E+03 2.12586E-05       1 Divergence
  144 1.00000E-06 3.64765E-02 1.75695E+03 2.07612E-05       1 Divergence
  145 1.00000E-06 3.57075E-02 1.75695E+03 2.03235E-05       1 Divergence
  146 1.00000E-06 3.50544E-02 1.75695E+03 1.99518E-05       1 Divergence
  147 1.00000E-06 3.44393E-02 1.75695E+03 1.96017E-05       1 Divergence
  148 1.00000E-06 3.38714E-02 1.75695E+03 1.92784E-05       1 Divergence
  149 1.00000E-06 3.32778E-02 1.75695E+03 1.89406E-05       1 Divergence
  150 1.00000E-06 3.27883E-02 1.75695E+03 1.86620E-05       1 Divergence
  151 1.00000E-06 3.24845E-02 1.75695E+03 1.84891E-05       1 Divergence
  152 1.00000E-06 3.22196E-02 1.75695E+03 1.83383E-05       1 Divergence
  153 1.00000E-06 3.19538E-02 1.75695E+03 1.81870E-05       1 Divergence
  154 1.00000E-06 3.16804E-02 1.75695E+03 1.80314E-05       1 Divergence
  155 1.00000E-06 3.14392E-02 1.75695E+03 1.78941E-05       1 Divergence
  156 1.00000E-06 3.12178E-02 1.75695E+03 1.77682E-05       1 Divergence
  157 1.00000E-06 3.09832E-02 1.75695E+03 1.76346E-05       1 Divergence
  158 1.00000E-06 3.07586E-02 1.75695E+03 1.75068E-05       1 Divergence
  159 1.00000E-06 3.05367E-02 1.75695E+03 1.73805E-05       1 Divergence
  160 1.00000E-06 3.03635E-02 1.75695E+03 1.72819E-05       1 Divergence
  161 1.00000E-06 3.01779E-02 1.75695E+03 1.71762E-05       1 Divergence
  162 1.00000E-06 3.00244E-02 1.75695E+03 1.70889E-05       1 Divergence
  163 1.00000E-06 2.98808E-02 1.75695E+03 1.70071E-05       1 Divergence
  164 1.00000E-06 2.97599E-02 1.75695E+03 1.69383E-05       1 Divergence
  165 1.00000E-06 2.96434E-02 1.75695E+03 1.68720E-05       1 Divergence
  166 1.00000E-06 2.95418E-02 1.75695E+03 1.68142E-05       1 Divergence
  167 1.00000E-06 2.94575E-02 1.75695E+03 1.67662E-05       1 Divergence
  168 1.00000E-06 2.93790E-02 1.75695E+03 1.67216E-05       1 Divergence
  169 1.00000E-06 2.93042E-02 1.75695E+03 1.66790E-05       1 Divergence
  170 1.00000E-06 2.92303E-02 1.75695E+03 1.66369E-05       1 Divergence
  171 1.00000E-06 2.91602E-02 1.75695E+03 1.65970E-05       1 Divergence
  172 1.00000E-06 2.91020E-02 1.75695E+03 1.65639E-05       1 Divergence
  173 1.00000E-06 2.90389E-02 1.75695E+03 1.65280E-05       1 Divergence
  174 1.00000E-06 2.89804E-02 1.75695E+03 1.64947E-05       1 Divergence
  175 1.00000E-06 2.89310E-02 1.75695E+03 1.64666E-05       1 Divergence
  176 1.00000E-06 2.88809E-02 1.75695E+03 1.64380E-05       1 Divergence
  177 1.00000E-06 2.88287E-02 1.75695E+03 1.64083E-05       1 Divergence
  178 1.00000E-06 2.87651E-02 1.75695E+03 1.63721E-05       1 Divergence
  179 1.00000E-06 2.86966E-02 1.75695E+03 1.63331E-05       1 Divergence
  180 1.00000E-06 2.86328E-02 1.75695E+03 1.62968E-05       1 Divergence
  181 1.00000E-06 2.85850E-02 1.75695E+03 1.62696E-05       1 Divergence
  182 1.00000E-06 2.85365E-02 1.75695E+03 1.62420E-05       1 Divergence
  183 1.00000E-06 2.84866E-02 1.75695E+03 1.62136E-05       1 Divergence
  184 1.00000E-06 2.84386E-02 1.75695E+03 1.61863E-05       1 Divergence
  185 1.00000E-06 2.83915E-02 1.75695E+03 1.61595E-05       1 Divergence
  186 1.00000E-06 2.83403E-02 1.75695E+03 1.61303E-05       1 Divergence
  187 1.00000E-06 2.82740E-02 1.75695E+03 1.60926E-05       1 Divergence
  188 1.00000E-06 2.81864E-02 1.75695E+03 1.60428E-05       1 Divergence
  189 1.00000E-06 2.80892E-02 1.75695E+03 1.59874E-05       1 Divergence
  190 1.00000E-06 2.79528E-02 1.75695E+03 1.59098E-05       1 Divergence
  191 1.00000E-06 2.77710E-02 1.75695E+03 1.58063E-05       1 Divergence
  192 1.00000E-06 2.75358E-02 1.75695E+03 1.56725E-05       1 Divergence
  193 1.00000E-06 2.72558E-02 1.75695E+03 1.55131E-05       1 Divergence
  194 1.00000E-06 2.69550E-02 1.75695E+03 1.53419E-05       1 Divergence
  195 1.00000E-06 2.65998E-02 1.75695E+03 1.51397E-05       1 Divergence
  196 1.00000E-06 2.61926E-02 1.75695E+03 1.49079E-05       1 Divergence
  197 1.00000E-06 2.58063E-02 1.75695E+03 1.46881E-05       1 Divergence
  198 1.00000E-06 2.53231E-02 1.75695E+03 1.44130E-05       1 Divergence
  199 1.00000E-06 2.48249E-02 1.75695E+03 1.41295E-05       1 Divergence
  200 1.00000E-06 2.42284E-02 1.75695E+03 1.37900E-05       1 Divergence
  201 1.00000E-06 2.37263E-02 1.75695E+03 1.35042E-05       1 Divergence
  202 1.00000E-06 2.31411E-02 1.75695E+03 1.31711E-05       1 Divergence
  203 1.00000E-06 2.26490E-02 1.75695E+03 1.28911E-05       1 Divergence
  204 1.00000E-06 2.22343E-02 1.75695E+03 1.26550E-05       1 Divergence
  205 1.00000E-06 2.18832E-02 1.75695E+03 1.24552E-05       1 Divergence
  206 1.00000E-06 2.15959E-02 1.75695E+03 1.22916E-05       1 Divergence
  207 1.00000E-06 2.13310E-02 1.75695E+03 1.21409E-05       1 Divergence
  208 1.00000E-06 2.11127E-02 1.75695E+03 1.20166E-05       1 Divergence
  209 1.00000E-06 2.08897E-02 1.75695E+03 1.18897E-05       1 Divergence
  210 1.00000E-06 2.07127E-02 1.75695E+03 1.17890E-05       1 Divergence
  211 1.00000E-06 2.05803E-02 1.75695E+03 1.17136E-05       1 Divergence
  212 1.00000E-06 2.04314E-02 1.75695E+03 1.16289E-05       1 Divergence
  213 1.00000E-06 2.02645E-02 1.75695E+03 1.15339E-05       1 Divergence
  214 1.00000E-06 2.00689E-02 1.75695E+03 1.14225E-05       1 Divergence
  215 1.00000E-06 1.98315E-02 1.75695E+03 1.12874E-05       1 Divergence
  216 1.00000E-06 1.95598E-02 1.75695E+03 1.11328E-05       1 Divergence
  217 1.00000E-06 1.92118E-02 1.75695E+03 1.09347E-05       1 Divergence
  218 1.00000E-06 1.88482E-02 1.75695E+03 1.07278E-05       1 Divergence
  219 1.00000E-06 1.84414E-02 1.75695E+03 1.04963E-05       1 Divergence
  220 1.00000E-06 1.80565E-02 1.75695E+03 1.02772E-05       1 Divergence
  221 1.00000E-06 1.76029E-02 1.75695E+03 1.00190E-05       1 Divergence
  222 1.00000E-06 1.71749E-02 1.75695E+03 9.77535E-06       1 Divergence
  223 1.00000E-06 1.67546E-02 1.75695E+03 9.53613E-06       1 Divergence
  224 1.00000E-06 1.63396E-02 1.75695E+03 9.29993E-06       1 Divergence
  225 1.00000E-06 1.58904E-02 1.75695E+03 9.04428E-06       1 Divergence
  226 1.00000E-06 1.54637E-02 1.75695E+03 8.80141E-06       1 Divergence
  227 1.00000E-06 1.50774E-02 1.75695E+03 8.58155E-06       1 Divergence
  228 1.00000E-06 1.47259E-02 1.75695E+03 8.38151E-06       1 Divergence
  229 1.00000E-06 1.44075E-02 1.75695E+03 8.20026E-06       1 Divergence
  230 1.00000E-06 1.41102E-02 1.75695E+03 8.03108E-06       1 Divergence
  231 1.00000E-06 1.38545E-02 1.75695E+03 7.88553E-06       1 Divergence
  232 1.00000E-06 1.36502E-02 1.75695E+03 7.76923E-06       1 Divergence
  233 1.00000E-06 1.34692E-02 1.75695E+03 7.66623E-06       1 Divergence
  234 1.00000E-06 1.33166E-02 1.75695E+03 7.57937E-06       1 Divergence
  235 1.00000E-06 1.32119E-02 1.75695E+03 7.51978E-06       1 Divergence
  236 1.00000E-06 1.31105E-02 1.75695E+03 7.46208E-06       1 Divergence
  237 1.00000E-06 1.30219E-02 1.75695E+03 7.41162E-06       1 Divergence
  238 1.00000E-06 1.29362E-02 1.75695E+03 7.36283E-06       1 Divergence
  239 1.00000E-06 1.28544E-02 1.75695E+03 7.31629E-06       1 Divergence
  240 1.00000E-06 1.27885E-02 1.75695E+03 7.27880E-06       1 Divergence
  241 1.00000E-06 1.27382E-02 1.75695E+03 7.25015E-06       1 Divergence
  242 1.00000E-06 1.26839E-02 1.75695E+03 7.21923E-06       1 Divergence
  243 1.00000E-06 1.26311E-02 1.75695E+03 7.18918E-06       1 Divergence
  244 1.00000E-06 1.25808E-02 1.75695E+03 7.16056E-06       1 Divergence
  245 1.00000E-06 1.25278E-02 1.75695E+03 7.13041E-06       1 Divergence
  246 1.00000E-06 1.24829E-02 1.75695E+03 7.10483E-06       1 Divergence
  247 1.00000E-06 1.24300E-02 1.75695E+03 7.07476E-06       1 Divergence
  248 1.00000E-06 1.23817E-02 1.75695E+03 7.04724E-06       1 Divergence
  249 1.00000E-06 1.23360E-02 1.75695E+03 7.02122E-06       1 Divergence
  250 1.00000E-06 1.22864E-02 1.75695E+03 6.99299E-06       1 Divergence
  251 1.00000E-06 1.22339E-02 1.75695E+03 6.96310E-06       1 Divergence
  252 1.00000E-06 1.21825E-02 1.75695E+03 6.93386E-06       1 Divergence
  253 1.00000E-06 1.21395E-02 1.75695E+03 6.90940E-06       1 Divergence
  254 1.00000E-06 1.21014E-02 1.75695E+03 6.88769E-06       1 Divergence
  255 1.00000E-06 1.20701E-02 1.75695E+03 6.86989E-06       1 Divergence
  256 1.00000E-06 1.20385E-02 1.75695E+03 6.85191E-06       1 Divergence
  257 1.00000E-06 1.20159E-02 1.75695E+03 6.83902E-06       1 Divergence
  258 1.00000E-06 1.19942E-02 1.75695E+03 6.82672E-06       1 Divergence
  259 1.00000E-06 1.19738E-02 1.75695E+03 6.81510E-06       1 Divergence
  260 1.00000E-06 1.19537E-02 1.75695E+03 6.80367E-06       1 Divergence
  261 1.00000E-06 1.19375E-02 1.75695E+03 6.79443E-06       1 Divergence
  262 1.00000E-06 1.19217E-02 1.75695E+03 6.78545E-06       1 Divergence
  263 1.00000E-06 1.19090E-02 1.75695E+03 6.77821E-06       1 Divergence
  264 1.00000E-06 1.18975E-02 1.75695E+03 6.77168E-06       1 Divergence
  265 1.00000E-06 1.18871E-02 1.75695E+03 6.76573E-06       1 Divergence
  266 1.00000E-06 1.18742E-02 1.75695E+03 6.75841E-06       1 Divergence
  267 1.00000E-06 1.18601E-02 1.75695E+03 6.75037E-06       1 Divergence
  268 1.00000E-06 1.18417E-02 1.75695E+03 6.73990E-06       1 Divergence
  269 1.00000E-06 1.18150E-02 1.75695E+03 6.72470E-06       1 Divergence
  270 1.00000E-06 1.17826E-02 1.75695E+03 6.70628E-06       1 Divergence
  271 1.00000E-06 1.17576E-02 1.75695E+03 6.69204E-06       1 Divergence
  272 1.00000E-06 1.17368E-02 1.75695E+03 6.68021E-06       1 Divergence
  273 1.00000E-06 1.17172E-02 1.75695E+03 6.66903E-06       1 Divergence
  274 1.00000E-06 1.17008E-02 1.75695E+03 6.65968E-06       1 Divergence
  275 1.00000E-06 1.16852E-02 1.75695E+03 6.65085E-06       1 Divergence
  276 1.00000E-06 1.16713E-02 1.75695E+03 6.64293E-06       1 Divergence
  277 1.00000E-06 1.16537E-02 1.75695E+03 6.63288E-06       1 Divergence
  278 1.00000E-06 1.16316E-02 1.75695E+03 6.62030E-06       1 Divergence
  279 1.00000E-06 1.16020E-02 1.75695E+03 6.60345E-06       1 Divergence
  280 1.00000E-06 1.15648E-02 1.75695E+03 6.58229E-06       1 Divergence
  281 1.00000E-06 1.15223E-02 1.75695E+03 6.55808E-06       1 Divergence
  282 1.00000E-06 1.14718E-02 1.75695E+03 6.52937E-06       1 Divergence
  283 1.00000E-06 1.14193E-02 1.75695E+03 6.49951E-06       1 Divergence
  284 1.00000E-06 1.13620E-02 1.75695E+03 6.46688E-06       1 Divergence
  285 1.00000E-06 1.12771E-02 1.75695E+03 6.41855E-06       1 Divergence
  286 1.00000E-06 1.11857E-02 1.75695E+03 6.36654E-06       1 Divergence
  287 1.00000E-06 1.10547E-02 1.75695E+03 6.29197E-06       1 Divergence
  288 1.00000E-06 1.09118E-02 1.75695E+03 6.21063E-06       1 Divergence
  289 1.00000E-06 1.07453E-02 1.75695E+03 6.11586E-06       1 Divergence
  290 1.00000E-06 1.05493E-02 1.75695E+03 6.00433E-06       1 Divergence
  291 1.00000E-06 1.03549E-02 1.75695E+03 5.89368E-06       1 Divergence
  292 1.00000E-06 1.01575E-02 1.75695E+03 5.78129E-06       1 Divergence
  293 1.00000E-06 9.95734E-03 1.75695E+03 5.66738E-06       1 Divergence
  294 1.00000E-06 9.71237E-03 1.75695E+03 5.52796E-06       1 Divergence
  295 1.00000E-06 9.52330E-03 1.75695E+03 5.42035E-06       1 Divergence
  296 1.00000E-06 9.32154E-03 1.75695E+03 5.30551E-06       1 Divergence
  297 1.00000E-06 9.15521E-03 1.75695E+03 5.21084E-06       1 Divergence
  298 1.00000E-06 9.01234E-03 1.75695E+03 5.12952E-06       1 Divergence
  299 1.00000E-06 8.89643E-03 1.75695E+03 5.06355E-06       1 Divergence
  300 1.00000E-06 8.82203E-03 1.75695E+03 5.02121E-06       1 Divergence
  301 1.00000E-06 8.76187E-03 1.75695E+03 4.98696E-06       1 Divergence
  302 1.00000E-06 8.68829E-03 1.75695E+03 4.94508E-06       1 Divergence
  303 1.00000E-06 8.59156E-03 1.75695E+03 4.89003E-06       1 Divergence
  304 1.00000E-06 8.47419E-03 1.75695E+03 4.82323E-06       1 Divergence
  305 1.00000E-06 8.32673E-03 1.75695E+03 4.73930E-06       1 Divergence
  306 1.00000E-06 8.18628E-03 1.75695E+03 4.65936E-06       1 Divergence
  307 1.00000E-06 8.01945E-03 1.75695E+03 4.56440E-06       1 Divergence
  308 1.00000E-06 7.89201E-03 1.75695E+03 4.49187E-06       1 Divergence
  309 1.00000E-06 7.77079E-03 1.75695E+03 4.42287E-06       1 Divergence
  310 1.00000E-06 7.63619E-03 1.75695E+03 4.34627E-06       1 Divergence
  311 1.00000E-06 7.48812E-03 1.75695E+03 4.26199E-06       1 Divergence
  312 1.00000E-06 7.33717E-03 1.75695E+03 4.17607E-06       1 Divergence
  313 1.00000E-06 7.20455E-03 1.75695E+03 4.10059E-06       1 Divergence
  314 1.00000E-06 7.06833E-03 1.75695E+03 4.02306E-06       1 Divergence
  315 1.00000E-06 6.94050E-03 1.75695E+03 3.95030E-06       1 Divergence
  316 1.00000E-06 6.80141E-03 1.75695E+03 3.87114E-06       1 Divergence
  317 1.00000E-06 6.69247E-03 1.75695E+03 3.80913E-06       1 Divergence
  318 1.00000E-06 6.58354E-03 1.75695E+03 3.74713E-06       1 Divergence
  319 1.00000E-06 6.46429E-03 1.75695E+03 3.67926E-06       1 Divergence
  320 1.00000E-06 6.33482E-03 1.75695E+03 3.60557E-06       1 Divergence
  321 1.00000E-06 6.22624E-03 1.75695E+03 3.54377E-06       1 Divergence
  322 1.00000E-06 6.12717E-03 1.75695E+03 3.48738E-06       1 Divergence
  323 1.00000E-06 6.05269E-03 1.75695E+03 3.44499E-06       1 Divergence
  324 1.00000E-06 5.99721E-03 1.75695E+03 3.41341E-06       1 Divergence
  325 1.00000E-06 5.95430E-03 1.75695E+03 3.38899E-06       1 Divergence
  326 1.00000E-06 5.91114E-03 1.75695E+03 3.36442E-06       1 Divergence
  327 1.00000E-06 5.86821E-03 1.75695E+03 3.33999E-06       1 Divergence
  328 1.00000E-06 5.82303E-03 1.75695E+03 3.31427E-06       1 Divergence
  329 1.00000E-06 5.77782E-03 1.75695E+03 3.28854E-06       1 Divergence
  330 1.00000E-06 5.72939E-03 1.75695E+03 3.26098E-06       1 Divergence
  331 1.00000E-06 5.70100E-03 1.75695E+03 3.24482E-06       1 Divergence
  332 1.00000E-06 5.67989E-03 1.75695E+03 3.23280E-06       1 Divergence
  333 1.00000E-06 5.66022E-03 1.75695E+03 3.22161E-06       1 Divergence
  334 1.00000E-06 5.64448E-03 1.75695E+03 3.21265E-06       1 Divergence
  335 1.00000E-06 5.63048E-03 1.75695E+03 3.20468E-06       1 Divergence
  336 1.00000E-06 5.61885E-03 1.75695E+03 3.19806E-06       1 Divergence
  337 1.00000E-06 5.60472E-03 1.75695E+03 3.19002E-06       1 Divergence
  338 1.00000E-06 5.58556E-03 1.75695E+03 3.17912E-06       1 Divergence
  339 1.00000E-06 5.56325E-03 1.75695E+03 3.16642E-06       1 Divergence
  340 1.00000E-06 5.54194E-03 1.75695E+03 3.15429E-06       1 Divergence
  341 1.00000E-06 5.51877E-03 1.75695E+03 3.14110E-06       1 Divergence
  342 1.00000E-06 5.49758E-03 1.75695E+03 3.12904E-06       1 Divergence
  343 1.00000E-06 5.47636E-03 1.75695E+03 3.11696E-06       1 Divergence
  344 1.00000E-06 5.45553E-03 1.75695E+03 3.10511E-06       1 Divergence
  345 1.00000E-06 5.43374E-03 1.75695E+03 3.09270E-06       1 Divergence
  346 1.00000E-06 5.41500E-03 1.75695E+03 3.08204E-06       1 Divergence
  347 1.00000E-06 5.39544E-03 1.75695E+03 3.07090E-06       1 Divergence
  348 1.00000E-06 5.37843E-03 1.75695E+03 3.06122E-06       1 Divergence
  349 1.00000E-06 5.36231E-03 1.75695E+03 3.05205E-06       1 Divergence
  350 1.00000E-06 5.34706E-03 1.75695E+03 3.04337E-06       1 Divergence
  351 1.00000E-06 5.33288E-03 1.75695E+03 3.03530E-06       1 Divergence
  352 1.00000E-06 5.32093E-03 1.75695E+03 3.02849E-06       1 Divergence
  353 1.00000E-06 5.30999E-03 1.75695E+03 3.02227E-06       1 Divergence
  354 1.00000E-06 5.29709E-03 1.75695E+03 3.01493E-06       1 Divergence
  355 1.00000E-06 5.28614E-03 1.75695E+03 3.00870E-06       1 Divergence
  356 1.00000E-06 5.27221E-03 1.75695E+03 3.00077E-06       1 Divergence
  357 1.00000E-06 5.26091E-03 1.75695E+03 2.99433E-06       1 Divergence
  358 1.00000E-06 5.24874E-03 1.75695E+03 2.98741E-06       1 Divergence
  359 1.00000E-06 5.23629E-03 1.75695E+03 2.98032E-06       1 Divergence
  360 1.00000E-06 5.22478E-03 1.75695E+03 2.97377E-06       1 Divergence
  361 1.00000E-06 5.21529E-03 1.75695E+03 2.96837E-06       1 Divergence
  362 1.00000E-06 5.20636E-03 1.75695E+03 2.96328E-06       1 Divergence
  363 1.00000E-06 5.19504E-03 1.75695E+03 2.95685E-06       1 Divergence
  364 1.00000E-06 5.18415E-03 1.75695E+03 2.95064E-06       1 Divergence
  365 1.00000E-06 5.16950E-03 1.75695E+03 2.94231E-06       1 Divergence
  366 1.00000E-06 5.15805E-03 1.75695E+03 2.93579E-06       1 Divergence
  367 1.00000E-06 5.14532E-03 1.75695E+03 2.92855E-06       1 Divergence
  368 1.00000E-06 5.13192E-03 1.75695E+03 2.92092E-06       1 Divergence
  369 1.00000E-06 5.11827E-03 1.75695E+03 2.91315E-06       1 Divergence
  370 1.00000E-06 5.10116E-03 1.75695E+03 2.90341E-06       1 Divergence
  371 1.00000E-06 5.07831E-03 1.75695E+03 2.89041E-06       1 Divergence
  372 1.00000E-06 5.04929E-03 1.75695E+03 2.87389E-06       1 Divergence
  373 1.00000E-06 5.01936E-03 1.75695E+03 2.85685E-06       1 Divergence
  374 1.00000E-06 4.98139E-03 1.75695E+03 2.83524E-06       1 Divergence
  375 1.00000E-06 4.93605E-03 1.75695E+03 2.80943E-06       1 Divergence
  376 1.00000E-06 4.88347E-03 1.75695E+03 2.77951E-06       1 Divergence
  377 1.00000E-06 4.82636E-03 1.75695E+03 2.74700E-06       1 Divergence
  378 1.00000E-06 4.76060E-03 1.75695E+03 2.70958E-06       1 Divergence
  379 1.00000E-06 4.68986E-03 1.75695E+03 2.66931E-06       1 Divergence
  380 1.00000E-06 4.60181E-03 1.75695E+03 2.61920E-06       1 Divergence
  381 1.00000E-06 4.51462E-03 1.75695E+03 2.56957E-06       1 Divergence
  382 1.00000E-06 4.43191E-03 1.75695E+03 2.52249E-06       1 Divergence
  383 1.00000E-06 4.36393E-03 1.75695E+03 2.48381E-06       1 Divergence
  384 1.00000E-06 4.31547E-03 1.75695E+03 2.45622E-06       1 Divergence
  385 1.00000E-06 4.28315E-03 1.75695E+03 2.43782E-06       1 Divergence
  386 1.00000E-06 4.25815E-03 1.75695E+03 2.42360E-06       1 Divergence
  387 1.00000E-06 4.23395E-03 1.75695E+03 2.40982E-06       1 Divergence
  388 1.00000E-06 4.20916E-03 1.75695E+03 2.39571E-06       1 Divergence
  389 1.00000E-06 4.18351E-03 1.75695E+03 2.38111E-06       1 Divergence
  390 1.00000E-06 4.15404E-03 1.75695E+03 2.36434E-06       1 Divergence
  391 1.00000E-06 4.13351E-03 1.75695E+03 2.35265E-06       1 Divergence
  392 1.00000E-06 4.11218E-03 1.75695E+03 2.34052E-06       1 Divergence
  393 1.00000E-06 4.08949E-03 1.75695E+03 2.32760E-06       1 Divergence
  394 1.00000E-06 4.06497E-03 1.75695E+03 2.31365E-06       1 Divergence
  395 1.00000E-06 4.04221E-03 1.75695E+03 2.30069E-06       1 Divergence
  396 1.00000E-06 4.01416E-03 1.75695E+03 2.28472E-06       1 Divergence
  397 1.00000E-06 3.97866E-03 1.75695E+03 2.26452E-06       1 Divergence
  398 1.00000E-06 3.93274E-03 1.75695E+03 2.23838E-06       1 Divergence
  399 1.00000E-06 3.88299E-03 1.75695E+03 2.21007E-06       1 Divergence
  400 1.00000E-06 3.82987E-03 1.75695E+03 2.17983E-06       1 Divergence
  401 1.00000E-06 3.78744E-03 1.75695E+03 2.15568E-06       1 Divergence
  402 1.00000E-06 3.75404E-03 1.75695E+03 2.13667E-06       1 Divergence
  403 1.00000E-06 3.71984E-03 1.75695E+03 2.11721E-06       1 Divergence
  404 1.00000E-06 3.69557E-03 1.75695E+03 2.10339E-06       1 Divergence
  405 1.00000E-06 3.67474E-03 1.75695E+03 2.09154E-06       1 Divergence
  406 1.00000E-06 3.65320E-03 1.75695E+03 2.07928E-06       1 Divergence
  407 1.00000E-06 3.63623E-03 1.75695E+03 2.06962E-06       1 Divergence
  408 1.00000E-06 3.62637E-03 1.75695E+03 2.06401E-06       1 Divergence
  409 1.00000E-06 3.61506E-03 1.75695E+03 2.05757E-06       1 Divergence
  410 1.00000E-06 3.60602E-03 1.75695E+03 2.05242E-06       1 Divergence
  411 1.00000E-06 3.59819E-03 1.75695E+03 2.04797E-06       1 Divergence
  412 1.00000E-06 3.59115E-03 1.75695E+03 2.04396E-06       1 Divergence
  413 1.00000E-06 3.58501E-03 1.75695E+03 2.04047E-06       1 Divergence
  414 1.00000E-06 3.57953E-03 1.75695E+03 2.03735E-06       1 Divergence
  415 1.00000E-06 3.57368E-03 1.75695E+03 2.03402E-06       1 Divergence
  416 1.00000E-06 3.56558E-03 1.75695E+03 2.02941E-06       1 Divergence
  417 1.00000E-06 3.55934E-03 1.75695E+03 2.02586E-06       1 Divergence
  418 1.00000E-06 3.55178E-03 1.75695E+03 2.02155E-06       1 Divergence
  419 1.00000E-06 3.54440E-03 1.75695E+03 2.01736E-06       1 Divergence
  420 1.00000E-06 3.53778E-03 1.75695E+03 2.01359E-06       1 Divergence
  421 1.00000E-06 3.53256E-03 1.75695E+03 2.01062E-06       1 Divergence
  422 1.00000E-06 3.52759E-03 1.75695E+03 2.00779E-06       1 Divergence
  423 1.00000E-06 3.52057E-03 1.75695E+03 2.00379E-06       1 Divergence
  424 1.00000E-06 3.51513E-03 1.75695E+03 2.00069E-06       1 Divergence
  425 1.00000E-06 3.50793E-03 1.75695E+03 1.99660E-06       1 Divergence
  426 1.00000E-06 3.50219E-03 1.75695E+03 1.99333E-06       1 Divergence
  427 1.00000E-06 3.49736E-03 1.75695E+03 1.99058E-06       1 Divergence
  428 1.00000E-06 3.49168E-03 1.75695E+03 1.98735E-06       1 Divergence
  429 1.00000E-06 3.48574E-03 1.75695E+03 1.98397E-06       1 Divergence
  430 1.00000E-06 3.47931E-03 1.75695E+03 1.98031E-06       1 Divergence
  431 1.00000E-06 3.47224E-03 1.75695E+03 1.97628E-06       1 Divergence
  432 1.00000E-06 3.45984E-03 1.75695E+03 1.96922E-06       1 Divergence
  433 1.00000E-06 3.44724E-03 1.75695E+03 1.96206E-06       1 Divergence
  434 1.00000E-06 3.43180E-03 1.75695E+03 1.95327E-06       1 Divergence
  435 1.00000E-06 3.40695E-03 1.75695E+03 1.93912E-06       1 Divergence
  436 1.00000E-06 3.37490E-03 1.75695E+03 1.92088E-06       1 Divergence
  437 1.00000E-06 3.34238E-03 1.75695E+03 1.90237E-06       1 Divergence
  438 1.00000E-06 3.29822E-03 1.75695E+03 1.87724E-06       1 Divergence
  439 1.00000E-06 3.23322E-03 1.75695E+03 1.84024E-06       1 Divergence
  440 1.00000E-06 3.15361E-03 1.75695E+03 1.79493E-06       1 Divergence
  441 1.00000E-06 3.03777E-03 1.75695E+03 1.72900E-06       1 Divergence
  442 1.00000E-06 2.89501E-03 1.75695E+03 1.64774E-06       1 Divergence
  443 1.00000E-06 2.77372E-03 1.75695E+03 1.57871E-06       1 Divergence
  444 1.00000E-06 2.68749E-03 1.75695E+03 1.52963E-06       1 Divergence
  445 1.00000E-06 2.62286E-03 1.75695E+03 1.49284E-06       1 Divergence
  446 1.00000E-06 2.58394E-03 1.75695E+03 1.47069E-06       1 Divergence
  447 1.00000E-06 2.55169E-03 1.75695E+03 1.45233E-06       1 Divergence
  448 1.00000E-06 2.51895E-03 1.75695E+03 1.43370E-06       1 Divergence
  449 1.00000E-06 2.49348E-03 1.75695E+03 1.41921E-06       1 Divergence
  450 1.00000E-06 2.47441E-03 1.75695E+03 1.40835E-06       1 Divergence
  451 1.00000E-06 2.46123E-03 1.75695E+03 1.40085E-06       1 Divergence
  452 1.00000E-06 2.44257E-03 1.75695E+03 1.39023E-06       1 Divergence
  453 1.00000E-06 2.41728E-03 1.75695E+03 1.37583E-06       1 Divergence
  454 1.00000E-06 2.38686E-03 1.75695E+03 1.35852E-06       1 Divergence
  455 1.00000E-06 2.35450E-03 1.75695E+03 1.34010E-06       1 Divergence
  456 1.00000E-06 2.30435E-03 1.75695E+03 1.31156E-06       1 Divergence
  457 1.00000E-06 2.24507E-03 1.75695E+03 1.27782E-06       1 Divergence
  458 1.00000E-06 2.16961E-03 1.75695E+03 1.23487E-06       1 Divergence
  459 1.00000E-06 2.09149E-03 1.75695E+03 1.19041E-06       1 Divergence
  460 1.00000E-06 2.03993E-03 1.75695E+03 1.16106E-06       1 Divergence
  461 1.00000E-06 1.99946E-03 1.75695E+03 1.13803E-06       1 Divergence
  462 1.00000E-06 1.96684E-03 1.75695E+03 1.11946E-06       1 Divergence
  463 1.00000E-06 1.94314E-03 1.75695E+03 1.10597E-06       1 Divergence
  464 1.00000E-06 1.92383E-03 1.75695E+03 1.09498E-06       1 Divergence
  465 1.00000E-06 1.90324E-03 1.75695E+03 1.08326E-06       1 Divergence
  466 1.00000E-06 1.88995E-03 1.75695E+03 1.07570E-06       1 Divergence
  467 1.00000E-06 1.87939E-03 1.75695E+03 1.06969E-06       1 Divergence
  468 1.00000E-06 1.87068E-03 1.75695E+03 1.06473E-06       1 Divergence
  469 1.00000E-06 1.86355E-03 1.75695E+03 1.06067E-06       1 Divergence
  470 1.00000E-06 1.85819E-03 1.75695E+03 1.05762E-06       1 Divergence
  471 1.00000E-06 1.85183E-03 1.75695E+03 1.05400E-06       1 Divergence
  472 1.00000E-06 1.84748E-03 1.75695E+03 1.05153E-06       1 Divergence
  473 1.00000E-06 1.84399E-03 1.75695E+03 1.04954E-06       1 Divergence
  474 1.00000E-06 1.83976E-03 1.75695E+03 1.04713E-06       1 Divergence
  475 1.00000E-06 1.83691E-03 1.75695E+03 1.04551E-06       1 Divergence
  476 1.00000E-06 1.83291E-03 1.75695E+03 1.04323E-06       1 Divergence
  477 1.00000E-06 1.82897E-03 1.75695E+03 1.04099E-06       1 Divergence
  478 1.00000E-06 1.82506E-03 1.75695E+03 1.03877E-06       1 Divergence
  479 1.00000E-06 1.82168E-03 1.75695E+03 1.03684E-06       1 Divergence
  480 1.00000E-06 1.81766E-03 1.75695E+03 1.03455E-06       1 Divergence
  481 1.00000E-06 1.81462E-03 1.75695E+03 1.03282E-06       1 Divergence
  482 1.00000E-06 1.81236E-03 1.75695E+03 1.03153E-06       1 Divergence
  483 1.00000E-06 1.80902E-03 1.75695E+03 1.02964E-06       1 Divergence
  484 1.00000E-06 1.80582E-03 1.75695E+03 1.02781E-06       1 Divergence
  485 1.00000E-06 1.80274E-03 1.75695E+03 1.02606E-06       1 Divergence
  486 1.00000E-06 1.80053E-03 1.75695E+03 1.02480E-06       1 Divergence
  487 1.00000E-06 1.79758E-03 1.75695E+03 1.02313E-06       1 Divergence
  488 1.00000E-06 1.79521E-03 1.75695E+03 1.02178E-06       1 Divergence
  489 1.00000E-06 1.79236E-03 1.75695E+03 1.02015E-06       1 Divergence
  490 1.00000E-06 1.78822E-03 1.75695E+03 1.01780E-06       1 Divergence
  491 1.00000E-06 1.78490E-03 1.75695E+03 1.01591E-06       1 Divergence
  492 1.00000E-06 1.77942E-03 1.75695E+03 1.01279E-06       1 Divergence
  493 1.00000E-06 1.77175E-03 1.75695E+03 1.00842E-06       1 Divergence
  494 1.00000E-06 1.76417E-03 1.75695E+03 1.00410E-06       1 Divergence
  495 1.00000E-06 1.75475E-03 1.75695E+03 9.98743E-07       1 Divergence
  496 1.00000E-06 1.74125E-03 1.75695E+03 9.91059E-07       1 Divergence
  497 1.00000E-06 1.72832E-03 1.75695E+03 9.83699E-07       1 Divergence
  498 1.00000E-06 1.71485E-03 1.75695E+03 9.76033E-07       1 Divergence
  499 1.00000E-06 1.69437E-03 1.75695E+03 9.64381E-07       1 Divergence
  500 1.00000E-06 1.67027E-03 1.75695E+03 9.50661E-07       1 Divergence
  501 1.00000E-06 1.64364E-03 1.75695E+03 9.35507E-07       1 Divergence
  502 1.00000E-06 1.60946E-03 1.75695E+03 9.16050E-07       1 Divergence
  503 1.00000E-06 1.58011E-03 1.75695E+03 8.99344E-07       1 Divergence
  504 1.00000E-06 1.56100E-03 1.75695E+03 8.88471E-07       1 Divergence
  505 1.00000E-06 1.54409E-03 1.75695E+03 8.78844E-07       1 Divergence
  506 1.00000E-06 1.53153E-03 1.75695E+03 8.71698E-07       1 Divergence
  507 1.00000E-06 1.52045E-03 1.75695E+03 8.65387E-07       1 Divergence
  508 1.00000E-06 1.50767E-03 1.75695E+03 8.58116E-07       1 Divergence
  509 1.00000E-06 1.49572E-03 1.75695E+03 8.51315E-07       1 Divergence
  510 1.00000E-06 1.48375E-03 1.75695E+03 8.44499E-07       1 Divergence
        1 PRES gmres:  510  1.4837E-03  1.0000E-06  1.7570E+03  4.4790E+00  6.5689E+00    F
  1     1 Helmholtz VELX    F:   5.0372E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     2 Helmholtz VELX    F:   3.7548E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     3 Helmholtz VELX    F:   2.9811E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     4 Helmholtz VELX    F:   3.4244E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     5 Helmholtz VELX    F:   2.5126E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     6 Helmholtz VELX    F:   3.1289E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     7 Helmholtz VELX    F:   2.2675E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     8 Helmholtz VELX    F:   2.9705E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     9 Helmholtz VELX    F:   2.0600E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    10 Helmholtz VELX    F:   2.5881E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    11 Helmholtz VELX    F:   1.8571E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    12 Helmholtz VELX    F:   2.3955E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    13 Helmholtz VELX    F:   1.6764E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    14 Helmholtz VELX    F:   2.1144E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    15 Helmholtz VELX    F:   1.5109E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    16 Helmholtz VELX    F:   1.9033E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    17 Helmholtz VELX    F:   1.3494E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    18 Helmholtz VELX    F:   1.7204E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    19 Helmholtz VELX    F:   1.2034E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    20 Helmholtz VELX    F:   1.5221E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    21 Helmholtz VELX    F:   1.0667E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    22 Helmholtz VELX    F:   1.3784E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    23 Helmholtz VELX    F:   9.4593E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    24 Helmholtz VELX    F:   1.2150E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    25 Helmholtz VELX    F:   8.3723E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    26 Helmholtz VELX    F:   1.0814E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    27 Helmholtz VELX    F:   7.4172E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    28 Helmholtz VELX    F:   9.5709E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    29 Helmholtz VELX    F:   6.5580E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    30 Helmholtz VELX    F:   8.4010E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    31 Helmholtz VELX    F:   5.8123E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    32 Helmholtz VELX    F:   7.4063E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    33 Helmholtz VELX    F:   5.1583E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    34 Helmholtz VELX    F:   6.4478E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    35 Helmholtz VELX    F:   4.5736E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    36 Helmholtz VELX    F:   5.5897E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    37 Helmholtz VELX    F:   4.0446E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    38 Helmholtz VELX    F:   4.7939E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    39 Helmholtz VELX    F:   3.5297E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    40 Helmholtz VELX    F:   4.0633E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    41 Helmholtz VELX    F:   3.0458E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    42 Helmholtz VELX    F:   3.4152E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    43 Helmholtz VELX    F:   2.5992E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    44 Helmholtz VELX    F:   2.8566E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    45 Helmholtz VELX    F:   2.2129E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    46 Helmholtz VELX    F:   2.3980E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    47 Helmholtz VELX    F:   1.8827E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    48 Helmholtz VELX    F:   2.0141E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    49 Helmholtz VELX    F:   1.6008E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    50 Helmholtz VELX    F:   1.6882E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    51 Helmholtz VELX    F:   1.3526E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    52 Helmholtz VELX    F:   1.4089E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    53 Helmholtz VELX    F:   1.1432E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    54 Helmholtz VELX    F:   1.1718E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    55 Helmholtz VELX    F:   9.7230E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    56 Helmholtz VELX    F:   9.7481E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    57 Helmholtz VELX    F:   8.3091E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    58 Helmholtz VELX    F:   8.0341E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    59 Helmholtz VELX    F:   7.1296E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    60 Helmholtz VELX    F:   6.5755E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    61 Helmholtz VELX    F:   6.0322E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    62 Helmholtz VELX    F:   5.2350E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    63 Helmholtz VELX    F:   4.9399E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    64 Helmholtz VELX    F:   3.9440E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    65 Helmholtz VELX    F:   3.8235E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    66 Helmholtz VELX    F:   3.0369E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    67 Helmholtz VELX    F:   2.9578E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    68 Helmholtz VELX    F:   2.1610E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    69 Helmholtz VELX    F:   2.3270E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    70 Helmholtz VELX    F:   1.8663E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    71 Helmholtz VELX    F:   1.5680E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    72 Helmholtz VELX    F:   1.3638E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    73 Helmholtz VELX    F:   1.4654E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    74 Helmholtz VELX    F:   1.0235E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    75 Helmholtz VELX    F:   9.1389E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    76 Helmholtz VELX    F:   8.8702E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    77 Helmholtz VELX    F:   8.6898E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    78 Helmholtz VELX    F:   6.0201E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    79 Helmholtz VELX    F:   5.0776E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    80 Helmholtz VELX    F:   5.8083E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    81 Helmholtz VELX    F:   4.2300E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    82 Helmholtz VELX    F:   3.6550E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    83 Helmholtz VELX    F:   2.9649E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    84 Helmholtz VELX    F:   3.1284E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    85 Helmholtz VELX    F:   2.9479E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    86 Helmholtz VELX    F:   2.5445E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    87 Helmholtz VELX    F:   2.2850E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    88 Helmholtz VELX    F:   2.3946E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    89 Helmholtz VELX    F:   2.5465E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    90 Helmholtz VELX    F:   2.5046E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    91 Helmholtz VELX    F:   2.2049E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    92 Helmholtz VELX    F:   2.1031E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    93 Helmholtz VELX    F:   2.3922E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    94 Helmholtz VELX    F:   2.4638E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    95 Helmholtz VELX    F:   2.2244E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    96 Helmholtz VELX    F:   2.1260E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    97 Helmholtz VELX    F:   2.0263E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    98 Helmholtz VELX    F:   1.9858E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    99 Helmholtz VELX    F:   1.8289E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1   100 Helmholtz VELX    F:   1.4050E-03   1.0000E-07   5.0000E-04   1.0000E+03
     1   100 **ERROR**: Failed in HMHOLTZ: VELX   1.4050E-03   5.0372E+00   1.0000E-07
  1     1 Helmholtz VELY    F:   5.0372E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     2 Helmholtz VELY    F:   3.7548E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     3 Helmholtz VELY    F:   2.9811E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     4 Helmholtz VELY    F:   3.4244E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     5 Helmholtz VELY    F:   2.5126E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     6 Helmholtz VELY    F:   3.1289E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     7 Helmholtz VELY    F:   2.2675E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     8 Helmholtz VELY    F:   2.9705E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1     9 Helmholtz VELY    F:   2.0600E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    10 Helmholtz VELY    F:   2.5881E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    11 Helmholtz VELY    F:   1.8571E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    12 Helmholtz VELY    F:   2.3955E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    13 Helmholtz VELY    F:   1.6764E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    14 Helmholtz VELY    F:   2.1144E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    15 Helmholtz VELY    F:   1.5109E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    16 Helmholtz VELY    F:   1.9033E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    17 Helmholtz VELY    F:   1.3494E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    18 Helmholtz VELY    F:   1.7204E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    19 Helmholtz VELY    F:   1.2034E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    20 Helmholtz VELY    F:   1.5221E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    21 Helmholtz VELY    F:   1.0667E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    22 Helmholtz VELY    F:   1.3784E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    23 Helmholtz VELY    F:   9.4593E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    24 Helmholtz VELY    F:   1.2150E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    25 Helmholtz VELY    F:   8.3723E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    26 Helmholtz VELY    F:   1.0814E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    27 Helmholtz VELY    F:   7.4172E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    28 Helmholtz VELY    F:   9.5709E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    29 Helmholtz VELY    F:   6.5580E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    30 Helmholtz VELY    F:   8.4010E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    31 Helmholtz VELY    F:   5.8123E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    32 Helmholtz VELY    F:   7.4063E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    33 Helmholtz VELY    F:   5.1583E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    34 Helmholtz VELY    F:   6.4478E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    35 Helmholtz VELY    F:   4.5736E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    36 Helmholtz VELY    F:   5.5897E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    37 Helmholtz VELY    F:   4.0446E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    38 Helmholtz VELY    F:   4.7939E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    39 Helmholtz VELY    F:   3.5297E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    40 Helmholtz VELY    F:   4.0633E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    41 Helmholtz VELY    F:   3.0458E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    42 Helmholtz VELY    F:   3.4152E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    43 Helmholtz VELY    F:   2.5992E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    44 Helmholtz VELY    F:   2.8566E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    45 Helmholtz VELY    F:   2.2129E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    46 Helmholtz VELY    F:   2.3980E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    47 Helmholtz VELY    F:   1.8827E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    48 Helmholtz VELY    F:   2.0141E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    49 Helmholtz VELY    F:   1.6008E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    50 Helmholtz VELY    F:   1.6882E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    51 Helmholtz VELY    F:   1.3526E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    52 Helmholtz VELY    F:   1.4089E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    53 Helmholtz VELY    F:   1.1432E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    54 Helmholtz VELY    F:   1.1718E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    55 Helmholtz VELY    F:   9.7230E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    56 Helmholtz VELY    F:   9.7481E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    57 Helmholtz VELY    F:   8.3091E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    58 Helmholtz VELY    F:   8.0341E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    59 Helmholtz VELY    F:   7.1297E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    60 Helmholtz VELY    F:   6.5755E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    61 Helmholtz VELY    F:   6.0322E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    62 Helmholtz VELY    F:   5.2350E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    63 Helmholtz VELY    F:   4.9399E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    64 Helmholtz VELY    F:   3.9440E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    65 Helmholtz VELY    F:   3.8235E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    66 Helmholtz VELY    F:   3.0369E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    67 Helmholtz VELY    F:   2.9578E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    68 Helmholtz VELY    F:   2.1610E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    69 Helmholtz VELY    F:   2.3270E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    70 Helmholtz VELY    F:   1.8663E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    71 Helmholtz VELY    F:   1.5680E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    72 Helmholtz VELY    F:   1.3638E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    73 Helmholtz VELY    F:   1.4654E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    74 Helmholtz VELY    F:   1.0235E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    75 Helmholtz VELY    F:   9.1389E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    76 Helmholtz VELY    F:   8.8702E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    77 Helmholtz VELY    F:   8.6898E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    78 Helmholtz VELY    F:   6.0201E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    79 Helmholtz VELY    F:   5.0776E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    80 Helmholtz VELY    F:   5.8083E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    81 Helmholtz VELY    F:   4.2300E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    82 Helmholtz VELY    F:   3.6550E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    83 Helmholtz VELY    F:   2.9649E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    84 Helmholtz VELY    F:   3.1284E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    85 Helmholtz VELY    F:   2.9480E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    86 Helmholtz VELY    F:   2.5445E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    87 Helmholtz VELY    F:   2.2850E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    88 Helmholtz VELY    F:   2.3946E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    89 Helmholtz VELY    F:   2.5465E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    90 Helmholtz VELY    F:   2.5046E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    91 Helmholtz VELY    F:   2.2049E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    92 Helmholtz VELY    F:   2.1031E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    93 Helmholtz VELY    F:   2.3923E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    94 Helmholtz VELY    F:   2.4639E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    95 Helmholtz VELY    F:   2.2244E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    96 Helmholtz VELY    F:   2.1260E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    97 Helmholtz VELY    F:   2.0263E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    98 Helmholtz VELY    F:   1.9858E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    99 Helmholtz VELY    F:   1.8289E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1   100 Helmholtz VELY    F:   1.4050E-03   1.0000E-07   5.0000E-04   1.0000E+03
     1   100 **ERROR**: Failed in HMHOLTZ: VELY   1.4050E-03   5.0372E+00   1.0000E-07
  1     1 Helmholtz VELZ    F:   9.5292E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     2 Helmholtz VELZ    F:   6.4166E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     3 Helmholtz VELZ    F:   3.9902E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     4 Helmholtz VELZ    F:   4.2872E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     5 Helmholtz VELZ    F:   2.1071E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     6 Helmholtz VELZ    F:   2.4260E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     7 Helmholtz VELZ    F:   1.9539E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     8 Helmholtz VELZ    F:   1.6743E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1     9 Helmholtz VELZ    F:   1.3834E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1    10 Helmholtz VELZ    F:   1.4388E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1    11 Helmholtz VELZ    F:   1.0349E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1    12 Helmholtz VELZ    F:   1.0620E+01   1.0000E-07   5.0000E-04   1.0000E+03
  1    13 Helmholtz VELZ    F:   9.7298E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    14 Helmholtz VELZ    F:   8.8052E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    15 Helmholtz VELZ    F:   6.9648E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    16 Helmholtz VELZ    F:   7.8431E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    17 Helmholtz VELZ    F:   6.3039E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    18 Helmholtz VELZ    F:   5.6527E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    19 Helmholtz VELZ    F:   5.8296E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    20 Helmholtz VELZ    F:   5.0590E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    21 Helmholtz VELZ    F:   4.4749E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    22 Helmholtz VELZ    F:   4.0941E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    23 Helmholtz VELZ    F:   4.2169E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    24 Helmholtz VELZ    F:   3.2098E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    25 Helmholtz VELZ    F:   3.4489E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    26 Helmholtz VELZ    F:   3.0033E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    27 Helmholtz VELZ    F:   2.6518E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    28 Helmholtz VELZ    F:   2.4470E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    29 Helmholtz VELZ    F:   2.3838E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    30 Helmholtz VELZ    F:   2.0417E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    31 Helmholtz VELZ    F:   1.8710E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    32 Helmholtz VELZ    F:   1.7928E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    33 Helmholtz VELZ    F:   1.5012E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    34 Helmholtz VELZ    F:   1.3838E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    35 Helmholtz VELZ    F:   1.3661E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    36 Helmholtz VELZ    F:   1.1942E+00   1.0000E-07   5.0000E-04   1.0000E+03
  1    37 Helmholtz VELZ    F:   9.7837E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    38 Helmholtz VELZ    F:   9.8364E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    39 Helmholtz VELZ    F:   8.6608E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    40 Helmholtz VELZ    F:   8.1446E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    41 Helmholtz VELZ    F:   6.9231E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    42 Helmholtz VELZ    F:   6.4787E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    43 Helmholtz VELZ    F:   5.3081E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    44 Helmholtz VELZ    F:   5.5599E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    45 Helmholtz VELZ    F:   4.8954E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    46 Helmholtz VELZ    F:   3.9745E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    47 Helmholtz VELZ    F:   3.6509E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    48 Helmholtz VELZ    F:   3.4559E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    49 Helmholtz VELZ    F:   3.2388E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    50 Helmholtz VELZ    F:   2.6830E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    51 Helmholtz VELZ    F:   2.4632E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    52 Helmholtz VELZ    F:   2.0555E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    53 Helmholtz VELZ    F:   1.9987E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    54 Helmholtz VELZ    F:   1.8225E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    55 Helmholtz VELZ    F:   1.5536E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    56 Helmholtz VELZ    F:   1.3305E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    57 Helmholtz VELZ    F:   1.2566E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    58 Helmholtz VELZ    F:   1.1498E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    59 Helmholtz VELZ    F:   1.0225E-01   1.0000E-07   5.0000E-04   1.0000E+03
  1    60 Helmholtz VELZ    F:   9.5690E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    61 Helmholtz VELZ    F:   8.7744E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    62 Helmholtz VELZ    F:   8.1697E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    63 Helmholtz VELZ    F:   7.2685E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    64 Helmholtz VELZ    F:   6.5719E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    65 Helmholtz VELZ    F:   5.3845E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    66 Helmholtz VELZ    F:   4.6931E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    67 Helmholtz VELZ    F:   3.8194E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    68 Helmholtz VELZ    F:   3.2661E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    69 Helmholtz VELZ    F:   2.7015E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    70 Helmholtz VELZ    F:   2.4773E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    71 Helmholtz VELZ    F:   1.9782E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    72 Helmholtz VELZ    F:   1.6632E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    73 Helmholtz VELZ    F:   1.5315E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    74 Helmholtz VELZ    F:   1.4528E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    75 Helmholtz VELZ    F:   1.2165E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    76 Helmholtz VELZ    F:   1.0963E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    77 Helmholtz VELZ    F:   1.0932E-02   1.0000E-07   5.0000E-04   1.0000E+03
  1    78 Helmholtz VELZ    F:   9.5822E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    79 Helmholtz VELZ    F:   7.6653E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    80 Helmholtz VELZ    F:   6.2040E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    81 Helmholtz VELZ    F:   5.0502E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    82 Helmholtz VELZ    F:   4.3983E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    83 Helmholtz VELZ    F:   3.8328E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    84 Helmholtz VELZ    F:   3.2025E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    85 Helmholtz VELZ    F:   2.9368E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    86 Helmholtz VELZ    F:   2.8773E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    87 Helmholtz VELZ    F:   2.8604E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    88 Helmholtz VELZ    F:   2.7054E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    89 Helmholtz VELZ    F:   2.4420E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    90 Helmholtz VELZ    F:   2.2751E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    91 Helmholtz VELZ    F:   2.2877E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    92 Helmholtz VELZ    F:   2.2196E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    93 Helmholtz VELZ    F:   2.1330E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    94 Helmholtz VELZ    F:   2.1739E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    95 Helmholtz VELZ    F:   2.5034E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    96 Helmholtz VELZ    F:   2.8429E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    97 Helmholtz VELZ    F:   2.5881E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    98 Helmholtz VELZ    F:   2.0766E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1    99 Helmholtz VELZ    F:   1.8595E-03   1.0000E-07   5.0000E-04   1.0000E+03
  1   100 Helmholtz VELZ    F:   1.7923E-03   1.0000E-07   5.0000E-04   1.0000E+03
     1   100 **ERROR**: Failed in HMHOLTZ: VELZ   1.7923E-03   9.5292E+01   1.0000E-07
               L1/L2 DIV(V)    :  -3.8266E-06   1.6062E+00
               L1/L2 QTL       :   0.0000E+00   0.0000E+00
               L1/L2 DIV(V)-QTL:  -3.8266E-06   1.6062E+00
               WARNING: DIV(V)-QTL too large!
          1   1.0000E-03  7.2582E+00 Fluid done
filt amp 0.0000 0.0000 0.0000 0.0000 0.0100
filt trn 1.0000 1.0000 1.0000 1.0000 0.9900
        1  1.0000E-03  7.8540E-01  1.0000E+00  3.3862E+00 ubar
 schfile:/home/2014012/jpeixi01/neksamples/expansion/expansion.sch
 CFL, Ctarg!   76.427286262789934       0.50000000000000000
Step      2, t= 2.0000000E-03, DT= 1.0000000E-03, C= 76.427 7.2928E+00 7.2928E+00
  9.99999999999999955E-008  p22            2           1
        2 PRES gmres:  510  1.6457E-03  1.0000E-06  3.5115E+03  4.4956E+00  6.5480E+00    F
     2   100 **ERROR**: Failed in HMHOLTZ: VELX   5.1695E-05   2.5294E+00   1.0000E-07
     2   100 **ERROR**: Failed in HMHOLTZ: VELY   5.1695E-05   2.5294E+00   1.0000E-07
     2   100 **ERROR**: Failed in HMHOLTZ: VELZ   5.2018E-05   6.2429E+01   1.0000E-07
               L1/L2 DIV(V)    :  -3.9826E-06   1.7367E+00
               L1/L2 DIV(V)-QTL:  -3.9826E-06   1.7367E+00
          2   2.0000E-03  7.2092E+00 Fluid done
        2  2.0000E-03  7.8540E-01  1.0000E+00  4.0515E+00 ubar
 CFL, Ctarg!   88.963918084087751       0.50000000000000000
Step      3, t= 3.0000000E-03, DT= 1.0000000E-03, C= 88.964 1.4519E+01 7.2262E+00
  9.99999999999999955E-008  p22            3           1
        3 PRES gmres:  510  6.8139E-04  1.0000E-06  2.9318E+03  4.5070E+00  6.5629E+00    F
     3   100 **ERROR**: Failed in HMHOLTZ: VELX   1.2233E-04   2.4292E+00   1.0000E-07
     3   100 **ERROR**: Failed in HMHOLTZ: VELY   1.2233E-04   2.4292E+00   1.0000E-07
     3   100 **ERROR**: Failed in HMHOLTZ: VELZ   2.9226E-05   5.2030E+01   1.0000E-07
               L1/L2 DIV(V)    :  -4.0140E-06   1.4886E+00
               L1/L2 DIV(V)-QTL:  -4.0140E-06   1.4886E+00
          3   3.0000E-03  7.2199E+00 Fluid done
        3  3.0000E-03  7.8540E-01  1.0000E+00  3.9996E+00 ubar
 CFL, Ctarg!   85.072860002093805       0.50000000000000000
Step      4, t= 4.0000000E-03, DT= 1.0000000E-03, C= 85.073 2.1756E+01 7.2366E+00
        4 PRES gmres:  510  9.5133E-04  1.0000E-06  1.1727E+03  4.4994E+00  6.5550E+00    F
  9.99999999999999955E-008  p22            4           1
     4   100 **ERROR**: Failed in HMHOLTZ: VELX   2.1953E-04   5.8873E+00   1.0000E-07
     4   100 **ERROR**: Failed in HMHOLTZ: VELY   2.1953E-04   5.8873E+00   1.0000E-07
     4   100 **ERROR**: Failed in HMHOLTZ: VELZ   4.4696E-05   2.0886E+01   1.0000E-07
               L1/L2 DIV(V)    :  -4.1535E-06   1.3150E+00
               L1/L2 DIV(V)-QTL:  -4.1535E-06   1.3150E+00
          4   4.0000E-03  7.2123E+00 Fluid done
        4  4.0000E-03  7.8540E-01  1.0000E+00  3.6760E+00 ubar
 CFL, Ctarg!   77.948750333544453       0.50000000000000000
Step      5, t= 5.0000000E-03, DT= 1.0000000E-03, C= 77.949 2.8985E+01 7.2291E+00
          5    PRES alph1n  6.2326E+03  6.0667E+03  1.0274E+00     1
          5    PRES halpha     1 -5.8781E-01
        5 PRES gmres:  510  7.7739E-04  1.0000E-06  1.2938E+00  4.5036E+00  6.5645E+00    F
  9.99999999999999955E-008  p22            5           1
     5   100 **ERROR**: Failed in HMHOLTZ: VELX   4.2651E-04   1.8335E+01   1.0000E-07
     5   100 **ERROR**: Failed in HMHOLTZ: VELY   4.2651E-04   1.8335E+01   1.0000E-07
     5   100 **ERROR**: Failed in HMHOLTZ: VELZ   1.6888E-04   3.9705E+00   1.0000E-07
               L1/L2 DIV(V)    :  -4.1210E-06   1.5917E+00
               L1/L2 DIV(V)-QTL:  -4.1210E-06   1.5917E+00
          5   5.0000E-03  7.2267E+00 Fluid done
        5  5.0000E-03  7.8540E-01  1.0000E+00  4.1843E+00 ubar
 CFL, Ctarg!   96.699964741224690       0.50000000000000000
Step      6, t= 6.0000000E-03, DT= 1.0000000E-03, C= 96.700 3.6228E+01 7.2439E+00
          6    PRES alph1n  3.1298E+04  3.5048E+04  8.9299E-01     2
          6    PRES halpha     2 -3.6429E+00  5.9155E+01
        6 PRES gmres:  510  1.5538E-02  1.0000E-06  6.3365E+00  4.4854E+00  6.5337E+00    F
  9.99999999999999955E-008  p22            6           1
     6   100 **ERROR**: Failed in HMHOLTZ: VELX   2.1875E-03   7.4612E+01   1.0000E-07
     6   100 **ERROR**: Failed in HMHOLTZ: VELY   2.1875E-03   7.4612E+01   1.0000E-07
     6   100 **ERROR**: Failed in HMHOLTZ: VELZ   8.5719E-04   1.8110E+01   1.0000E-07
               L1/L2 DIV(V)    :  -3.6185E-06   6.6419E+00
               L1/L2 DIV(V)-QTL:  -3.6185E-06   6.6419E+00
          6   6.0000E-03  7.2321E+00 Fluid done
        6  6.0000E-03  7.8540E-01  1.0000E+00  2.6491E+01 ubar
 CFL, Ctarg!   708.00485131999335       0.50000000000000000
Step      7, t= 7.0000000E-03, DT= 1.0000000E-03, C=708.005 4.3477E+01 7.2489E+00
          7    PRES alph1n  6.0102E+05  6.3402E+05  9.4795E-01     3
          7    PRES halpha     3 -4.1770E+01 -2.0720E+03  2.4424E+03
        7 PRES gmres:  510  6.9422E-02  1.0000E-06  1.0606E+02  4.6009E+00  6.7103E+00    F
  9.99999999999999955E-008  p22            7           1
     7   100 **ERROR**: Failed in HMHOLTZ: VELX   3.4033E-02   1.0637E+03   1.0000E-07
     7   100 **ERROR**: Failed in HMHOLTZ: VELY   3.4033E-02   1.0637E+03   1.0000E-07
     7   100 **ERROR**: Failed in HMHOLTZ: VELZ   7.2466E-03   2.1147E+02   1.0000E-07
               L1/L2 DIV(V)    :   1.3630E-07   6.9253E+01
               L1/L2 DIV(V)-QTL:   1.3630E-07   6.9253E+01
          7   7.0000E-03  7.3974E+00 Fluid done
        7  7.0000E-03  7.8540E-01  1.0000E+00  2.3804E+02 ubar
 CFL, Ctarg!   6270.1912022422794       0.50000000000000000
Step      8, t= 8.0000000E-03, DT= 1.0000000E-03, C=******* 5.0892E+01 7.4147E+00
          8    PRES alph1n  1.1317E+08  1.0988E+08  1.0299E+00     4
          8    PRES halpha     4 -1.2174E+04  1.6148E+06  5.1069E+05  3.2658E+05
        8 PRES gmres:  510  9.3158E+00  1.0000E-06  2.1635E+04  4.5082E+00  6.5851E+00    F
  9.99999999999999955E-008  p22            8           1
     8   100 **ERROR**: Failed in HMHOLTZ: VELX   7.7090E+00   2.0641E+05   1.0000E-07
     8   100 **ERROR**: Failed in HMHOLTZ: VELY   7.7090E+00   2.0641E+05   1.0000E-07
     8   100 **ERROR**: Failed in HMHOLTZ: VELZ   2.4990E+00   7.2553E+04   1.0000E-07
               L1/L2 DIV(V)    :   4.0704E-03   2.4798E+04
               L1/L2 DIV(V)-QTL:   4.0704E-03   2.4798E+04
          8   8.0000E-03  7.2441E+00 Fluid done
        8  8.0000E-03  7.8540E-01  1.0000E+00  4.9065E+04 ubar
 CFL, Ctarg!   1360732.6106204169       0.50000000000000000
 call outfld: ifpsco: F
        9  8.0000E-03 Write checkpoint:
       0       9 OPEN: expansion0.f00001
           1  Emergency exit:           9    time =  8.00000000000000017E-003
  Latest solution and data are dumped for post-processing.
  *** STOP ***
           2  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
           3  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
           4  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
           5  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
           6  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
           7  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
        9  8.0000E-03 done :: Write checkpoint
                              file size =      88.    MB
                              avg data-throughput =   873.0MB/s
                              io-nodes =     1
          16  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          17  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          18  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          20  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          21  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          22  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          23  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         104  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
  *** STOP ***
          56  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          40  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         105  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
           9  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          57  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          41  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         106  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          10  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          58  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          42  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         107  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          11  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          59  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          43  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         108  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          12  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          60  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          44  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         109  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          24  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          13  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          61  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          45  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         110  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          32  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          80  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          25  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          14  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          62  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          46  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         111  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          33  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          81  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          26  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          15  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          63  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          47  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          48  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          34  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          82  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          96  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          27  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          88  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          49  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          35  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          83  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          97  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          28  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          89  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          50  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          36  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          72  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          84  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         120  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          98  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          29  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          90  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          51  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          37  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          73  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          85  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         121  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          99  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          30  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          91  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          52  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          38  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         112  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          74  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          86  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         122  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         100  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          31  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          92  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          53  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          39  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         113  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          75  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          87  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         123  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         101  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          93  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         128  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          54  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         114  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          76  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         124  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         102  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          94  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         129  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          55  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         115  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          77  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         125  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         103  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          19  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          95  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         130  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         116  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          78  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         126  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         131  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         117  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          79  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         127  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         132  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         118  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         133  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         119  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
         134  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
  *** STOP ***
          64  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          65  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          66  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          67  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          68  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          69  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          70  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
          71  Emergency exit:           9    time =  8.00000000000000017E-003
  *** STOP ***
runtime statistics:
 total time   50.892067055566407
 inv3 time          16  1.82151794433593750E-003  3.57917854338106657E-005
 invc time        9144  7.39049911499023438E-003  1.45219079172416622E-004
 mltd time          24  2.52811908721923828E-002  4.96760936131542138E-004
 cdtp time          24  1.45916938781738281E-002  2.86718436141371812E-004
 eslv time           0   0.0000000000000000        0.0000000000000000
 pres time           8   52.796670913696289        1.0374243761026711
 crsl time        4080   7.9781398773193359       0.15676588393645749
 crsl min    6.8175837993621826
 crsl max    8.9708325862884521
 crsl avg    7.9962120532989500
 hmhz time          27   57.585806846618652        1.1315281571044009
 spro time           9  2.29263305664062500E-003  4.50489278444402358E-005
 usbc time           8  1.89974308013916016E-002  3.73288645962234001E-004
 usbc min   1.78277492523193359E-002
 usbc max   2.98836231231689453E-002
 usb  avg   2.07468492013436791E-002
 axhm time        6763   7.5539877414703369       0.14843153714354990
 advc time          24  0.11107635498046875       2.18258682358470979E-003
 vdss time          25  1.73659324645996094E-002  3.41230637097892872E-004
 vdss min   1.43883228302001953E-002
 vdss max   2.66075134277343750E-002
 vdss avg   1.70246848353633184E-002
 dsum time       10797   2.9744241237640381       5.84457322300628648E-002
 dsum min    2.2821061611175537
 dsum max    4.7710735797882080
 dsum avg    3.1347654890131067
 dadd time           0   7.8218324184417725       0.15369453180004497
 ddsl time           0   0.0000000000000000        0.0000000000000000
 solv time           0   0.0000000000000000        0.0000000000000000
 prep time           9  0.11356639862060547       2.23151475644736957E-003
#  nid       tusbc       tdadd       tcrsl       tvdss       tdsum        tgop    qqq    F
           0  1.8997E-02  7.8218E+00  7.9781E+00  1.7366E-02  2.9744E+00  1.3191E-02 qqq
           1  2.0400E-02  7.8423E+00  8.4285E+00  1.5377E-02  2.5655E+00  1.4935E-02 qqq
           2  2.0486E-02  8.0273E+00  8.1594E+00  1.5913E-02  3.1643E+00  1.4970E-02 qqq
           3  2.0749E-02  8.0644E+00  7.6260E+00  1.7381E-02  3.4140E+00  1.4896E-02 qqq
           4  2.0874E-02  7.9990E+00  8.0812E+00  1.5448E-02  3.0351E+00  1.4895E-02 qqq
           5  2.0221E-02  7.8341E+00  8.6697E+00  1.5337E-02  2.6427E+00  1.4889E-02 qqq
           6  1.9518E-02  7.7666E+00  8.7718E+00  1.5164E-02  2.5814E+00  1.5003E-02 qqq
           7  2.0141E-02  7.9038E+00  8.7661E+00  1.4774E-02  2.7152E+00  1.4891E-02 qqq
           8  2.0012E-02  7.8714E+00  8.1369E+00  1.7557E-02  3.2791E+00  1.4847E-02 qqq
           9  1.9076E-02  7.7617E+00  7.5790E+00  1.7205E-02  3.8093E+00  1.4864E-02 qqq
          10  2.1220E-02  7.9835E+00  8.4108E+00  1.7497E-02  3.3731E+00  1.4930E-02 qqq
          11  1.8966E-02  7.8573E+00  8.5894E+00  1.7756E-02  2.5395E+00  1.4891E-02 qqq
          12  2.1374E-02  7.8222E+00  8.6283E+00  1.6928E-02  2.5987E+00  1.4871E-02 qqq
          13  2.1943E-02  7.8546E+00  8.1899E+00  1.7641E-02  3.1074E+00  1.4981E-02 qqq
          14  1.8917E-02  7.8214E+00  8.1624E+00  1.6000E-02  2.8441E+00  1.5014E-02 qqq
          15  1.9269E-02  7.8290E+00  8.3168E+00  1.6467E-02  3.0379E+00  1.4860E-02 qqq
          16  1.9789E-02  7.8505E+00  7.4406E+00  1.5963E-02  3.9149E+00  1.4874E-02 qqq
          17  2.3311E-02  7.9581E+00  7.8078E+00  1.6060E-02  3.6824E+00  1.4981E-02 qqq
          18  2.0361E-02  7.8511E+00  7.7393E+00  1.6280E-02  3.7710E+00  1.4913E-02 qqq
          19  2.0780E-02  7.8792E+00  7.9376E+00  1.7926E-02  3.6091E+00  1.4794E-02 qqq
          20  2.0782E-02  7.9088E+00  8.2752E+00  1.6706E-02  3.0404E+00  1.5031E-02 qqq
          21  2.0214E-02  7.9419E+00  8.9708E+00  1.5912E-02  2.5444E+00  1.4861E-02 qqq
          22  2.0280E-02  8.2116E+00  8.4133E+00  1.6546E-02  3.2354E+00  1.4845E-02 qqq
          23  2.0966E-02  8.0479E+00  8.5005E+00  1.5932E-02  3.1699E+00  1.4866E-02 qqq
          24  2.0541E-02  7.9525E+00  8.9421E+00  1.5842E-02  2.6931E+00  1.4996E-02 qqq
          25  1.9933E-02  7.7591E+00  8.5776E+00  1.5635E-02  2.7921E+00  1.4881E-02 qqq
          26  1.9004E-02  7.7590E+00  8.2606E+00  1.5479E-02  3.1258E+00  1.5049E-02 qqq
          27  1.8812E-02  7.7192E+00  8.2581E+00  1.7215E-02  3.1503E+00  1.4877E-02 qqq
          28  2.0898E-02  7.6397E+00  8.6141E+00  1.4835E-02  2.6966E+00  1.4866E-02 qqq
          29  2.0755E-02  7.7618E+00  8.8365E+00  1.5570E-02  2.5246E+00  1.4892E-02 qqq
          30  2.0029E-02  7.6449E+00  8.7606E+00  1.5057E-02  2.5247E+00  1.4941E-02 qqq
          31  2.0037E-02  7.7788E+00  8.4921E+00  1.6268E-02  2.9307E+00  1.4912E-02 qqq
          32  1.8462E-02  8.2316E+00  7.2717E+00  1.8251E-02  4.4490E+00  1.4899E-02 qqq
          33  1.9141E-02  8.0813E+00  6.9938E+00  1.7984E-02  4.7711E+00  1.4889E-02 qqq
          34  2.0012E-02  7.7092E+00  7.8662E+00  1.6642E-02  3.4381E+00  1.4867E-02 qqq
          35  1.9677E-02  7.7678E+00  7.7212E+00  1.7287E-02  3.4074E+00  1.4859E-02 qqq
          36  1.9125E-02  7.8100E+00  7.7308E+00  1.6609E-02  3.6359E+00  1.5044E-02 qqq
          37  1.8250E-02  7.5938E+00  7.4622E+00  1.5498E-02  3.6643E+00  1.4992E-02 qqq
          38  2.1388E-02  7.5545E+00  7.3959E+00  1.8540E-02  3.8832E+00  1.4945E-02 qqq
          39  1.8054E-02  7.6125E+00  7.6501E+00  1.6223E-02  3.5646E+00  1.4865E-02 qqq
          40  1.7828E-02  7.5351E+00  7.8967E+00  2.0605E-02  3.3991E+00  1.4906E-02 qqq
          41  2.1564E-02  7.5247E+00  7.8982E+00  2.0040E-02  3.4334E+00  1.4852E-02 qqq
          42  1.9394E-02  7.3486E+00  8.2573E+00  1.7259E-02  2.8028E+00  1.5020E-02 qqq
          43  1.9411E-02  7.9668E+00  8.4359E+00  2.0545E-02  2.8271E+00  1.4862E-02 qqq
          44  2.0115E-02  8.0115E+00  8.3086E+00  2.0946E-02  3.2512E+00  1.4877E-02 qqq
          45  2.0313E-02  7.6972E+00  8.9501E+00  1.7477E-02  2.5241E+00  1.4859E-02 qqq
          46  2.2603E-02  7.6659E+00  8.7327E+00  1.7000E-02  2.6030E+00  1.4980E-02 qqq
          47  1.9747E-02  7.6953E+00  8.2351E+00  1.8872E-02  3.0575E+00  1.4940E-02 qqq
          48  1.9066E-02  7.7223E+00  8.7886E+00  1.5275E-02  2.6701E+00  1.4944E-02 qqq
          49  1.8854E-02  7.6590E+00  8.0037E+00  1.6690E-02  2.9829E+00  1.4903E-02 qqq
          50  2.1531E-02  7.7643E+00  7.7398E+00  1.5923E-02  3.8266E+00  1.4902E-02 qqq
          51  2.0745E-02  7.7767E+00  8.1410E+00  1.5507E-02  3.4132E+00  1.5073E-02 qqq
          52  2.1969E-02  7.7002E+00  8.4550E+00  1.6098E-02  3.0825E+00  1.5024E-02 qqq
          53  1.9438E-02  7.7663E+00  8.3370E+00  1.5162E-02  3.0130E+00  1.4897E-02 qqq
          54  2.0162E-02  7.7306E+00  8.2410E+00  1.6105E-02  3.0812E+00  1.4979E-02 qqq
          55  1.8429E-02  7.6938E+00  7.5033E+00  1.5954E-02  3.8848E+00  1.4934E-02 qqq
          56  1.8039E-02  7.7522E+00  7.3345E+00  1.8445E-02  4.1581E+00  1.4913E-02 qqq
          57  1.9627E-02  7.5588E+00  8.0168E+00  1.6092E-02  3.2113E+00  1.4856E-02 qqq
          58  2.1672E-02  7.6851E+00  8.1503E+00  1.5781E-02  3.4153E+00  1.4944E-02 qqq
          59  2.1654E-02  7.6977E+00  8.6098E+00  1.5740E-02  2.8923E+00  1.4865E-02 qqq
          60  1.8691E-02  7.5917E+00  8.6822E+00  1.6062E-02  2.6721E+00  1.4993E-02 qqq
          61  2.1041E-02  7.5110E+00  8.8209E+00  1.5756E-02  2.6777E+00  1.4864E-02 qqq
          62  1.9603E-02  7.5547E+00  8.1930E+00  1.6981E-02  3.2808E+00  1.5053E-02 qqq
          63  2.0205E-02  7.7503E+00  8.4462E+00  1.6958E-02  3.0425E+00  1.4885E-02 qqq
          64  2.0476E-02  7.6624E+00  8.5345E+00  1.6692E-02  2.9758E+00  1.2822E-03 qqq
          65  2.0051E-02  7.5855E+00  8.9003E+00  1.5428E-02  2.4402E+00  1.2832E-03 qqq
          66  2.6172E-02  7.6515E+00  8.1743E+00  1.5428E-02  3.3445E+00  1.2672E-03 qqq
          67  2.0842E-02  7.8336E+00  6.8920E+00  1.6771E-02  4.6180E+00  1.3671E-03 qqq
          68  2.1120E-02  7.6297E+00  7.9715E+00  1.6677E-02  3.2010E+00  1.2579E-03 qqq
          69  2.0030E-02  7.5890E+00  8.0874E+00  1.4388E-02  2.9543E+00  1.3192E-03 qqq
          70  2.2208E-02  7.6305E+00  7.5651E+00  1.5531E-02  3.4561E+00  1.3931E-03 qqq
          71  2.1794E-02  7.5165E+00  8.1758E+00  1.4644E-02  2.8983E+00  1.3182E-03 qqq
          72  2.0783E-02  7.5779E+00  8.0675E+00  1.7799E-02  3.0843E+00  1.5056E-02 qqq
          73  1.9461E-02  7.6131E+00  7.8338E+00  1.6891E-02  3.3133E+00  1.4898E-02 qqq
          74  1.9565E-02  7.7259E+00  7.9647E+00  1.5613E-02  2.9911E+00  1.4886E-02 qqq
          75  1.9466E-02  7.6783E+00  7.7528E+00  1.5789E-02  3.3698E+00  1.4937E-02 qqq
          76  2.3161E-02  7.7640E+00  7.4294E+00  1.7002E-02  3.3511E+00  1.4886E-02 qqq
          77  1.9887E-02  7.7196E+00  7.7493E+00  1.6977E-02  3.0271E+00  1.4904E-02 qqq
          78  2.1290E-02  7.6826E+00  7.7420E+00  1.6229E-02  3.0658E+00  1.5017E-02 qqq
          79  2.0850E-02  7.7486E+00  7.8388E+00  1.7046E-02  3.0475E+00  1.4970E-02 qqq
          80  2.0608E-02  7.7420E+00  7.9109E+00  1.7637E-02  2.8251E+00  1.4989E-02 qqq
          81  2.0664E-02  7.6271E+00  8.1421E+00  1.6241E-02  2.2821E+00  1.4903E-02 qqq
          82  2.0033E-02  7.6962E+00  8.0105E+00  1.6470E-02  2.8799E+00  1.4858E-02 qqq
          83  2.0547E-02  7.8031E+00  7.9124E+00  1.7149E-02  2.9909E+00  1.4873E-02 qqq
          84  2.0152E-02  7.6862E+00  7.6792E+00  1.6963E-02  3.3774E+00  1.5022E-02 qqq
          85  2.1266E-02  7.7688E+00  7.8481E+00  1.8033E-02  3.1863E+00  1.4942E-02 qqq
          86  2.0369E-02  7.7784E+00  7.9312E+00  1.7189E-02  3.1171E+00  1.4839E-02 qqq
          87  2.2780E-02  7.7185E+00  7.5206E+00  1.7629E-02  3.6009E+00  1.4862E-02 qqq
          88  2.1044E-02  7.5326E+00  8.3698E+00  1.5473E-02  2.3604E+00  1.5050E-02 qqq
          89  2.1616E-02  7.6924E+00  8.3328E+00  1.5203E-02  2.4429E+00  1.4963E-02 qqq
          90  2.2563E-02  7.7314E+00  8.1804E+00  1.4789E-02  2.7396E+00  1.4999E-02 qqq
          91  2.5641E-02  7.6883E+00  7.8726E+00  1.5150E-02  3.0380E+00  1.4883E-02 qqq
          92  2.1547E-02  7.7893E+00  8.0129E+00  1.6886E-02  2.6964E+00  1.4895E-02 qqq
          93  2.0789E-02  7.7934E+00  7.9006E+00  1.6682E-02  3.1198E+00  1.4881E-02 qqq
          94  2.2114E-02  7.8954E+00  7.6806E+00  1.6489E-02  3.3018E+00  1.4925E-02 qqq
          95  2.0794E-02  7.8142E+00  7.6028E+00  1.7606E-02  3.3341E+00  1.4892E-02 qqq
          96  2.0269E-02  7.6726E+00  7.6262E+00  1.8658E-02  3.1795E+00  1.4849E-02 qqq
          97  2.1118E-02  7.8171E+00  7.5935E+00  1.8120E-02  3.2789E+00  1.4895E-02 qqq
          98  2.0828E-02  7.8392E+00  7.5101E+00  1.6401E-02  3.2291E+00  1.4845E-02 qqq
          99  2.1659E-02  7.9864E+00  7.7380E+00  1.7657E-02  3.0656E+00  1.4928E-02 qqq
         100  2.2091E-02  7.7389E+00  7.5233E+00  1.7974E-02  3.2232E+00  1.5021E-02 qqq
         101  2.3491E-02  7.9507E+00  7.4743E+00  1.7877E-02  3.4506E+00  1.4873E-02 qqq
         102  2.3749E-02  7.9925E+00  7.8873E+00  1.6546E-02  3.0521E+00  1.4968E-02 qqq
         103  2.1884E-02  8.1659E+00  8.1194E+00  1.6705E-02  2.9187E+00  1.4843E-02 qqq
         104  2.0611E-02  8.0316E+00  7.7686E+00  1.6595E-02  3.1612E+00  1.4870E-02 qqq
         105  1.9465E-02  7.7357E+00  8.0229E+00  1.5415E-02  2.6442E+00  1.4919E-02 qqq
         106  1.9511E-02  7.7926E+00  7.9963E+00  1.5216E-02  2.7670E+00  1.4984E-02 qqq
         107  1.9622E-02  7.8786E+00  8.2851E+00  1.4623E-02  2.5351E+00  1.4867E-02 qqq
         108  2.0074E-02  7.8709E+00  8.0219E+00  1.6129E-02  2.6274E+00  1.4949E-02 qqq
         109  2.1814E-02  7.8046E+00  8.3771E+00  1.5132E-02  2.4123E+00  1.4867E-02 qqq
         110  2.0707E-02  7.9058E+00  8.2860E+00  1.5233E-02  2.5040E+00  1.5041E-02 qqq
         111  1.9787E-02  7.9039E+00  8.1343E+00  1.8379E-02  2.5311E+00  1.4904E-02 qqq
         112  2.3240E-02  7.8169E+00  7.5040E+00  1.7142E-02  3.2910E+00  1.4847E-02 qqq
         113  2.1423E-02  7.8949E+00  7.5822E+00  1.6338E-02  3.1599E+00  1.4842E-02 qqq
         114  2.0939E-02  7.9426E+00  7.4697E+00  1.9600E-02  3.3665E+00  1.4833E-02 qqq
         115  2.0994E-02  7.9038E+00  7.3860E+00  1.5774E-02  3.3223E+00  1.5022E-02 qqq
         116  2.2229E-02  7.8166E+00  7.6017E+00  1.5407E-02  2.9932E+00  1.4965E-02 qqq
         117  2.0817E-02  8.0007E+00  7.5879E+00  2.0319E-02  3.2945E+00  1.4897E-02 qqq
         118  1.8285E-02  7.8040E+00  7.4030E+00  1.8713E-02  3.2069E+00  1.4925E-02 qqq
         119  1.9691E-02  7.6913E+00  7.5841E+00  1.9394E-02  3.2251E+00  1.4873E-02 qqq
         120  1.9101E-02  7.7747E+00  7.9222E+00  1.8945E-02  2.7652E+00  1.4875E-02 qqq
         121  2.1934E-02  7.8507E+00  7.6348E+00  1.8246E-02  3.1548E+00  1.4961E-02 qqq
         122  1.9693E-02  7.8769E+00  8.0103E+00  1.9356E-02  2.8332E+00  1.5056E-02 qqq
         123  1.9724E-02  7.7084E+00  8.0795E+00  1.8274E-02  2.6286E+00  1.4919E-02 qqq
         124  2.0824E-02  7.8590E+00  8.1825E+00  1.8743E-02  2.6317E+00  1.5001E-02 qqq
         125  2.1933E-02  7.7790E+00  7.8159E+00  1.8163E-02  2.9538E+00  1.4880E-02 qqq
         126  1.9516E-02  7.9766E+00  7.8348E+00  1.8711E-02  2.8852E+00  1.4885E-02 qqq
         127  1.9078E-02  7.7655E+00  7.1991E+00  1.9511E-02  3.6562E+00  1.4900E-02 qqq
         128  1.9639E-02  8.0022E+00  7.6943E+00  1.6644E-02  3.0015E+00  1.4925E-02 qqq
         129  2.9496E-02  9.3101E+00  7.6622E+00  2.4991E-02  3.6170E+00  1.4986E-02 qqq
         130  2.9711E-02  9.3588E+00  7.5876E+00  2.5007E-02  3.7197E+00  1.4921E-02 qqq
         131  2.0338E-02  7.8577E+00  7.4443E+00  1.7324E-02  3.7143E+00  1.4978E-02 qqq
         132  1.9297E-02  7.9682E+00  7.6298E+00  1.7424E-02  3.2416E+00  1.4947E-02 qqq
         133  2.2209E-02  7.9547E+00  7.3134E+00  1.7201E-02  3.8384E+00  1.5018E-02 qqq
         134  2.9884E-02  9.3604E+00  6.8176E+00  2.6608E-02  4.5788E+00  1.5059E-02 qqq
call exitt: dying ...
backtrace(): obtained 12 stack frames.
/home/2014012/jpeixi01/neksamples/expansion/nek5000(print_stack_+0x1a) [0x5084aa]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(exitt_+0x286) [0x5d80d6]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(emerxit_+0x1e9) [0x4b98f9]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(setdt_+0x3a0) [0x4b17e0]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(settime_+0x49) [0x423489]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(nek_advance_+0x2a7) [0x41ab77]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(nek__multi_advance_+0x20) [0x41a880]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(nek_solve_+0xda) [0x41acfa]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(MAIN__+0x26) [0x41a846]
/home/2014012/jpeixi01/neksamples/expansion/nek5000(main+0x2a) [0x63b9ea]
/lib64/libc.so.6(__libc_start_main+0xfd) [0x330ee1ecdd]
/home/2014012/jpeixi01/neksamples/expansion/nek5000() [0x419d09]
total elapsed time             :   6.34487E+01 sec
total solver time incl. I/O    :   5.08921E+01 sec
time/timestep                  :   5.65467E+00 sec
CPU seconds/timestep/gridpt    :   4.57344E-04 sec
