[Nek5000-users] Problem with passive scalar fields - subroutine outfld
Thu Mar 27 09:34:33 CDT 2014
Dear users and developers,
I'm simulating a 3D conjugate heat transfer case, considering
temperature as a passive scalar.
When I simulate only one temperature field everything is ok.
If I add more passive scalar fields (each one identical to the first
one), after the subroutine prepost.f/outfld is called, then some of
these fields are not good.
I ran up to 8 additional fields, and results are the followings ("- -"
means that the field is not good):
ldimt     T              PS1         PS2         PS3         PS4
PS5         PS6         PS7         PS8
                1              ok
                2              ok           --
                3              ok           --             ok
                4              ok           --             ok
ok
                5              ok           --             --
--             ok
                6              ok           --             --
--             ok           ok
                7              ok           --             --
--             ok           ok           ok
                8              ok           --             --
--             ok           ok           ok           ok
                9              ok           --             --
--             ok           ok           ok           ok           ok
I'm using PN-PN.
Nothing changes with the number of mesh points or the number of steps or
the spatial polynomial order.
I saw differences with Visit, with mean temperature profiles, and with
average temperature in fluid and solid domain.
Differences are noticeable also in logfile. Consider the following
example, in which the first field file is dumped at step 250; at step
251 the changes are noticeable in the number of iterations per field
only for PS1, PS2 and PS3.
Step    250, t= 3.1936627E+00, DT= 1.0935650E-02, C=  0.571 7.8515E+01
2.6463E-01
             Solving for heat
        250    Hmholtz TEMP:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 1:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 2:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 3:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 4:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 5:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 6:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 7:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250    Hmholtz PS 8:     17   9.2949E-04   4.5939E-03
1.0000E-03
        250   3.1937E+00  2.0457E-01 Heat done
             Solving for fluid
call outfld: ifpsco: T
      250  3.1937E+00 Write checkpoint:
       0     250 OPEN: cjh_tc0.f00001
      250  3.1937E+00 done :: Write checkpoint
                              file size =      5.6    MB
                              avg data-throughput =   367.7MB/s
                              io-nodes =     1
Step    251, t= 3.2045983E+00, DT= 1.0935650E-02, C=  0.566 7.8809E+01
2.9378E-01
             Solving for heat
        251    Hmholtz TEMP:     17   8.3175E-04   4.6145E-03
1.0000E-03
        251    Hmholtz PS 1:     74   9.1166E-04   1.1888E+02
1.0000E-03
        251    Hmholtz PS 2:     85   9.4452E-04   9.1977E+02
1.0000E-03
        251    Hmholtz PS 3:     91   8.5561E-04   2.3562E+03
1.0000E-03
        251    Hmholtz PS 4:     17   8.3175E-04   4.6145E-03
1.0000E-03
        251    Hmholtz PS 5:     17   8.3175E-04   4.6145E-03
1.0000E-03
        251    Hmholtz PS 6:     17   8.3175E-04   4.6145E-03
1.0000E-03
        251    Hmholtz PS 7:     17   8.3175E-04   4.6145E-03
1.0000E-03
        251    Hmholtz PS 8:     17   8.3175E-04   4.6145E-03
1.0000E-03
        251   3.2046E+00  3.6832E-01 Heat done
Looking to the outfld subroutine I wasn't able to figure out the reason
for that.
Does anyone know how to solve this problem?
Thanks in advance.
Relevant parts of logfile, SIZE, .usr, .box and .rea files are attached
at the end of the mail.
Best Regards,
Donato
________________________________________________________________________
________
SIZE file
      parameter (ldimt= 9)                       ! passive scalars + T
________
*.box file
base.rea
3                      spatial dimension  ( < 0 --> generate .rea/.re2
pair)
10                     number of fields
Box
-10   14   -5
nelx,nely,nelz for Box
0.  6. 1.                                                  x0,x1,gain
-1.00 -0.98 -0.94 -0.86 -0.70 -0.50 -0.25 -0.00 0.25
0.50 0.70 0.86 0.94 0.98 1.00                             y0,y1,...,yn
0.  3. 1.                                                  z0,z1,gain
P  ,P  ,W  ,W  ,P  ,P                                      vel BCs
P  ,P  ,E  ,E  ,P  ,P                                      temp BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS1 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS2 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS3 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS4 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS5 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS6 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS7 BCs
P  ,P  ,E  ,E  ,P  ,P                                      PS8 BCs
Box_up
-10   7  -5
nelx,nely,nelz for Box_up
0.  6. 1.                                                  x0,x1,gain
1.00 1.02 1.06 1.14 1.30 1.50 1.75 2.00                    y0,y1,...,yn
0.  3. 1.                                                  z0,z1,gain
   ,   ,   ,   ,   ,                                       vel BCs
P  ,P  ,I  ,E  ,P  ,P                                      temp  BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS1 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS2 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS3 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS4 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS5 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS6 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS7 BCs
P  ,P  ,I  ,E  ,P  ,P                                      PS8 BCs
Box_down
-10   7  -5
nelx,nely,nelz for Box_down
0.  6. 1.                                                  x0,x1,gain
-2.00 -1.75 -1.50 -1.30 -1.14 -1.06 -1.02 -1.00            y0,y1,...,yn
0.  3. 1.                                                  z0,z1,gain
   ,   ,   ,   ,   ,                                       vel BCs
P  ,P  ,E  ,I  ,P  ,P                                      temp  BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS1 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS2 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS3 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS4 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS5 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS6 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS7 BCs
P  ,P  ,E  ,I  ,P  ,P                                      PS8 BCs
________
logfile
103   Parameters
   1      1.00000         p1    DENSITY
   2     -2812.94         p2    Re_b
   7      1.00000         p7    RHOCP
   8      1.00000         p8    CONDUCT
  11      500.           p11   NSTEPS
  12      0.05            p12   DT
  15      250.           p15   IOSTEP
  21      1.000000E-06    p21   DIVERGENCE
  22      1.000000E-03    p22   HELMHOLTZ
  23     8              p23 NPSCAL
  24      0.100000E-01    p24   TOLREL
  25      0.100000E-01    p25   TOLABS
  26      0.50000         p26   TARGET COURANT NUMBER
  27      3.00000         p27   TORDER
  28      0.000000E+00    p28
  30      1.000000E+00    p30   1: user-def props via USERVP subr.
  52      1.              p52   if >1, history point dump frequency (in
steps)
  54      1.000000E+00    p54   direction of flow rate -- 1-X, 2-Y, 3-Z
  55      3.000E+00       p55   volumetric flow rate
  65      1.00000         p65
  66      0.00000         p66   write format
  67      0.00000         p67   read format
  68      1.              p68   iostep for avg_all (if ^= 0, else =
iostep)
  93      20.000          p93   if>0, # res-proj (adjust MXPREF in SIZEu
accordingly)
  94      5.00000         p94   if>0, start proj vel and p.s. after P094
steps
  95      5.00000         p95   if>0, start proj pressure after p095
steps
  99      4.000000E+00    p99   dealiasing
102      1.00000         p102  dump out divergence at each time step
 IFTRAN   = T
IFFLOW   = T
IFHEAT   = T
IFSPLIT  = T
IFLOMACH = F
IFUSERVP = T
IFUSERMV = F
IFSTRS   = F
IFCHAR   = F
IFCYCLIC = F
IFAXIS   = F
IFMVBD   = F
IFMELT   = F
IFMODEL  = F
IFKEPS   = F
IFMOAB   = F
IFNEKNEK = F
IFSYNC   = T
 IFVCOR   = T
IFINTQ   = F
IFCWUZ   = F
IFSWALL  = F
IFGEOM   = F
IFSURT   = F
IFWCNO   = F
 IFTMSH for field           1    =  F
IFADVC for field           1    =  T
IFNONL for field           1    =  F
 IFTMSH for field           2    =  T
IFADVC for field           2    =  T
IFNONL for field           2    =  F
 IFTMSH for field           3    =  T
IFADVC for field           3    =  T
IFNONL for field           3    =  F
 IFTMSH for field           4    =  T
IFADVC for field           4    =  T
IFNONL for field           4    =  F
 IFTMSH for field           5    =  T
IFADVC for field           5    =  T
IFNONL for field           5    =  F
 IFTMSH for field           6    =  T
IFADVC for field           6    =  T
IFNONL for field           6    =  F
 IFTMSH for field           7    =  T
IFADVC for field           7    =  T
IFNONL for field           7    =  F
 IFTMSH for field           8    =  T
IFADVC for field           8    =  T
IFNONL for field           8    =  F
 IFTMSH for field           9    =  T
IFADVC for field           9    =  T
IFNONL for field           9    =  F
 IFTMSH for field          10    =  T
IFADVC for field          10    =  T
IFNONL for field          10    =  F
 Dealiasing enabled, lxd=           6
________
*.rea file
  ***** OUTPUT FIELD SPECIFICATION *****
           5 SPECIFICATIONS FOLLOW
  T      COORDINATES
  T      VELOCITY
  T      PRESSURE
  T      TEMPERATURE
  F      TEMPERATURE GRADIENT
            8      PASSIVE SCALARS
  T PS 1
  T PS 2
  T PS 3
  T PS 4
  T PS 5
  T PS 6
  T PS 7
  T PS 8
________
*.usr file
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      if (ifield.eq.1) then
         udiff  = param(2)         ! fluid kinematic viscosity
         utrans = param(1)         ! fluid density
         if (ieg .gt. nelgv) then  ! properties in the solid
            utrans  = param(1)     ! solid density
         endif
      else
         utrans  = param(7)        ! fluid rhocp
         udiff   = param(8)        ! fluid conductivity
            udiff   = param(8)     ! solid conductivity
            utrans  = param(7)     ! solid rhocp
         endif
      endif
      return
      end
c------------------------------------------
      subroutine userq  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      qvol   = 1.
      if (ieg.gt.nelgv) qvol = -1.
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux=0.0
      uy=0.0
      uz=0.0
      temp=0.0
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      one  = 1.
      pi   = 4.*atan(one)
      ux = (9.*(1.-y**8))/8.-0.6283185307179586*Cos(x)*Sin(Pi*y)*Sin(z)
      uy = 0.1*(1. + Cos(Pi*y))*Sin(x)*Sin(z)
      uz = 0.3141592653589793*Cos(z)*Sin(x)*Sin(Pi*y)
      temp = 0.d0
      return
      end
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140327/ef8583fb/attachment-0001.html>
