[Nek5000-users] Latest Nek5000 update.
Fri Mar 7 17:18:15 CST 2014
The latest update to the Nek5000 svn repository (version #1010) sets the
default for all outpost files to be the binary f0000? format, unless
otherwise specified in the .usr file.
The .rea file parameter 66 and parameter 67 will ONLY be used by
postx/postex to determine file format.  That is, if you want a file format
that is not f0000?, it MUST  be changed in the .usr file, not the .rea
file.
As a reminder, the format is set according to the param(66)/param(67)
values:
     0       -  ASCII ( fld format)
+/- 6       -  Binary ( .f00000 format)
all others - Binary ( fld format)
These values are now consistent in throughout postx and Nek5000.
Best,
Katherine
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140307/c8a0fc6c/attachment.html>
