[Nek5000-users] Small diffusivity. How heat/diffusion equations are solved?
Thu Jun 26 10:10:06 CDT 2014
I am trying to model inner waves in a salinity-stratified solution,
for which kinematic viscosity is 10^-6, diffusivity is 10^-9, so Schmidt number is about 10^-3.
 If I set viscosity=diffusivity=10^-6, the program works fine, but I get too great effect of diffusion.
If I set diffusivity to be less than 10^-6, solution blows up.
In this connection I have two questions:
Is there a description how heat/diffusion equations are solved in nek5000?
Is it possible to change transport/diffusion equation just to transport equation, i.e. without diffusion at all?
Thanks.
