[Nek5000-users] test of the time average of turbChannel--what's wrong?
Mon Jun 23 08:20:47 CDT 2014
Hi Paul,
I just wanted to come back to this point as it seems the correction
regarding the turbchannel case in the new version of nek is quite sound;
though, the command "timel = time" seems to sit in a wrong position. To
what I understand it must appear after the 'if' statement with regards
the 'write' block to make sure the timel is saved correctly per
timestep.
Cheers
Azad
Hi Xianbei,
You are correct that dtime should be equal to DT.   If you look at
avg_all() in navier5.f
in the main nek source directory, this is what happens because timel is
updated after
the averaging.  In the turbchannel case, this was not done - so I've now
modified the
.usr file to reflect this.  I would suggest to simply use the avg_all
code to do the
time averaging and then to use those average fields to generate
profiles.
Thanks for pointing out the problem with the turbChannel example.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces
at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov
[nek5000-users at lists.mcs.anl.gov]
Sent: Saturday, May 31, 2014 10:38 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] test of the time average of
Hi Xianbei,
The usr files are meant to be modified by the users, so you can adjust
it to
suit your needs.
Paul
Sent: Saturday, May 31, 2014 9:58 PM
To: Nek5000
Subject: [Nek5000-users] test of the time average of turbChannel--what's
wrong?
Hi, all:
     I read about the time average method in the
turbChannel.usr/userchk,here is the origin codes:
     if(icalld.eq.0) then
         call rzero(uavg,n)
         call rzero(urms,n)
         call rzero(vrms,n)
         call rzero(wrms,n)
         call rzero(uvms,n)
         atime = 0.
         timel = time
         call planar_average_s(yy     ,ym1 ,w1,w2)
         icalld = 1
       endif
       dtime = time - timel
       atime = atime + dtime
       if (atime.ne.0. .and. dtime.ne.0.) then
         beta      = dtime/atime
         alpha     = 1.-beta
         ifverbose = .false.
         call avg1(uavg,vx   ,alpha,beta,n,'uavg',ifverbose)
As seen , atime and timel is initialized by 0 and time, so when
time=time+DT, dtime=DT, atime=DT, so the first average value is
vx(t=DT), when time=time+2*DT, dtime=2*DT(timel is not changed, just
equal to the initial value ),atime=3*DT, here question comes: this will
lead to vxmean(t=2*DT)=2/3*vx(t=DT)+1/3*vx(t=2*DT), this is not what we
respect. The right one is make sure that dtime=DT all the time.
Also, I do a test to verify this.In order to be more reliable, the
velocity isn't nomorlized by u_tau. First, calculate by 1 step and
output the means.dat, so the value equal to the time=DT's
#time =  2.0000000E-02
#  y     uup_tau    Umean
   0.000000000E+00  2.031155153E-02  0.000000000E+00
   2.565198406E-03  2.031155153E-02  1.285886819E-02
then restart with the field from previous calculation and output the
means.dat, this will output the value of time=2*DT's,
#time =  4.0000000E-02
#  y     uup_tau    Umean
   0.000000000E+00  2.072569248E-02  0.000000000E+00
   2.565205097E-03  2.072569248E-02  1.288671376E-02
At last, restart the calculation and run 2 steps to calculate the
average of vx(time=DT) and vx(time=2*DT)
#  y     uup_tau    Umean
   0.000000000E+00  2.061649552E-02  0.000000000E+00
   2.565198406E-03  2.061649552E-02  1.287524390E-02
As can be seen, the 2 step average is almost equal to the average of
step 1 and step 2. So what's wrong with my understanding? Is timel alway
updated to the previous time and make sure that dtime=constant? How?
Can anyone help?
Xianbei
