[Nek5000-users] Reg: error in Genmap
Mon Jun 16 14:23:52 CDT 2014
I consider your suggestions Paul. I modified manually. I assume from what
paul suggestion, there is error in the way the mesh points are given. I'm
trying to recheck how the .rea file can be modified using prenek. I already
posted on modifying mesh & BC in .rea using prenek, but it didn't work.
Ravi
On Sun, Jun 15, 2014 at 11:50 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Ravi,
> How did you modify the .rea file?
> Katherine
> On Sun, Jun 15, 2014 at 6:11 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>  Dear Ravi,
>>  My guess is that your mesh is somehow invalid.
>>  A quick look at the genmap.f source indicates that the first number
>> in front of the SELF error indicator is the element number, which would
>> imply something wrong with element number 1.
>>  Paul
>> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
>> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>> *Sent:* Sunday, June 15, 2014 3:05 PM
>> *To:* nek5000-users at lists.mcs.anl.gov
>> *Subject:* [Nek5000-users] Reg: error in Genmap
>>   Hello all,
>>  I get the following error,
>>  Input mesh tolerance (default 0.2):
>> NOTE: smaller is better, but generous is more forgiving for bad meshes.
>> .005
>> reading .rea file data ...
>> start locglob_lexico: 8 8 64 5.000000000000000E-003
>> locglob: 1 1 64
>> locglob: 2 3 64
>> locglob: 3 9 64
>> locglob: 1 18 64
>> locglob: 2 18 64
>> locglob: 3 18 64
>> locglob: 1 18 64
>> locglob: 2 18 64
>> locglob: 3 18 64
>> 1 2 4 Matrix: SELF!!
>> 1 SELF!! 1 3 1 3
>> 2 SELF!! 7 9 7 9
>> cont: SELF!! 1 ??
>> ABORT: SELF-CHK 1 5 1 0
>> Try to tighten the mesh tolerance!
>> 0 quit
>>  How to address this problem. I manually modified the mesh coniditons in
>> the .rea file.
>> I tried to look out for this in the previous posts. Nothing worked for my
>> case from the suggestions.
>>  Thanks,
>>  Ravi Kiran Pendyala,
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140616/f38c73fc/attachment.html>
