[Nek5000-users] volumetric heat source w/ inflow
Tue Jun 10 17:10:44 CDT 2014
Hi Aleks,
As a follow up on the following post, I just wanted to note that the
results of Nek's version of my setup agreed exactly with the MOAB
counterpart, and so the aforementioned issue has different origin.
Mohsen
On 10-Jun-14, at 1:55 PM, Mohsen Behzad wrote:
> Thanks Aleks for your suggestion.
> So you think it might be because of some issue with MOAB. I'll
> check this out, though, apparently, I haven't had any problem
> reading the mesh and sidesets into Nek via MOAB.
> Mohsen
> On 10-Jun-14, at 12:27 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Mohsen,
>> One way I usually check my MOAB setups is by running the Nek's
>> version of it.
>> For this one needs to get Mesh & BC by calling gen_rea(2) from say
>> userchk, add the missing parameters to create .rea file, run
>> genmap for .map file and fill q array in userq2() routine by
>> calling the latter from userq() say once per timestep
>> Aleks
>> ________________________________________
>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-
>> bounces at lists.mcs.anl.gov] on behalf of nek5000-
>> users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>> Sent: Tuesday, June 10, 2014 11:03 AM
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] volumetric heat source w/ inflow
>> Hi Aleks,
>> I should have mentioned in my previous email that I am actually using
>> MOAB.
>> Thanks,
>> Mohsen
>> On 10-Jun-14, at 12:01 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Mohsen,
>>> userq2 is used only with MOAB -- use qvol in userq instead -- see,
>>> e.g. examples/conj_ht/conj_ht.usr but without condition on nelgv
>>> Best.
>>> Aleks
>>> Sent: Tuesday, June 10, 2014 10:16 AM
>>> To: Nek 5000
>>> Subject: [Nek5000-users] volumetric heat source w/ inflow
>>> Hello all,
>>> I am working on a problem consisting of an axially-horizontal
>>> cylindrical tank with an inlet (an opening) at its top and a
>>> connected pipe to its bottom as an outlet. The boundary conditions
>>> are set accordingly, i.e., inflow and outflow, respectively.
>>> There is
>>> no problem with isothermal simulation of such configuration.
>>> However,
>>> when volumetric heat source is added to the fluid domain (via userq2
>>> subroutine), non-physical temperatures have been observed at the
>>> walls (w/ adiabatic BC) in the immediate vicinity of the inflow (w/
>>> Dirichlet temperature BC). In fact, the element nodes close to the
>>> inlet have very high or very low temperatures, which are no
>>> expected.
>>> I am wondering if anyone has any experience/hint on this issue.
>>> Thanks,
>>> Mohsen
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
