[Nek5000-users] quasi 3D and boundary condition
Sun Jun 8 09:44:36 CDT 2014
Hi Zhang,
You can use periodic boundary conditions in the z direction, provided you have at least 3
elements in z.
Prescribed boundary conditions are given in Cartesian coordinates.  If you have the "mv "
bc on your moving surface (i.e., the cylinder surface), along with the following things
       lx2=lx1-2
       ly2=ly1-2
       lz2=lz1-2
 parameter (lx1m=lx1,ly1m=ly1,lz1m=lz1)
in SIZE, and T ifstrs, T ifmvbd in the .rea file, then the mesh will move with the fluid
velocity (which you prescribe as Cartesian velocity vectors, u,v,w).    Note that nek
uses an ALE formulation and the mesh motion must relatively limited or the mesh
becomes too distorted.   For an oscillating cylinder, this should be ok (see
www.mcs.anl.gov/~fischer/ocyl.gif).    I've just added a 2D oscillating cylinder case
that illustrates the basic procedure to the examples suite.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Sunday, June 08, 2014 8:40 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] quasi 3D and boundary condition
Hi Everyone.
I am trying to run the flow past a cylinder case. I am going to move to the 3D simulation for my study. I have two questions:
1) how to run quasi 3D simulation in nek5000 ? if there is not existing code, andy suggestion to how to implement so?
2) how to specify the normal and tangential boundary condition for a curvature boundary?
cheers
Zhang Wei
waynezw0618 at gmail.com
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
