[Nek5000-users] How to run Nek5000 in cluster based on mpich?
Wed Jun 4 23:41:09 CDT 2014
Hi,Paul:
    I change this line:
    mpiexec -np $2 ./nek5000 > $1.log.$2 &
   to
   mpiexec -n $2 ./nek5000 > $1.log.$2 &
   in nekbmpi and then changed the name to 'runnek' in each node
   Then type ./runnek xxx 48
   While the error still exsits.
Xianbei
At 2014-06-04 11:20:52, nek5000-users at lists.mcs.anl.gov wrote:
Hi Xianbei,
Have a look at the nekbmpi script and modify to match the job submission
procedure on your cluster.
Paul
From:nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Wednesday, June 04, 2014 9:34 AM
To: Nek5000
Subject: [Nek5000-users] How to run Nek5000 in cluster based on mpich?
Hi,all:
   I have just built a small cluster of computers, based on mpich.I have tested the capability of this cluster, each node can be called freely.  Now I want to do my simulation in it, however, I don't know how to run Nek. As known, on only 1 computer, one can do like this:
  nekmpi XXX X
or
  nekbmpi XXX X
  while this is not the case in the cluster! I believe most of you have tried this, I'll appreciate if anyone can give me some advice.
Best regards
Xianbei
来自网易手机号码邮箱了解更多
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140605/06cb6afd/attachment-0001.html>
