[Nek5000-users] Error when creating own mesh
Wed Jul 9 08:29:36 CDT 2014
Dear Friedrich,
I recommend running "diff" on the example file and your file.
Assuming that the example file works you should then be close
to understanding the source of difficulty.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Wednesday, July 09, 2014 5:57 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Error when creating own mesh
Dear Neks,
I am have attempted to use nek5000, firstly by following some of the examples etc.
Now I am trying to create my own simulation, which is based upon the ocyl examples.
My efforts simply include creating my own grid points in the .rea file to create a slightly different dimension... I believe I have understood how to define the problem however I continually receive errors when creating the genmap it reads as follows....
Input (.rea) file name:
ocyl
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.2
 reading .rea file data ...
  ERROR: error reading    1          11          24
  aborting 510 in routine rdbdry.
           1  quit
All I have done again is change the dimensions of the elements in the .rea file so I do not see why it would now not work?
Thank you for any help in advance,
Friedrich.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140709/3c77591a/attachment.html>
